Clatter Samba Member
Joined: September 24, 2003 Posts: 7549 Location: Santa Cruz
Posted: Tue Apr 25, 2023 7:39 am Post subject: Re: A Type 4 in 2023 - Rob's Motor Build |
Had a big day out in the shop yesterday!
Took the P&L apart, rings off and everything wiped down.
First thing to do is make sure we didn't get a bad set.
'Bout half a thou variation in different ways.
Mostly between sets, some barrels were a little bigger at the bottom.
Not bad, really.
Better than some AA sets we've had.
We'll keep 'em.
Went ahead and engraved numbers in everything to keep track.
4 1/2 or so is a bit on the loose side,
But since we have a bus here, I'm not upset.
No need to break-in gently.. Run it hard!
Still,
I fell it's worth it to touch off with a hone.
Just a few seconds with 240, and then 600.
Different directions, and wiped down clean between.
Cleaned up in the sink with hot soapy water and a worn-out Scotch-Brite.
Even still, a paper towel after with some WD-40 to stop rust shows grit.
Can't help but think the iron used is just dirty...
Blowing it dry, sand kept coming out between fins.
Chased a bunch of it out with a skinny pick.
Cleaning out pistons, and especially inside the pins,
They balanced exactly the same.
Within a gram right from the factory...!
Pretty cool. Never seen that before.
P&L all cleaned up and bagged and boxed and ready to go.
Moved on to rods.
We'll skip right to the finish, as i showed all this in the Cheap Junk build.
Balanced end-to-end, "bulletin" oil spray grooves, big end smoothed out, wrist pin oil holes opened up.
Plus, all deburred, especially at the parting line, and clean cleaned.
A whole day of stuff that doesn't need done.
"You don't need to do all that, it'll run fine without it".
_________________ Bus Motor Build
What’s That Noise?!? |
Cdn17Sport6MT Samba Member
Joined: April 02, 2023 Posts: 74 Location: Vancouver, BC Canada
Posted: Tue Apr 25, 2023 8:01 am Post subject: Re: A Type 4 in 2023 - Rob's Motor Build |
Superseded...
Last edited by Cdn17Sport6MT on Tue Apr 25, 2023 8:03 am; edited 1 time in total |
Posted: Tue Apr 25, 2023 8:02 am Post subject: Re: A Type 4 in 2023 - Rob's Motor Build |
@Clatter, you make reference to iron when you do a final pass with WD40 and a rag/shop paper towel... Obviously those are cast iron (stock) barrels. Do folks ever think about using aluminum/Nikasil barrels? |
SGKent Samba Member
Posted: Tue Apr 25, 2023 8:51 am Post subject: Re: A Type 4 in 2023 - Rob's Motor Build |
Steve - there should be a fine mark where the Sunnen measuring device measured the bearing size. It will be about 1/8" or so inside from each edge and be circular. Make sure it goes all the way to the part line and crosses it. Sometimes a machinist with the best intentions doesn't do that and the rod can be pinched. The cap only needs to be offset .0005" to have a .001" pinch. It can only be picked up by measuring both sides as one passes over the part line. I resized thousands of rods for a living once, it is the most common mistake made and easy to to. I looked for the scribe mark but could not see it in this photo. It will be really faint but there. The second photo shows how a cap can be a tiny bit off when honed. One side (arrow) can be wider than the other if the cap is pinched,
This is probably something like what the machinist measured with. The arrow points to the small piece that would have left the a line like a scribe line. I don't know what else to call it.
_________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Tue Apr 25, 2023 11:39 am Post subject: Re: A Type 4 in 2023 - Rob's Motor Build |
Cdn17Sport6MT wrote: |
Sure.
100s would be fine in a true Nicasil.
https://lnengineering.com/type-4-store/type4store-...sters.html
Birals are available from China.
They say you can get away with 96s in a bus application.
https://aapistons.com/collections/porsche-piston-c...linder-set
It's generally accepted that when running iron cylinders in a bus application,
That 94 is the biggest you would want to run.
96s with iron jugs are reported to give blowby from reduced finnage.
LN sells forged 94.5 pistons for bus use if you have a set of OG iron 94s to have honed oversize.
Otherwise, they sell you Nickies.
The AA/Mahle (same thing) don't meet their quality standards.
When running a set of China 94s like we have here,
I'm measuring them carefully to make sure we didn't get (another) bad set.
Refinishing the cylinders with a proper plateau hone,
And usually getting some proper Grant or preferably Hastings rings.
Even so, sealing on the AA China 94s isn't always that great.
