sweeds Samba Member
Joined: June 23, 2004 Posts: 7 Location: Grand Rapids, MI
Posted: Thu Jul 08, 2004 7:19 am Post subject: Installing Alternator Belt - Need Help? |
I was "attempting" to install my new pulley and belt last night, but the belt seemed to be WAY too small. I have a 73 Westy, does anyone have a belt size they use? I have a newer engine in the bus, replaced the original, and the belt I bought (CONITECH AVX10X888) is about an inch too short. I did put the belt on the pulley first and then tried to wrap in around. Any ideas, different belts to look into?
Thanks |
pawesty Samba Medic
Joined: June 28, 2003 Posts: 1545 Location: Northern Vermont
Posted: Thu Jul 08, 2004 7:57 am Post subject: |
your belt should be Conti 10x965
dave _________________ "Go smell the wind, go far. Hear the marvelous strange chime of midnight" Kerouac
79 westy
78 westy
purveyor of refurbed westies and parts!!! inquire within!
sweeds Samba Member
Posted: Thu Jul 08, 2004 11:03 am Post subject: |
I have a Gatorback 11x965 from AutoZone, so could I get a Gatorback 10x965 from the same place. I just purchased a Dynaflex by Dayco at Pep Boys. Anyone else have any suggestions? |
AhnwS71 Samba Member
Joined: January 31, 2018 Posts: 215 Location: Huntsville, AL
Posted: Thu Oct 03, 2019 8:28 am Post subject: Re: Installing Alternator Belt - Need Help? |
sweeds wrote: |
Thanks |
same issue here. I have a 71 Westy (alternator) and just replaced the alternator pulley and have a new belt (contitech 11.3 x 912 La) that i cannot get on.
in the videos i have watched, they put the belt on, then rear pulley piece on, then tighten it down. When i try to put the belt on, i cannot get the rear pulley section on without it being open more at the top vs the bottom and it pinches the belt when i try to tighten it down.
see example:
Also, in the videos it seems the belt rides further up on the pulley than mine appears to reach. Do i need a longer belt or am i doing my first belt change incorrectly?
Thanks for your input. _________________ '71 Westy
Sometimes you eat the bar, and sometimes the bar eats you. the Stranger |
Zed999 Samba Member
Posted: Thu Oct 03, 2019 9:48 am Post subject: Re: Installing Alternator Belt - Need Help? |
To get it to ride up on your partly tightened top pulley, turn the nut, the pulley ( and the engine) will turn and the belt will ride up as the nut tightens down. If the pulley half is still not square you need more shims between or a longer belt. Only when it's all looking good should you lock the pulley and tighten to spec. |
Posted: Thu Oct 03, 2019 10:26 am Post subject: Re: Installing Alternator Belt - Need Help? |
Zed999 wrote: |
turn the nut, the pulley ( and the engine) will turn and the belt will ride up as the nut tightens down. . |
AH, What i am doing is tightening the nut to the point it turns them all. So instead, manually turn the three (nut,pulley,pulley) before the nut is tightened down completely. will report back. _________________ '71 Westy
Zed999 Samba Member
Posted: Thu Oct 03, 2019 12:47 pm Post subject: Re: Installing Alternator Belt - Need Help? |
AhnwS71 wrote: |
Zed999 wrote: |
AH, What i am doing is tightening the nut to the point it turns them all. So instead, manually turn the three (nut,pulley,pulley) before the nut is tightened down completely. will report back. |
No you have it right - that's what I meant - let the nut turn everything. |
Posted: Thu Oct 03, 2019 4:09 pm Post subject: Re: Installing Alternator Belt - Need Help? |
Got enough shims between the pulley halves? A 11mm belt is going to effectively be shorter than a 10mm belt of the same length as it will ride higher in the pulleys.
