Lowlightmafia Samba Member
Posted: Wed Apr 12, 2023 1:47 am Post subject: Okrasa 36hp distributor options |
Hi, I’m finally having a 36hp engine built to get around from show to show and some longer distance drives with better power while being mildly quite. Have all the parts ready to build but want some advice on the distributor.
Simple build
WW 69 crank
WW high performance cam
WW okrasa heads (stock compression)
Dual 32 zenith carbs
GB sump
All balanced
The rest is bone stock
Going into a stock lowlight vert
I have an 010, 022, and 019 distributor. Wanted to find out the pros and cons of each distributor for this build?
Also would it be worth looking into a magneto or is it not worth it from a performance/ regular driving standpoint compared to the above distributors? |
Joined: June 24, 2015 Posts: 719 Location: Rialto. CA
Posted: Wed Apr 12, 2023 11:34 am Post subject: Re: Okrasa 36hp distributor options |
Lowlightmafia wrote: |
Simple build
WW 69 crank
GB sump
All balanced
022 has 32* advance to much for that build some may say its not a street type distributor more of a racing type ..o22 is a porsche 356 distributor with semi hemi heads /40mm big valves ...so forsure thats not the one for your build ...your more in the 019 |
PeteSC Samba Member
Posted: Thu Apr 13, 2023 5:37 am Post subject: Re: Okrasa 36hp distributor options |
Simple build
WW 69 crank
GB sump
All balanced
I had an 019 when I first built my engine; it was ok, but the engine performs much better with an 010. The 019 hits it's max advance at a higher RPM than the 010, which I expect hinders its performance. I believe the 019 isn't at max advance until 3200 rpms or so, compared to around 2600 for the 019. I have no experience with an 022 so I can't comment.
There are a few who have dyno tested their Okrasa 36'ers whil comparing distributors, and at the risk of suggesting such sacrilege....the best results were with an 009. |
Bub Samba Member
Joined: June 10, 2004 Posts: 1155 Location: Central Washington
Posted: Thu Apr 13, 2023 8:07 am Post subject: Re: Okrasa 36hp distributor options |
Simple build
WW 69 crank
GB sump
All balanced
I've tried all three of those and found the 010/BR25 to run the best. Could just have been bad parts, but put an ignitor module inside that distributor and it's even better. In my case I got way hotter more reliable spark, timing was even more steady- and I'm not one to recommend those types of things. _________________
hitest wrote: |
Had a girlfriend once who shall we say, nearly arrived at the mere sight of a semaphore in action- easy to please she was... |
Vedderism Samba Member
Joined: October 02, 2020 Posts: 28 Location: Paramount
Posted: Fri Apr 14, 2023 8:49 am Post subject: Re: Okrasa 36hp distributor options |
I daily drive a bone stock 1200 with the WW Okrasa kit on a 010. Runs perfectly fine with no issues. |
esde Samba Member
Joined: October 20, 2007 Posts: 5969 Location: central rust belt
Posted: Fri Apr 14, 2023 9:11 am Post subject: Re: Okrasa 36hp distributor options |
All that investment and staying with 6.6:1 compression? I think the bump in compression is possibly the cheapest power increase you'll get.
Do the zeniths have a vacuum port? If so you could try the vjur4 br8, which is basically an 019 mechanically with an adjustable vacuum advance can. I've had the idea to swap 010 guts into one, which would make an 010 with adjustable vacuum advance. In my spare, spare time someday.. _________________ modok wrote:
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76949 Location: Sneaking up behind you
Posted: Fri Apr 14, 2023 10:11 am Post subject: Re: Okrasa 36hp distributor options |
esde wrote: |
I've had thew idea to swap 010 guys into one, which would make an 010 with adjustable vacuum advance. In my spare, spare time someday.. |
Won't work, the upper part with the cam and springs, which the rotor sits on is longer on a vju4br8 than a 019 or 010.
010/VJ4BR25 (left) 019/VJ4BR8 (center) VJU4BR8 (right)
_________________ Glenn
Member #1009
#BlueSquare |
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7221 Location: Videbaek Denmark
Posted: Sat Apr 15, 2023 2:54 am Post subject: Re: Okrasa 36hp distributor options |
On a 30/36 hp or even a 1286 cc Okrasa engine there can be some truth to the 010 works ok. Reason is the hemi ish combustion chamber which wants relatively high advance in spite of the small bore. On a newer type 1 it is not so. If a 010 makes a normal set up type 1 engine run better than a 009 or 019 something is definitely wrong. Again, if the engine has been cut for semi hemi chamber shape the 010 can sort of come back to be the choice.
I accept and agree that the old school way of doing it is to slap a mechanical only distributor on these engines when the get converted to dual carbs. That said, Esde has a point in his way of thinking. Problem is, the way he wants to do it is,,, complicated. The better way is to use the BR8 distributor "as is". I do not remember exactly how it is laid ou inside, it has been a while, but reducing the mecanical advance curve 3-4 degrees and loosening the initial advance a little can make for a huge change in power pick up. I did this to a German customers 1385 cc Okrasa and it picked up 4 hp!!! @ 2500 rpm.
Wrt the vacum take off. - On the PBI/PCI/PBIC carbs there is a casting on the "accelleration pump side" of the body which can relatively easy be drilled out so you can have ported vacum to the can. Start out with a small drill, like say a 1,5 mm. and see where the hole comes out in relation to the butterfly. Then you can enlarge the hole in the direction you want/need for you to get the signal you want. When doing ported vacum the idea is to not have a vacum signal until 1250-1300 rpm. Some people want an even higher switch point, but I find that 1250-1300 is fine and it can also help a lot in throttle response from lower rpms.
Once you get the signal strength and in the area you want you can fine tune the actual advance with the adjuster on the distributor. _________________ https://www.thesamba.com/vw/forum/viewtopic.php?t=435993 |
Posted: Fri Apr 21, 2023 5:41 pm Post subject: Re: Okrasa 36hp distributor options |
Thank you everyone for the advise. I prefer not to use a vacuum canister as iv had problems in the past on stock 36hp builds. Iv been using an 022 on a stock 36hp with ww heads/ww dual carbs and it runs alright for what it is. So this build will be cam, crank plus heads to give some power with smooth cruising. The reason for the zeniths and cast dizzy is purely for the aesthetic of the engine. It seems like the unanimous decision is to go with a 010 dizzy and im going to use that.
With that said I am talking with a mad scientist at blackline racing to build something that will push the envelope of the 36 for a 59 hard top ghia. Should be a fun project after I finish this easy one. |