I'm holding off on getting rings for Rob's bus motor here until i mock up.
If the dished AA bus pistons don't give enough compression,
I have a nice set of US-spec 914 94 pistons available with a smaller dish.
914 and bus pistons use different ring packs.
Have to do the measurements/math to be sure.
1.8 heads have larger chambers than bus heads.
Getting the case off for a tanking this afternoon,
Then things will be clean enough for a first trial assembly to get a lay of the land, so to speak.. _________________ Bus Motor Build
Posted: Tue Apr 25, 2023 11:46 am Post subject: Re: A Type 4 in 2023 - Rob's Motor Build |
SGKent wrote: |
Thanks for the tip.
I'd be surprised if there was any cap shift with these.
Rod bolts are splined tightly to the cap.
You could feel a half-thou or less with a fingernail.
Jim had two Sunnen rod hones at this shop not too long ago.
He's got this for sure.
Probably some extra care on his part that measuring didn't leave visual evidence. _________________ Bus Motor Build
SGKent Samba Member
Posted: Tue Apr 25, 2023 12:11 pm Post subject: Re: A Type 4 in 2023 - Rob's Motor Build |
steve - my buddy had Msc Tilton build him two engines for the SCCA Road Atlanta finals years ago. Mac was building Pail Newman's winning SCCA engines that took him to a championship. The first engine half spun a bearing on lap two in practice and bent the rod severely. A couple more revs and the engine would have been full of air holes. Leland felt the power going away and killed it just in time. Mac and several other extremely well known engine builders looked over the rod, crank etc., for a couple hours and could not find the flaw that caused it. Bill was at Road Atlanta for one of the big buck teams so I went and borrowed him. It took Bill about 20 seconds to spot the cause. Just because the rod is perfect in size over 90% of it does not mean that the other 10% is dead on. Trust me, I have done many rods that took a second time because the variation was too great to do in one honing. The reason Bill spotted the cause was that the scribe marks did not go 360 degrees. I personally won't accept a rod that has been resized unless the scribe lines left by the gauge go 360 degrees. I had to teach the guy who did RIMCO's rods that 15 years ago. What you will normally see is that the measurement is a little wider at the part line. That is Ok. But if either side is narrower it is not Ok. Human hands and wrists don't wind 360 degrees so it takes some wind up in the shoulder and arm to be able to do a 360 measurement without jiggling the gauge. The point is, it only take 5 seconds a rod to see if the scribe lines go 360. If not have the guy checK them. 95% of the time they will be fine. The other 5% will be glad we caught these. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Mon May 01, 2023 11:15 am Post subject: Re: A Type 4 in 2023 - Rob's Motor Build |
Got a little time yesterday..
Detailing out the case a bit before it goes to vapor blast.
Big flappy casting flash on top of case where it shows.
Also factory black sealant that doesn't come off in the tank.
Using a bigger fine-tooth burr for the initial.
Finish up details with small super-fine burr.
You could chase this stuff forever - clear to polishing the whole case.
Near the top is my bigger burring and it's tooth marks that chased a big parting line,
But below that, you can see some factory work.
They obviously used a coarse 5 or 7-flute bit,
And just skimmed off the flash.
Still,
Crazy to think that they did this much hand work BITD.
My hand cramps enough in an hour or two.
Imagine doing it all day...!
Pretty cool the 'overtemp fallout coin warranty validator' thingie a past rebuilder put on.
Good sign the center hadn't fallen off already, right?
Case had two of them, and they're staying.
Another way to verify overheating is always welcome, eh?
Plenty of flash between fins on the bottom of the sump,
But,
Really,
Comes a point.
Who's going to be crawling underneath a bus looking at how finely the sump fins are detailed?
Still,
Cleaned up some dings from road debris, or a sloppy engine pull years ago,
Should be worthy of a blasting now! _________________ Bus Motor Build
tricyclerob Samba Member
Posted: Mon May 01, 2023 12:24 pm Post subject: Re: A Type 4 in 2023 - Rob's Motor Build |
Rob here.
Case looks great! Biggest concern was really the top of the case that shows and that cleaned up nicely. Thanks Steve!
Like my second grade teacher said, "neatness counts!"
Collaborating on an engine build from the left coast to the right coast is interesting. Lots of text messaging!
I've been doing cars, boats, motorcycles, etc for 60 years and know a bit about a lot of things but VW internals is not one of them.