SGKent Samba Member
Posted: Thu Oct 03, 2019 4:17 pm Post subject: Re: Installing Alternator Belt - Need Help? |
we have multiple alternators and designs here being discussed. The original 2004 post discusses a North American 1973 pancake engine with an alternator under the tin, that rotates to adjust. A 1971 upright came with a generator, is managed with shims, and someone has upgraded it to an alternator. Two different animals.
To the latest poster - if the belt on the 1971 bus worked for a long time all you need to do is look at the numbers on it to see what it is and buy one that size. If it fails frequently then maybe the alignment of the belt is off. Who upgraded it? _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
kreemoweet Samba Member
Joined: March 13, 2008 Posts: 3898 Location: Seattle, WA
Posted: Thu Oct 03, 2019 5:36 pm Post subject: Re: Installing Alternator Belt - Need Help? |
AhnwS71 wrote: |
same issue here. I have a 71 Westy (alternator) and just replaced the alternator pulley and have a new belt (contitech 11.3 x 912 La) that i cannot get on. |
Pulleys are not all the same. Some of them will simply not work with the 11.3 x 912 "alternator" belt. Try the standard VW generator-size 9.5 x 905 belt. That's what I use
on my '71 bus with alternator, because it's the only size that works with the pulleys I have. _________________ '67 bug: seized by the authorities
Abscate Samba Member
Joined: October 05, 2014 Posts: 22640 Location: NYC/Upstate/ROW
Posted: Thu Oct 03, 2019 7:09 pm Post subject: Re: Installing Alternator Belt - Need Help? |
You can do this with a screwdriver while the engine is running.,,,wait,,,is this allowed ?? _________________ .ssS! |
Posted: Thu Oct 03, 2019 7:52 pm Post subject: Re: Installing Alternator Belt - Need Help? |
SGKent wrote: |
To the latest poster - if the belt on the 1971 bus worked for a long time all you need to do is look at the numbers on it to see what it is and buy one that size. If it fails frequently then maybe the alignment of the belt is off. Who upgraded it? |
let me start at the beginning, the engine was purchased from west coast core and was covered with chrome tin/fan shroud and cheap aftermarket components at the PO's request.
I have recently over hauled the engine with OG carb, distributor, fuel pump, tin, and fan shroud. not long after the install of all the new pieces, the belt came of the pulley. the belt had turned around and the teeth were facing out. during the install of the parts it was noted that the chrome alternator pulley was slightly warped and a new one was purchased. i decided to install a new belt and pulley thinking this may be the problem.
I installed the new belt from the info learned earlier in thread. I had to use 12 shims in the middle to even get the belt to move the pulleys. Once installed, i ran engine for a minute to see how it looked. I then touched the pulleys and belt and they were very hot. I assume due to improper belt installation. but looking into it, i may have bigger issues than the belt.
It appears with the belt off that the pulleys are not in align, they look better with the belt on but still not lined up correctly.
looks like if am off to a different thread.
Thanks for all the input from all. _________________ '71 Westy
Posted: Thu Oct 03, 2019 9:38 pm Post subject: Re: Installing Alternator Belt - Need Help? |
I’ll guess you have the wrong parts in the shroud, forward of the alternator.
The pulleys have to align or the belt will either flip off or wear prematurely
Y _________________ .ssS! |
SGKent Samba Member
Posted: Thu Oct 03, 2019 9:47 pm Post subject: Re: Installing Alternator Belt - Need Help? |
I think you may have hinted that you changed the fan shroud. The original 1971 engine had a 38 amp generator. Earlier buses had a 30 amp. The 38 amp pulley is different I believe, and the fan backing plate sits deeper. A mis-alignment because of the parts may be playing into this if the shroud was changed. My suggestion is work with someone who has been thru a fan shroud changed, and who knows what parts work together. I can see that the belt is offset and that is probably causing it to roll. Talk with any of the early bay guys on this. I'd start with Robbie ( Asiab3 ) _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12721 Location: on a bike ride somewhere
Posted: Fri Oct 04, 2019 1:51 pm Post subject: Re: Installing Alternator Belt - Need Help? |
Thanks for the shoutout Steve I was actually supervising AhnwS71 with the shroud, tin, and oil cooler swap, and engine installation. I remember sighting the belt alignment and not seeing any flagrant issues. He has the correct backing plate, pulley, and fan/hub parts for his new doghouse cooling system, complete with Hoover Bit, and stepped oil cooler seals with proper washer distribution. We dotted our I’s, crossed our T’s, and umlauted our.... umlauts?
