10degnorth Samba Member
Joined: March 07, 2018 Posts: 473 Location: Bend, Oregon
Posted: Thu Mar 16, 2023 6:30 pm Post subject: Factory VW "Postal" Hightop Teardown |
Foreword:
The following is based what I have been able to find online on TheSamba and other sources as well as word of mouth from folks in the VW community. Due to the lack of information available I may engage in some speculation and conjecture. I am very open to input and correcting this information if you have input.
I had the opportunity to purchase the cut off roof of a Syncro 16 Finnish military ambulance and will be documenting my tear down of it to retrofit onto my tin top here, including the roll-bars, which will be discussed later.
The "Postal" or "Bundepost" hightop was the only hightop installed factory by VW, it even has a melted in VW logo on the under side as you can see below. They were used primarily by the German post office as well as on military vans.
What makes these tops particularly interesting is that VW cut out the roof from right behind the front seats all the way to the rear hatch. The roof's structure was maintained by adding two roll-bar structures where the normal roof ribs are. I was surprised to find that this van utilized a Westfalia roof pressing with the flat spots for hinges in the rear corners rather than a tin top. I am less familiar with the Westfalia roofs, does anyone know if that turned up edge around the rim is standard or not? It can be seen in most of the internal pictures.
The roll-bars are formed sheet metal that slide into a receiver on each side of the roof-hole. It currently appears that these receivers are installed in the roof by cutting holes, sliding them in, then welding them into place. The roll-bar is then slid into the receivers and bolted down in position before being welded in place as well.
There are then more metal ribs that are rivetted to the roll-bars. These appear to be non structural and I assume were used to support cabinets and/or interior panels. When I received the top it was insulated with fiberglass, some of which can still be seen in the photos.
There are a couple of areas on the inside of the top that have metal foil and what appears to be antenna leads coming off of them. The notable ones are in the rear as seen in the next picture, and the "shelf" at the front. Maybe these were used for radio communications? The PO told me that when he got the van this top came off of it still had the lights and sirens as well as more antennas that he removed.
The paint job is pretty neat, I have found a couple examples of Finnish military vans painted with this same scheme so it appears to be something they did over a stock-green van. The original paint color can be seen on the inside.
I am a fan of this top due to its low height compared to some other options. It provides about 6'2" standing height without floor or interior insulation/ sheathing. As a 5'8" guy that's perfect for me. I also appreciate the roll-bar situation since it means I can raise my bed up to create more storage low down. I especially like the way this next van is setup.
I will update more as I continue the tear down. I'll try to answer any questions you've got! _________________ 1984 Wolfsburg Vanagon (Current Project): https://www.thesamba.com/vw/forum/viewtopic.php?t=773912&highlight=
1988 Microsquirted, Wolfsburg Vanagon (Sold): https://www.thesamba.com/vw/forum/viewtopic.php?t=708000&highlight=
Microsquirt Conversion Guide (Work now Discontinued): https://docs.google.com/document/d/1laXykNPbRYS8MT...2imqd2pnx7
hdenter Samba Member
Joined: October 14, 2008 Posts: 2754 Location: San Luis Obispo, CA
Posted: Thu Mar 16, 2023 8:31 pm Post subject: Re: "Postal" Hightop Teardown |
Every picture I've seen of a postal T25 showed a taller sliding door that matches the higher roof...
Hans _________________ '79 triple white convertible bug
'84 sunroof vanagon
'85 weekender |
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12008 Location: Santa Cruz, CA
Posted: Thu Mar 16, 2023 8:40 pm Post subject: Re: "Postal" Hightop Teardown |
hdenter wrote: |
Every picture I've seen of a postal T25 showed a taller sliding door that matches the higher roof... |
They were available with either standard or tall sliding door.
ALIKA T3 Samba Member
Joined: July 30, 2009 Posts: 6360 Location: Honolulu,Hawaii and France
Posted: Thu Mar 16, 2023 8:41 pm Post subject: Re: "Postal" Hightop Teardown |
hdenter wrote: |
Hans |
There were 2 styles, high door or normal door with this roof. The postal indeed had a tall door, so the name is misleading here. That's more an ambulance roof.