Steve has been providing a real education in that regard. [I have a lot to learn]
But, I haven't been sitting on my hands. Chasing parts and welding, repairing and fitting tin, [on my old motor]
I did find a company in the Netherlands that has a lot of the hard to find rubber bits, as well as engine tin by the piece. Shipping is a little more but if you can't find it anywhere else...
https://bus-ok.nl
One week shipping. Not bad.
Steve suggested removing the air pump bosses on the fan housing.
Another great idea.
What goes where? Diassembled 15 years ago. Way too many projects.
Fan housing off to vapor blasting.
Although Steve is doing all the heavy lifting at least I can contribute something...
robj
Posted: Mon May 01, 2023 12:35 pm Post subject: Re: A Type 4 in 2023 - Rob's Motor Build |
Nice!
Motor's gonna look sweet.
We were discussing finishes.
Rob's bus is orange.
I think painting all of his tins to match would look tidy.
Orange tins.. Blasted fan shroud.. With shiny socket head cap screws...
What y'all Think? _________________ Bus Motor Build
Posted: Tue May 02, 2023 11:38 pm Post subject: Re: A Type 4 in 2023 - Rob's Motor Build |
Clatter wrote: |
Nice!
What y'all Think? |
So, Steve had to mention shiny screws...
Hi, I'm Rob and I'm a nutandboltaholic...
I think I was scarred as a young-un, digging through nasty buckets of nuts and bolts saved by my father and grandfather looking for the right one for my '57 Chevy, [Back when it was just a used car].
I eventually figured out for not much more than a blister pack of 5, [so you had to buy another pack to get 6] I could buy a box of 25 or 50 from McMaster-Carr. So we ended up here;
I have to say it's super nice to have "most" of what you need. But I need little excuse to add to it.
Steve mentioned socket head cap screws. I've used them a lot but...
The choices are;
Far left; Socket head cap screw.
Next; Button head hex drive screw. [probably my second choice as it's similar to the OEM in appearance].
Third; Cad. plated blister pack OEM type screws. [AKA Cheese head screw]
Fourth; S.S. Cheese head. [I personally like the S.S. Cheese Head as it's kinda like OEM but not, as in "shiny"]
Next;
6mm flat washer,
6mm Wave[lock] washer [what the parts book mostly called for]
And my new favorite for tin, 6mm S.S Conical [lock] washer
As you can see, the conical washer is slightly larger in OD[14mm] and slightly smaller in ID [6.4mm] so it covers all of the "slotted" holes in the tin, unlike the OEM flat, or the OEM wave washer.
Plus, the conical shape spreads the locking load around the entire washer. Basically it's like a very flat "cone" that depresses slightly when tightened putting pressure on the screw head preventing it from loosening. In order to support that load it's also thicker. Tighten the screw to "snug" and the torque required to loosen it is noteworthy!
I really like it for this application.
https://www.mcmaster.com/catalog/129/3638/93237A105
OEM Wave washer on the left, conical on the right.
I'm also considering some "flange head locking nuts" but the OD of the flange is slightly larger then the flat on the fan shroud so I'm a little undecided. [I did get some "flange head locking bolts-this was what I meant about the fan shroud-the locking flange on the bolt is a little larger -sorry, it's late...]
I did get some 8mm conical washers in case I want to go that way.
Oh, they also come in black.
And keep in mind, S.S. to S.S. or S.S. to aluminum you HAVE to use anti-seize.
The best I've found from dealing with the "sailboat people" is this;
Somewhat expensive but a tiny bit goes a long way and it's never failed me. This is a "tub" I bought for Steve as a gift for putting up with all my questions.
So, 2.75 beers later, Cheese head screws and conical washers, all polished up.
And yes, we are going with tin matching the body color, although some of the misc. brackets etc..will be black.
A brief interlude.
I'm sure more than you ever wanted to know and you can't wait for Steve to return with more"engine"... [I have to keep busy doing something.]
robj |
RWK Samba Member
Posted: Wed May 03, 2023 6:43 am Post subject: Re: A Type 4 in 2023 - Rob's Motor Build |
Nice build! I use these flange head screws now for tin and other 6mm applications, tired of fighting old stripped out slotted head screws
Also for case cleaning try ultrasonic, they are more common now,
pics are of 2 cases, used and one cleaned in ultrasonic, notice it did not take off all the sealant, second dip will remove it I was told. I removed some of the galley plugs prior, looks very clean inside now.
