walarson Samba Member
Joined: November 02, 2017 Posts: 53 Location: Deerwood MN
Posted: Sun Mar 26, 2023 2:49 pm Post subject: Bosch fuel injected fuel pump wiring |
Greetings. Note the picture is a new Bosch fuel pump for my 76 FI beetle sedan.
Simple, and probably dumb, question: which terminal is the positive? There are NO markings on the pump of any kind to indicate.
My assumption is the smaller terminal is the positive.
Thanks in advance.
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51156 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sun Mar 26, 2023 3:46 pm Post subject: Re: Bosch fuel injected fuel pump wiring |
Fatter one is +. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
61SNRF Samba Member
Joined: March 29, 2009 Posts: 4657 Location: Whittier 90602
Posted: Sun Mar 26, 2023 4:10 pm Post subject: Re: Bosch fuel injected fuel pump wiring |
Your picture clearly shows a + sign under the left/small terminal and a - sign under the right/larger terminal.
Those markings are there to indicate +/power and -/ground. _________________ -Bruce
An ounce of prevention is worth a pound of cure. |
Posted: Sun Mar 26, 2023 4:26 pm Post subject: Re: Bosch fuel injected fuel pump wiring |
Godammit you are right!, disregard standard practice and go with the labels on the unit. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9969 Location: Huntington Beach, CA
Posted: Sun Mar 26, 2023 4:31 pm Post subject: Re: Bosch fuel injected fuel pump wiring |
Just to clarify. In case someone does not see it.
_________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
MuzzcoVW Samba Member
Joined: February 21, 2018 Posts: 1477 Location: Westfield, MA.
Posted: Tue Mar 28, 2023 1:35 pm Post subject: Re: Bosch fuel injected fuel pump wiring |
walarson wrote: |
Thanks in advance.
Glad you got it figured out. You don't want it reversed believe me! A friend had his reversed and spent most of a weekend pulling his hair out. The pump will run, but pump absolutely no fuel. He was slightly upset when we found the issue |
