scarruth Samba Member
Joined: October 07, 2021 Posts: 12 Location: Redondo Beach
Posted: Sat Apr 15, 2023 3:30 pm Post subject: Seat lock lever tensioner spring |
Noticed my seat lock lever not working and on inspection I discovered the tensioner spring had broken. Can’t seem to find in the classified or online air cooled parts stores. The parts manual says part number is 113 881 243. Looking for advice.
carsdlt Samba Member
Joined: May 02, 2012 Posts: 317 Location: So. OC, Calif.
Posted: Sat Apr 15, 2023 9:06 pm Post subject: Re: Seat lock lever tensioner spring |
The Thing Shop? I think that's where I got mine. _________________ Thanx, DLT
'73 181 stock 1600 - "Dr. Bombay"
"If it works, don't fix it....let it break on its own." |
Posted: Sat Apr 15, 2023 9:07 pm Post subject: Re: Seat lock lever tensioner spring |
Posted: Sat Apr 15, 2023 9:50 pm Post subject: Re: Seat lock lever tensioner spring |
Unfortunately the Thing Shop only has 113881245B, which is the big spring that tensions the entire seat assembly so it slides forward in the rail. This spring is on the lever. |
Semper_Dad Samba Member
Posted: Sun Apr 16, 2023 6:49 am Post subject: Re: Seat lock lever tensioner spring |
Being the part number starts with "113", you can probably find a donor from an older (pre 1973) Beetle. _________________ Walküre Restoration Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=737492 |
Posted: Sun Apr 16, 2023 9:39 am Post subject: Re: Seat lock lever tensioner spring |
Thanks Semper Dad. Was rapidly coming to that conclusion as well. Let the search begin! |
FJBLF Samba Member
Posted: Mon Apr 17, 2023 7:17 pm Post subject: Re: Seat lock lever tensioner spring |
Your local Ace Hardware has a huge selection of springs available on the specialty hardware section. I'm positive you can find one that works just fine. _________________ 1972 VW 181 SAFARI 1500 cc GRB Trans-axle |