_________________ 73 Type 181
63 Type 113
63 Type 261- 428 071
62 Type 241-378 025 178 530 |
Abscate Samba Member
Posted: Wed May 03, 2023 8:04 am Post subject: Re: A Type 4 in 2023 - Rob's Motor Build |
You are a serious boltaholic when you know the exact number to order where the picker loses patience and just throws in another 50 pack on your order instead of counting it out
_________________ .ssS! |
Posted: Wed May 03, 2023 8:41 am Post subject: Re: A Type 4 in 2023 - Rob's Motor Build |
Nice post Rob..
SHCS are nice for all of the fasteners that hold the halves of the fan shroud together.
Fan shroud rarely comes apart, and the recesses are perfect.
They’re so front/center..
It’s also satisfying to get all of the shoulders the right length in the different locations.
As for tin screws,
Stainless with separate washers can give you fits.
Because some of the tin needs added after the motor gets stabbed,
You’ll be doing screws way back in a cramped compartment even in an ideal situation.
If ever you end up having to pull tins later for any kind of work,
Fasteners will get dropped.
Little nooks/crannies will eat them.
Stainless won’t allow the use of a magnet to retrieve.
And separate washers? Ugh.
Those things find places to wedge and hide forevermore.
They find tin seams as if by magic.
I’m too anal to have a loose washer somewhere in the compartment location unknown.
I’ll offer that those Germans were right clever in their cheesehead-with-attached-washer design.
It’s damn practical.
I’ll admit to having polished stainless button-heads on a motor or two,
But the foul language they generate can definitely alarm neighbors,
Even a half mile away. _________________ Bus Motor Build
Posted: Wed May 10, 2023 10:34 pm Post subject: Re: A Type 4 in 2023 - Rob's Motor Build |
Rob here.
While Steve's been busy dealing with engine parts, I've been searching out all the missing bits and pieces of my tin, and all the rubber bits to seal it up. Also searching out heating system parts, all of which were MIA on my Westy.
But back to the screws for the tin for a moment. I took Steve's comment about loosing washers to heart, but I really wanted to use the larger conical washers and the stainless screws. [stubborn AND persistent...]
I pondered a solution and came up with small silicone washers that would go under the lock washers to prevent them from coming off the screw and yet not interfere with the washers locking action. I bought 4mm and 5mm and I think the 4 may interfere less with the locking action of the washers, but either will probably work fine. [And seal the holes].
I can't do much about them not being magnetic but at least if they're dropped I'm not just looking for a washer...
I did pick up the fan housing from Vapor Blasting. To be honest although very clean and very smooth, [much smoother than glass bead dust left them] they didn't look quite as nice as some MC engine cases I've had done. I think the castings are a little more porous and the magnesium content may have been a factor.
Now trying to decide what to coat them with. Probably Sharkhide Aluminum Protectant from Eastwood. Very pricy, [$72 a quart] but I have some from another project. Frame rails on an aluminum boat trailer. It was crusty and I DA'ed the entire thing, [with a nice pattern]. Used Sharkhide on it and it's still looking good 7 years later.
I never realized how many bits it took to properly seal the engine tin. I actually have an OEM paper parts book and I have to say having part numbers really helps when searching stuff out.
Bits;
And more bits;
Many of the rubber parts, [and some metal parts] just didn't appear to be available in the US. I found 2 sites, one in the Netherlands and one in Germany that really seemed to have some items impossible to find in the states.
One, "Bus-ok.nl" in the Neatherlands had many hard to find parts but the shipping was a little high. But, parts I couldn't find elsewhere. [shipping was a week-10 days] They had the Heat Exchanger Air inlet cover plates -[missing on mine] They also had new tin parts!
https://bus-ok.nl
The other in Bargteheide, Germany also had a good selection and their shipping was quite a bit less. [they had the gasket for the heat exchanger cover plates]
https://www.csp-shop.com/en/
One last thing. Scored a like new VDO Cylinder head Temp gauge and kit off eBay. Appears they are NLA.
Also ordered some of the correct orange paint for the tin, so that decision has been made.
All in all some good parts hunting.
robj |
Posted: Thu May 11, 2023 8:21 am Post subject: Re: A Type 4 in 2023 - Rob's Motor Build |
Yeahman!
All about the details..
Stuff's been going on in the background,.
Crank came back from Ed's a couple weeks ago,
Jim caught that the rod journals were several tenths over spec.
Been fun to see how my measurements compare to two pro machinists.
Robert at Schroeder's in Seaside was going to be doing a spin balance of the lower end.
Check out his balancer.
Winona's got herself a big brown beaver and she shows it off to all her friends..
Funny, i used to not include the key,
Because I never guessed that the balancer was picking up anything that small and close to center.