The structure is very similar to the High Top from Westfalia. You gotta run a cutting wire to cut the glue but some places are almost impossible, you'll need to make some kind of bar to hold, push/pull the wire. _________________ Silicone Steering Boots and 930 Cv boots for sale in the classifieds.
Posted: Thu Mar 16, 2023 8:48 pm Post subject: Re: "Postal" Hightop Teardown |
Good to see someone building this top up, i am jealous. I was considering going up to snatch it but i don't have room to store it at the moment. |
ZsZ Samba Member
Joined: December 11, 2010 Posts: 1647 Location: Budapest Hungary, Europe
Schnippzle Samba Member
Joined: February 04, 2021 Posts: 288 Location: Swede in London, UK
Posted: Fri Mar 17, 2023 5:08 am Post subject: Re: Factory VW "Postal" Hightop Teardown |
I have just bought the same type of high top to put on our van _________________ 1988 Caravelle - FB25B - Syncro converted
2016 MB E63 AMG S - The daily driver
2019 Harley Davidson FXFBS Fat Bob - The leisure |
joetiger Samba Member
Joined: January 27, 2005 Posts: 5078 Location: denver
Posted: Fri Mar 17, 2023 5:44 am Post subject: Re: Factory VW "Postal" Hightop Teardown |
I love how stout-looking those tops are. One of the most meticulously restored vans I've ever seen had that top, seen here at Solstice several years back. I can't remember if he's a Samba member or not, but it might be worthwhile to find out. I think he's a Syncro Fest guy too:
_________________ Joe T.
'04 GTI 1.8T
'04 Golf R32
Available Now! Vanagon to Louisiana--A Two-Lane Reckoning Through Past and Present
www.josephtrussell.com |
DirtDog Samba Member
Joined: July 06, 2021 Posts: 88 Location: FOCO, Colorado
Posted: Fri Mar 17, 2023 7:16 am Post subject: Re: Factory VW "Postal" Hightop Teardown |
I remember that van that year. It was super cool. Awesome to see someone doing this! |
michaelasnider Samba Member
Joined: September 27, 2013 Posts: 369 Location: East Kootenays, Canada
Posted: Fri Mar 17, 2023 7:24 am Post subject: Re: Factory VW "Postal" Hightop Teardown |
joetiger wrote: |
That van belongs to Barry Guscott, who owns Werke1 in Richmond BC. |
Posted: Mon Mar 27, 2023 7:00 pm Post subject: Re: Factory VW "Postal" Hightop Teardown |
The top is off!!!
What I ended up doing was bending the extra rail up the whole way around the top, then found a spot where there was already some separation between the fiberglass and metal roof. I was able to use a mix of a small pry bar, a rubber mallet, and a bit of cutting wire to separate the top and the roof.
Bent up drip rail.
Pry bar and mallet.
First light.
Edge of separated top.
Whoever took off the ambulance lights and siren left quite the mess of sealant.
I went ahead and scraped off the sealant and then wallowed out the holes to provide more surface area for fiberglass filler to bond to.
Then came the filler itself.
Lots of sanding, and a second coat of filler for the high spots.
Currently waiting on some filler to cure before doing a bit more sanding.
The camo paint job had sharp edges everywhere that the color changed so I am going through and evening out the transitions so that those hard edges don't show through when it gets painted.
Last night I did a quick test fit of the top, mostly to keep myself inspired by the project. It doesn't sit quite right yet since I didn't take off the rear hatch to fit the top's "tongue" against the body.
