gauravbahl Samba Member
Posted: Wed Mar 15, 2023 9:22 pm Post subject: Beetle 2.0 2011 completely stops after 30km |
Hi All,
I have an issue in my Volkswagen beetle 2.0 2011, 6 gear automatic transmission petrol model in India.
It runs fine for few km (20-30km ) but after that it shuts down and i have to wait for engine to cool down completely and only then it get started.
I got tested the radiators and fuse etc but all seems to be fine.
Mechanic said car has issue in valve body, we got it scan in Volkswagen workshop as well and they also said we need to replace the complete valve body for it.
Can you please suggest:
-if above analysis is fine and what I should do in this case
-Is there any way to fix it at cheaper cost
-should i replace valve body OR complete transmission unit (Second hand or new unit? 09G325039D) as per the analysis, any link for this second hand part
Regards
Gaurav |
Root_Werks Samba Member
Joined: December 31, 2007 Posts: 813 Location: San Juan Islands
Posted: Fri Mar 17, 2023 2:01 pm Post subject: Re: Beetle 2.0 2011 completely stops after 30km |
Not much of a later New Beetle person, but almost sounds like a vapor lock or if the FI uses some sort of accumulator, that might be bad (keeps pressure in fuel system).
Harder to tell if the vehicle isn't throwing any ECU codes. _________________ When I set my timing, why do I flush, then take a pee? |
ps2375 Samba Member
Joined: April 24, 2014 Posts: 2471 Location: Meridian,ID
Posted: Fri Mar 17, 2023 5:04 pm Post subject: Re: Beetle 2.0 2011 completely stops after 30km |
Does the tach show RPM when cranking after it "dies"? If not, that would indicate crank position sensor. It won't run if it doesn't know the crank is turning. |
Joined: August 31, 2013 Posts: 12856 Location: North Carolina
Posted: Sat Mar 18, 2023 10:41 am Post subject: Re: Beetle 2.0 2011 completely stops after 30km |
Is the engine shutting off & not starting or is does the engine still run & the vehicle does not move?
Those transmissions are known to have valve body issues, I have replaced dozens of them. There is a place in the UK that rebuilds them. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
volkybus Samba Member
Joined: November 03, 2013 Posts: 481 Location: CASTLETON VT USA
Posted: Wed Mar 29, 2023 8:32 am Post subject: Re: Beetle 2.0 2011 completely stops after 30km |
I had a coulasping (sp) fuel line do this on a
79 (golf or rabbit) it
Would go for a mile or so then die..drove me nuts & I sold it to my neighbor as he had it's twin..He fixed it after a few swaps from his own car...Good luck....Bill PR N VT |
