Tube vs Tubeless tire pressure
Forum Index -> Custom Wheel/Tire Share: Facebook Twitter
rcroane Premium Member
rcroane is offline
PostPosted: Fri Apr 07, 2023 6:41 am    Post subject: Tube vs Tubeless tire pressure Reply with quote
I'm finally mounting new tires on my '65 bug (the current tires are dated 1988!). Going from tubes to tubeless. Can I still run the same pressure I've been running (20 front and 28 rear)?
Thanks.
'65 Sunroof Bug
scottyrocks
scottyrocks is offline
PostPosted: Fri Apr 07, 2023 7:48 am    Post subject: Re: Tube vs Tubeless tire pressure Reply with quote
Yes.
– D. Tartt, 'The Goldfinch'
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Fri Apr 07, 2023 7:50 am    Post subject: Re: Tube vs Tubeless tire pressure Reply with quote
35 years old... surprised they still hold air.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
rcroane is offline
PostPosted: Fri Apr 07, 2023 8:15 am    Post subject: Re: Tube vs Tubeless tire pressure Reply with quote
Me too. Actually, it's only the spare that has a tube. It has a 4 digit date code of 1988 (Pirelli). The other 4 are Dunlop tubeless with a 3 digit date code of 458, so technically I think they could be 1978 or 1988. New tires are Vredstein Sprint Classic. I'm going with 155's vs 165's that are on the car now.
'65 Sunroof Bug
Jimmys 65
Jimmys 65 is offline
PostPosted: Tue Apr 29, 2025 6:07 am    Post subject: Re: Tube vs Tubeless tire pressure Reply with quote
How do you like the smaller 155’s and what air pressure are you running?
Bruce
Bruce is offline
PostPosted: Tue Apr 29, 2025 4:49 pm    Post subject: Re: Tube vs Tubeless tire pressure Reply with quote
Tires manufactured in the 80s used a 3 digit date code, so your tire is much newer than 1988.
Reply to topic    Forum Index -> Custom Wheel/Tire All times are Mountain Standard Time/Pacific Daylight Savings Time