Microsquirt Conversion Guide (Work now Discontinued): https://docs.google.com/document/d/1laXykNPbRYS8MT...2imqd2pnx7 |
Posted: Tue Mar 28, 2023 7:11 am Post subject: Re: Factory VW "Postal" Hightop Teardown |
This might be a stupid question, but once the new roof is on will there be space in the rear part for extra bed space or is the roof not tall enough? _________________ 1988 Caravelle - FB25B - Syncro converted
jimf909 Samba Member
Posted: Tue Mar 28, 2023 7:19 am Post subject: Re: Factory VW "Postal" Hightop Teardown |
_________________ - Jim
Abscate wrote: |
Posted: Tue Mar 28, 2023 7:56 am Post subject: Re: Factory VW "Postal" Hightop Teardown |
Schnippzle wrote: |
This might be a stupid question, but once the new roof is on will there be space in the rear part for extra bed space or is the roof not tall enough? |
This top is one of the shorter tops that was made for the Vanagon, it’s similar, or shorter than the Adventure Wagon that was available in the states. The AW had a bed in the top I believe, but the general consensus is that it’s mostly only good for kids due to the lack of headroom. The plan for mine is to cut the roof out all the way to the tailgate to open up some more options for interior layouts. _________________ 1984 Wolfsburg Vanagon (Current Project): https://www.thesamba.com/vw/forum/viewtopic.php?t=773912&highlight=
Posted: Tue Mar 28, 2023 10:34 pm Post subject: Re: Factory VW "Postal" Hightop Teardown |
10degnorth wrote: |
Schnippzle wrote: |
This top is one of the shorter tops that was made for the Vanagon, it’s similar, or shorter than the Adventure Wagon that was available in the states. The AW had a bed in the top I believe, but the general consensus is that it’s mostly only good for kids due to the lack of headroom. The plan for mine is to cut the roof out all the way to the tailgate to open up some more options for interior layouts. |
Gotcha, ok. Thank you. _________________ 1988 Caravelle - FB25B - Syncro converted
ZsZ Samba Member
Posted: Wed Mar 29, 2023 12:08 am Post subject: Re: Factory VW "Postal" Hightop Teardown |
From the camo paint, and holes the donor for the roof was a finnish military ambulance van.
It was a factory hightop option, hightop with standard height door.
An other option was a hightop with raised height door.
Both are referred as "postal" hightops as german (and austrian) post used these. Most of the postal vans were with tall doors, but they had some standard ones too. But as I said both were an order option, although never saw a tall door hightop kombi (9 seater) by factory.
If the donor is yellow and the door was tall then it is definitively a former Deutsche Post van.
As I read somewhere the roofs were put on in the Westfalia factory beside the VW plant in Hannover just like the westy hightops. _________________ Zoltan
1.9 MTdi 2wd Multivan (ex Caravelle)
Van since 2006, engine since 2008 |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17155 Location: Retired South Florida
Posted: Wed Mar 29, 2023 3:13 am Post subject: Re: Factory VW "Postal" Hightop Teardown |
Always impressed by these types of mega projects. Thanks for taking the time to document. Comment on the larger hole repairs. I’d have used at least one layer of 3/4 oz fiberglass mat for initial covering. Short of that, Duraglass filler has fibers for strengthening. Regular filler isn’t that strong and might lift or crack in use. Thanks again. _________________ ☮️ |
DuncanS Samba Member
Posted: Wed Mar 29, 2023 6:16 am Post subject: Re: Factory VW "Postal" Hightop Teardown |
MarkWard wrote: |
Comment on the larger hole repairs. I’d have used at least one layer of 3/4 oz fiberglass mat for initial covering. Short of that, Duraglass filler has fibers for strengthening. Regular filler isn’t that strong and might lift or crack in use. Thanks again. |
I agree. Although the following concerned a crack, it's good for holes as well.
DuncanS wrote: |
Fiberglass resins break down over time and so 30 year old material is not as strong as when it was new. The repair should be at least as strong as it was when new and spread the loads out over a large area of the still good, but weakened material.
The crude drawing shows what I mentioned in a previous post. Note both sides have been repaired. Ideally, say in a dinghy bottom which takes stress when landing and people step on the bottom when it's on the ground, I would grind back both sides as much as possible. The joint has to have as much area as is reasonable or the still good material will then crack around the repair. A single side repair won't be as strong as putting cloth on both sides.
Read: https://www.thesamba.com/vw/forum/viewtopic.php?t=755749&highlight=[/quote]
Duncan |
