RCJH77 Samba Member
Joined: March 27, 2022 Posts: 186 Location: Johnson County, KS
Posted: Thu Apr 20, 2023 3:07 pm Post subject: 1960 Beetle - Tire Setup (drums, drops, original wheels) |
I don't even want to be asking a tire size question, but...I have to. Sorry.
Here's the context. I'm sending my original wheels off to be repainted. They currently have 165/80R15's on them. I'm about 80% sure I'm going to install 2.5" drop spindles before the wheels come back. I would prefer it if all four tires were the same size, but I know I'll need to go down in width and aspect ratio to avoid fender rubbing on the front.
So my question is, would it be crazy (or look weird) to use the same size tires on the front and back, or do I just need to deal with having two different sizes? Alternatively, should I skip the drop spindles and go with a narrowed adjustable beam? (Will that accomplish the same thing?)
I know most people who install drop spindles go with a little, narrow tire up front and big wide tires on the back, but I'm trying to keep my bug looking as stock/original as possible, but with a raked profile.
Example of the look I'm going for:
6T5 square Samba Member
Joined: September 15, 2005 Posts: 1083 Location: Dover, DE
Posted: Fri Apr 21, 2023 5:17 am Post subject: Re: 1960 Beetle - Tire Setup (drums, drops, original wheels) |
185/65 15's on all 4. 1960 beetle- 4" narrowed beam, 2 1/2" dropped spindles, no rake- level drop. One notch outside, one inside on the rear axle. No rubbing.
_________________ John
65 square 1500S (weezer) sold but always on my mind
60 beetle (Ned)
Quoting John Muir -- Open the rear boot. Get out the stool and sit down. Contemplate the air-cooled beauty before you. - How to Keep Your Volkswagen Alive -- Step-By-Step Procedures for the Compleat Idiot |
RCJH77 Samba Member
Posted: Fri Apr 21, 2023 7:03 am Post subject: Re: 1960 Beetle - Tire Setup (drums, drops, original wheels) |
6T5 square wrote: |
185/65 15's on all 4. 1960 beetle- 4" narrowed beam, 2 1/2" dropped spindles, no rake- level drop. One notch outside, one inside on the rear axle. No rubbing. |
Beautiful! Exactly what I was looking for. Thank you! |
RCJH77 Samba Member
Posted: Tue May 16, 2023 9:27 am Post subject: Re: 1960 Beetle - Tire Setup (drums, drops, original wheels) |
6T5 square wrote: |
Maybe a stupid question: If I'm not looking to completely slam the bug, are the dropped spindles even necessary? The beam that I bought will drop it 3.5 inches. That seems like quite a drop to me. |
splitjunkie Samba Member
Posted: Tue May 16, 2023 9:58 am Post subject: Re: 1960 Beetle - Tire Setup (drums, drops, original wheels) |
RCJH77 wrote: |
6T5 square wrote: |
Dropped spindles push the wheels out a bit, making the track wider, so they will compound the problem. A stock width adjustable beam will drop it without messing with the track.
The trade off being drop spindles retain full suspension travel whereas an adjustable beam will limit it.
If you just want to drop it a little, an adjustable beam seems like the best fit as a starting point. This will allow you to play with different heights and find what you like. Then you can start talking about narrowed beams, drop spindles and the like.
In theory, a narrowed beam, narrowed just enough to compensate for the increased track caused by dropped spindles, and disk brakes if that is in your plans would give the best and closest to stock ride.
It can get very involved and very expensive so I would start small and work up from there.
I personally am not an advocate for radical dropping, but that's just me. I love the look of a reasonably lowered Bug, but not on the ground with the wheels tucked way in. I am also not a fan of dropped spindles due to the major design compromises to strength required to drop the spindles which usually have the axles pressed into cast knuckles.
This recent accident of a truck with obviously poorly selected aftermarket wheels and a snapped spindle should give anyone pause when they start modifying their suspension. Obviously a Bug is not a big heavy truck with the engine in the front, but a lot of care should be put into choosing what you do to your suspension.
_________________ Chris
RCJH77 Samba Member
Posted: Tue May 16, 2023 10:45 am Post subject: Re: 1960 Beetle - Tire Setup (drums, drops, original wheels) |
Really appreciate the detailed response! This helps a ton.
splitjunkie wrote: |
In theory, a narrowed beam, narrowed just enough to compensate for the increased track caused by dropped spindles, and disk brakes if that is in your plans would give the best and closest to stock ride. |
The beam I'm installing is a 2" narrowed beam (https://www2.cip1.com/acc-c10-4201/). I went this direction so I could keep the standard width tire (or go a little wider later on) without rubbing the fender (hopefully). It would also help if I decided to use the dropped spindles, but now I'm leaning toward not using them.
I've been watching front beam install videos and ran into this JBugs video, which terrified me. Since I was already on the fence about the dropped spindles, this really tipped me toward the No side.
I personally am not an advocate for radical dropping, but that's just me. I love the look of a reasonably lowered Bug, but not on the ground with the wheels tucked way in. I am also not a fan of dropped spindles due to the major design compromises to strength required to drop the spindles which usually have the axles pressed into cast knuckles. |
We're of like minds then. My goal is to drop it just enough to improve the stance without it being too terribly obvious that it's lowered. |
Posted: Tue May 16, 2023 2:37 pm Post subject: Re: 1960 Beetle - Tire Setup (drums, drops, original wheels) |
First off, anyone advising you to use a hammer to take everything apart is someone not to listen to. A hydraulic press is the only way to go. Hammering things is how you bend things. I am not impressed with what I have seen of their other videos.