Robert schooled me that he has to compensate for the keyway doing his balancing,
So now i stab the gear and key.
Robert also has a polisher,
So he can take a thou or so off the rod journals.
He also wasn't impressed with the finish.
So he'll polish the whole thing.
Sucks that it takes four day-trips across the bay area to get a crank right,
But it takes what it takes these days.. _________________ Bus Motor Build
Posted: Thu May 11, 2023 8:47 am Post subject: Re: A Type 4 in 2023 - Rob's Motor Build |
Case got tanked here locally and then off to vapor blast.
The guy "did us a favor" by dousing it in some kind of preservative oil.
So now it's back off to another tanking.
And the guy gets me for another $100!
Takes what it takes, right? _________________ Bus Motor Build
Posted: Thu May 11, 2023 9:05 am Post subject: Re: A Type 4 in 2023 - Rob's Motor Build |
Rob got a set of new Dansk '72-'74 heater boxes and sent them to Jet Hot.
They showed up in a huge box wrapped in piles of paper..
Couple of little dings and scuffs, but pretty nice.
They'll get more.
They're heater boxes after all...
These are known for having a more crudely-cast heat sink.
Also didn't see any insulation.
Let's hope that coating doesn't off gas.
Here's factory for comparison.
Misalignment at the flange kind of sucks.
I'll get in there with a stone or burr on a long shank and try to blend off this shelf.
Should be OK.
Here's what i was really worrind about..
Do they fit the heads?
Factory boxes aren't the best in this department to be sure.
Stoked to see the fit is spot-on.
Gasket flange is slightly smaller than port,
A little blending and gasket-match should suss this right out.
All in all,
These look workable at this point.
There's a risk associated with coating these things before they've been fit.
Especially with aftermarket parts.
While it remains to be seen how they fit the other tins, fan shroud, etc.
So far so good.
May major worry of head fitment is a non-issue.
Long as Rob doesn't need top heat on the coldest of days,
I'm thinking these might just do the trick. _________________ Bus Motor Build
Posted: Wed May 31, 2023 4:51 pm Post subject: Re: A Type 4 in 2023 - Rob's Motor Build |
Still waiting on the crank guy to finish up balance and polish..
Spent a bit of time looking at heads.
AMC heads supposedly have issues with casting flash blocking airflow through cooling fins.
Got a set of factory heads out to compare.
Factory OEM on left, AMC on the right.
They're damn close far as i can tell...
AMC might have fewer tiny cooling passages right above the exhaust port.
Factory heads have a couple more little cooling air passages.
AMC might be a little better above the plug by the intake.
Vs. factory:
Maybe the reports of bad flash are from newer generations of AMC heads?
Perhaps it's the AA heads with this issue?
New CB intake manifolds are -luckily- smaller than the ports.
Dychem and scribing for some port-matching.
Sharp eyes will notice they also got scribed with cylinder numbers to keep them together once matched.
Can't help but move on to ports.
Dag, the factory bowl cut is shallow,
And castings are off.
This will be flattened/blended once the die-grinder comes out.
Unshrouding on the exhaust side will help.
Pretty crowded by the chamber..
Got this old exhaust valve ground down so it sits low in the seat.
Gives room for me to unshroud, as well as chase that sharp edge left from the seat cut.
Once i go ahead and commit to spending a day all covered in ATF and chips,
We'll get these heads on their way.
Until then, good to get a game plan going... _________________ Bus Motor Build
Posted: Thu Jun 01, 2023 9:34 pm Post subject: Re: A Type 4 in 2023 - Rob's Motor Build |
Good day today..
Crank back from balancing and polish.
Put another cleanup on.
This brush assortment came from HF.
Started intake ports.
Knocked down that fat ridge at the edge of the bowl hog cut.
Smoothed out with the smaller burr.
Pretty stoked on these castings.
Often core shift will leave the seat sticking into the port.
Not the case here.
Matched manifolds.
Didn't need much.
Left the manifolds slightly smaller than the ports.
Studs are a bit big/loose in the manifold holes.
No matter how they end up shifted over,
There won't be a 'step' sticking into the flow.
Couldn't help but detail mani speed holes.
Surfacing on the plate.
Always interesting how they clean up.
Wonder what makes this 'concavity' on the mounting surface?
Material relaxes over time?
Cut while still hot?
Cruised the whole port to give an even finish.
Also took out rough parting line.
Didn't open it up, just straightened it out.
Intakes are all done.
Pretty stoked how they came out. _________________ Bus Motor Build
