SMUNNY66 Samba Member
Posted: Sat Apr 22, 2023 10:46 am Post subject: July 50 standard found |
Hello all. I’ve been a member on here for some time but this is my first forum post. I have recently found and acquired a July 50 standard body, sitting on a 63 pan. Unfortunately the pan, doors, hood and deck lid are wrong, the car does still retain the correct rear view mirror, hood hinges, hood prop, gas tank, gas cap, correct big spring on the deck lid, hood handle, dome light housing, speedo and pod, the block off pod has had a hole cut in it and a 61 Porsche tach installed. After cleaning the car out, it was full of leaves, dirt and debris, that is where I found the dome light housing on the floor, I found a chrome grooved door handle and the original doors check straps. The dash still has its original semaphore switch and the push start switch. The speedo is a moles speedo, but the backing is zinc and dated 7-59, so I am guessing it was a dealer replacement. I will share some pictures below and take some more and share when I get the chance. I have applied for a birth certificate, I am hoping that this comes back as a Hoffman car, if so it looks like it would be the oldest standard on the registry And the second oldest car on the list in general, but we will have to wait to find out when the certificate comes back. The vin is 1-0180328. |
finster Samba Member
Joined: May 26, 2012 Posts: 7951 Location: north o' the border
Posted: Sun Apr 23, 2023 2:02 am Post subject: Re: July 50 standard found |
looking forward to seeing the photos _________________ "we're here on Earth to fart around" kurt vonnegut
nothing lasts, nothing is finished, and nothing is perfect... |
50Splitman Samba Member
Posted: Sun Apr 23, 2023 8:03 am Post subject: Re: July 50 standard found |
Is your split the one that was listed recently in Facebook Marketplace for $2500 as a "49 split hardtop beetle" in Southern Maryland?
If so, I talked to the owner but never went over to see it as it was clear it was a 63 with pretty much every body part except the oval era decklid replaced from a post-oval era beetle. He never provided the body number/VIN, but given some of the pics, it looked like a 50 vs. 49.
Congrats if this is the one I'm describing, and look forward to know how rusty it is, the production date, and if it it a Hoffman. My 50 standard split is a Hoffman with VIN 01797XX. I haven't entered it the registry, but plan to do so. |
makin_vw Samba Member
Joined: January 30, 2011 Posts: 62 Location: san martin CA
Posted: Fri May 05, 2023 4:34 pm Post subject: Re: July 50 standard found |
look forward to seeing what the certificate says.. and photos of the car! |
Two Glove Boxes Samba Member
1970PAKombi Samba Member
Joined: July 10, 2019 Posts: 264 Location: Denver, PA
Posted: Thu May 11, 2023 8:38 am Post subject: Re: July 50 standard found |
Looking forward to seeing it |
