Base paint in liter
Matt Wilson
Matt Wilson is offline
PostPosted: Fri Mar 31, 2023 7:16 pm    Post subject: Re: Base paint in liter Reply with quote
I've usually had pretty good luck with 1 gal (~4L). It doesn't hurt to have extra. If you are using a catalyzed paint, of course the catalyst will increase the volume.
If you are using a darker color, sometimes you can have the paint shops tint the primer for you, for better color coverage over the primer.
1972 Standard Beetle
1969 Baja Beetle
Amzoch
Amzoch is offline
PostPosted: Wed Mar 29, 2023 2:30 am    Post subject: Base paint in liter Reply with quote
Hi, how many liter did you use to paint the base on the bug? Outside and inside (that you can see)