We did notice the chrome pulleys on hand had visible radial and axial runout when spin by hand. I don’t need my micrometer to know trash when I see it.
When installing a new belt OR pulley on a Type 1 engine, start with all your shims inside the pulley halves, no exceptions. This makes the belt as loose as possible and ensures the pulley halves can sit down flush. If too loose, remove one shim (stick it under the special pulley washer on the outside!) and try again. I can’t overstate the importance of alt/gen pulley seating enough, and the biggest mistake during installation is pinching the belt before the pulley halves are fully seated.
Do you remember during our work day when we installed the belt and debated shim movement, where we let the pulley spin a few times during tightening? This ensures the pulley halves are mating symmetrically, as the belt won’t bind up in one spot. That’s what your new pulley pictures look like to me.
Another problem I have witnessed with almost every new aftermarket pulley, is that the metal isn’t not stamped symmetrically. Take each pulley half and lay them large side down on flat glass, (a clean rear window works in a pinch.) There should be NO knocking, clicking, or rocking. Most pulleys stamped with a “Made in Germany” (but in Russian) stamping are out of round, probably from excessively pressure, or stamping without supporting properly.
If it passes this test, and many don’t, install it with a properly and thoroughly adjusted belt, warm up the engine until it’s idles smoothly, and sight down the pulleys, keeping dangly hair, clothes, or jewelry out of the skinny bits! Are the pulleys perfectly parallel with each other? Or is the belt making a jog front to back?
I wager your new pulley wouldn’t make it past the unpaid intern inspection for the Rocket City Trash Pandas.
www.airschooled.com |
SGKent Samba Member
Posted: Fri Oct 04, 2019 5:55 pm Post subject: Re: Installing Alternator Belt - Need Help? |
maybe it is just the angle but something looks cocked in the photo and the belt looks distorted at the top to me. The exterior part of the pulley looks caddywhompus to me too. Maybe it is a warped pulley.
Posted: Fri Oct 04, 2019 6:36 pm Post subject: Re: Installing Alternator Belt - Need Help? |
SGKent wrote: |
I had noticed that the upper pulley didn't seem to be fully seated. Either he doesn't have enough shims, or the belt is too short or too wide.
Just went through getting the right belt for my Toyota truck. Tried several belts from a local FLAPS, but none seemed quite right, so got a belt from the dealer and it was a perfect fit. |
Posted: Sat Oct 05, 2019 11:04 am Post subject: Re: Installing Alternator Belt - Need Help? |
update: took engine out to see it better. installed belt and it appears to be off by a small bit. i placed the new pulley parts against glass with the outside of the pulley touching the glass. no movement on one and barely any one the other. Pulley seems ok.
https://www.youtube.com/watch?v=SFDLjiQrUzk
see what happened to the old belt
Posted: Sat Oct 05, 2019 11:42 am Post subject: Re: Installing Alternator Belt - Need Help? |
Your upper pulley just doesn't look right and the belt is running way too far down in the pulley. Put a paint mark on the nut and pulley, back the nut off counting the turns and then remove the belt. Now turn the nut back in the same number of turns you counted until the paint marks align. Are the two pulley halves now bound tightly to each other as they should be? |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51125 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sat Oct 05, 2019 11:45 am Post subject: Re: Installing Alternator Belt - Need Help? |
Looks like the belt is way too short from here.
Why is your vacuum advance port on the distributor capped off? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