That video shows exactly what I am talking about the engineering compromises on a drop spindle. The spindle is cocked so far out on that relatively thin piece of metal to get the drop. The fact that they then bore a hole in that piece and press in the spindle (axle) just has never seemed like a good idea to me. The original VW part is a forged piece of metal. Forged parts are much stronger than cast. The dropped spindles are cast with a forged or billet axle. Just not something I would be willing to rely on for one of my cars.
Having said that, there are companies selling forged drop spindles these days, so assuming the manufacturers are using the proper steel and processes, they should be much stronger than the cast with pressed in axle versions. _________________ Chris
RCJH77 Samba Member
Posted: Tue May 23, 2023 6:48 am Post subject: Re: 1960 Beetle - Tire Setup (drums, drops, original wheels) |
When installing a new front beam, are these beam-to-body vibration damping pads necessary or helpful at all?
https://www2.cip1.com/c16-113-115a/
Also, would it be a good idea to replace these? I don't see anything particularly wrong with the originals, but wondering if it's best to replace them while you're doing the job.
RCJH77 Samba Member
Posted: Tue May 23, 2023 6:14 pm Post subject: Re: 1960 Beetle - Tire Setup (drums, drops, original wheels) |
For roughly $33, I'm just going to replace them all. 👍 |
Posted: Wed May 24, 2023 11:07 am Post subject: Re: 1960 Beetle - Tire Setup (drums, drops, original wheels) |
Replace them _________________ John
60 beetle (Ned)
RCJH77 Samba Member
Posted: Wed Jun 07, 2023 9:32 am Post subject: Re: 1960 Beetle - Tire Setup (drums, drops, original wheels) |
Okay, I'm stuck again, but so close to the finish line with this beam project. I've got the beam on a jack and have positioned it so the top two bolt holes are lined up. With new vibration damping pads on the beam, and two new pads on the trunk side (under the bolt heads), the original bolts aren't reaching the threads.
If I try to raise the beam any more (via the jack), the car lifts off of the jack stands. In other words, no matter how much more I push the beam up, the pads won't compress anymore and the bolts won't reach the threads.
So my question is, do I need to buy longer beam-to-body bolts? Seems odd to me that replacing the rubber pads has made the original bolts unusable. Maybe the original pads were a softer rubber?
In its current position, the beam won't slide into its home on the chassis either, so it has to come up more (i.e. those rubber pads have to compress somehow).
RCJH77 Samba Member
Posted: Wed Jun 07, 2023 3:54 pm Post subject: Re: 1960 Beetle - Tire Setup (drums, drops, original wheels) |
I measured the original rubber pads and the new ones and there's a difference of 1/8" (OG: 1/4", NEW: 3/8"), which doesn't sound like much, but I think I need that 1/8". Wolfsburg West, CIP1, JBUGS, etc, don't offer pads thinner than 3/8", so I may have to get creative. 😖 |
RCJH77 Samba Member
Posted: Thu Jun 08, 2023 8:12 am Post subject: Re: 1960 Beetle - Tire Setup (drums, drops, original wheels) |
Finally got the beam in last night. Holy crap, what a pain in the a$$ that was. I don't know if it's just a 1960 Beetle thing, but the 10mm vibration damping pads do NOT work in them. I ended up cutting them down to about 1/3rd using a bench grinder (highly recommend - worked perfectly). Even then, it was still a struggle to get the beam in. If I had to do it again, I would cut those pads down to about 1/4th the size.
Once I got the beam in place, the bottom two of the four beam bolts were hard to get started on the threads. I do think this has everything to do with the thickness of those two rubber pads, but regardless, I was able to get them in.
It should be downhill from here, but it's still a 1960, so I'm fully expecting more wonkiness. To be continued... |
Posted: Thu Jun 08, 2023 10:13 am Post subject: Re: 1960 Beetle - Tire Setup (drums, drops, original wheels) |
Another suggestion would be to put them in the hot sun for an hour or two. The heat will make them more pliable, but you still might have had to remove some material. _________________ Chris
RCJH77 Samba Member
Posted: Fri Jun 09, 2023 9:38 pm Post subject: Re: 1960 Beetle - Tire Setup (drums, drops, original wheels) |
Anyone know if there's a torque spec for tie rod end bolts? Neither the Bentley or the Muir book show one. Bear in mind, these are new narrowed tie rods that came with nylon lock nuts. |
RCJH77 Samba Member
Posted: Sun Jun 11, 2023 2:55 pm Post subject: Re: 1960 Beetle - Tire Setup (drums, drops, original wheels) |
I ended up just tightening the tire rod bolts until they got snug and stopped. Couldn't ever find an answer.
So here's the end result. I'm happy with the height up front. May drop the rear a little at some point, but not anytime soon. 👍
RCJH77 Samba Member
Posted: Fri Sep 29, 2023 1:56 pm Post subject: Re: 1960 Beetle - Tire Setup (drums, drops, original wheels) |
Looking back at these pictures, the front end is lower now for whatever reason (settled after getting it on the road?). Anyway, I want to raise it back to this height, but I'm having trouble finding an answer to this question:
Once the adjusters have been tightened and you've driven the car, what's the best method for loosening the adjusters? Should they be loosened with the front wheels on the ground, raised, or in some other position? |
Posted: Sat Sep 30, 2023 6:50 am Post subject: Re: 1960 Beetle - Tire Setup (drums, drops, original wheels) |
Put the car up on a set of ramps and then make your adjustments. Support the weight of the car under the "napoleon hat", make the adjustment and then lower it down again onto the ramps. That will give you some idea of how much the adjustment has changed the ride height _________________ John
60 beetle (Ned)
