Joined: August 31, 2013 Posts: 12858 Location: North Carolina
Posted: Tue Apr 25, 2023 5:58 am Post subject: Der Wiedergänger |
As per Wikipedia…
“The name Wiedergänger refers to different zombie or ghost phenomena from different cultural areas. The word means "one who walks again" in German. The core of the wiedergänger myth is the concept of the deceased, who—often in the form of a physical phenomenon—return to the world of the living.”
Or the more contemporary translation, “The Revenant”.
This 1964 thirteen window Deluxe was wrecked in 1974 & parked in a field, that field became a forest, and this beast was forgotten until a fellow VW enthusiast bought it & placed an ad for it here. I went to look at it, made an offer, & became the lucky sucker… I mean new owner.
By now, I’m sure that many of y’all have tripped across a thread or two of mine, but if you have not, I don’t care about originality, perfection, or the “correct this or that”. My focus is to resurrect my projects, make them structurally, and mechanically, sound & then return them to service. Then, I will drive the snot out of them.
Here’s the beast as found.
Delivered over the weekend, my first task was to make it roll again. The PO managed to break the front wheels loose, but the rears were seized solid. I removed the wheel & castle nut, and installed a drum puller.
And finally extracted the left rear drum.
Yeah, that’s ugly.
_________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Tizian Samba Member
Joined: February 18, 2015 Posts: 383 Location: Hamburg, Germany
Posted: Tue Apr 25, 2023 6:56 am Post subject: Re: Der Wiedergänger |
Spooky!
Don't get haunted by the undead...
Good luck! _________________ 02/24/2022
The saddest day in recent history. My thoughts are with all those people suffering from the aggression of only one individual. |
joe cool Samba Member
Joined: August 20, 2006 Posts: 1259 Location: Yolo County CA
Posted: Tue Apr 25, 2023 1:39 pm Post subject: Re: Der Wiedergänger |
Wolfgang International makes a nice transaxle mid mount that you should look into if you drive this thing like you drove the Ghiapet. At very least it is a good reference for something you build yourself. |
Posted: Wed Apr 26, 2023 7:19 am Post subject: Re: Der Wiedergänger |
Tizian wrote: |
Spooky!
Good luck! |
Thanks, I’m sure this thing will haunt me in the long run.
joe cool wrote: |
Thanks for that. While I don’t plan on beating this to that extent (I do currently have “The Wildebeest”), Im sure that there will be some off road adventures.
Next up was to repeat the process on the passenger side…
You can see where the seller beat the drum in an attempt to break the shoes free.
I even tried to shock the shoes with a drift through the lug bolt holes.
As you can see, this approach does damage the adjusters, retaining spring caps, and the spreader bar, so I wouldn’t suggest this unless absolutely necessary.
Fortunately, upon freeing the drums, my concerns about the transmission and reduction boxes being seized from almost 50 years of sitting were allayed since the axles turned freely while spinning the input shaft.
While I sorta appreciate the seller’s efforts to make it a roller, he stuffed the galled lug bolts back in & further damaged the threads in the drums.
So I chased each hole with a tap.
And we’ll, speaking of not caring about originality, I tossed a set of wheels from a past Thing project on it.
I’m kinda diggin the difference in offset.
However, the passenger rear fender arch interfered due to being caved in, so I coaxed it out with a block of wood.
With the rear brakes gutted, it should be easy to move…. Nope. I guess this explains that.
With a bit of leverage…
I persuaded it back into a more acceptable shape.
Posted: Thu Apr 27, 2023 7:42 am Post subject: Re: Der Wiedergänger |
Speaking of haunting, or maybe just Hantavirus (and Baylisascarus), welcome to my self imposed Hell.
For some strange reason, I actually shot the seat clamps with penetrating oil.
After removing the seat, and the mat, I finally got to assess the cargo floor, or what’s left of. I really hope that there wasn’t anything needed in all the crap on the mat, because I just rolled it up & emptied it into a trash can.
That carpet disintegrated into clumps of fibrous dust with each attempt of removing it.
So I can now see the ground, I mean floor.
EverettB Administrator
Joined: April 11, 2000 Posts: 69829 Location: Phoenix Metro
Posted: Fri Apr 28, 2023 10:08 am Post subject: Re: Der Wiedergänger |
EverettB wrote: |
Is it weird I know exactly how that smells? |
Nope, any true VW enthusiast has been there & has the odiferous emanations of rodent feces permanently etched into their memory. I dare say that a mere whiff of it takes you back to a certain project.
EverettB wrote: |
I had a bus sort of like that, I said screw it and hit it with the power washer at the car wash because I couldn't make it worse. |
I would have loved to have done this, but it’s here now. After shoveling out the larger stuff, I did flush the rest out with some water.
Oddly, this stuff is so old, it really doesn’t have a scent, kinda just a faint, sweetish, moldy tobacco smell.
Anyway, let’s rip into this & see what we’re dealing with.
Posted: Sat Apr 29, 2023 11:33 am Post subject: Re: Der Wiedergänger |
By all outright appearances, the frame rails seem to be solid. But the outriggers tend to collect stuff & rot the frame behind them out. So… there’s only one way to find out.
Hey y’all… WATCH THIS!
I am pleasantly surprised that it’s still solid.
Posted: Sun Apr 30, 2023 8:15 am Post subject: Re: Der Wiedergänger |
My intentions of lopping the center cross members out was negated by the necessity to disconnect all of the cables & linkages running through the tubes.
So I attempted to start with the parking brake cables, which led me to just deal with removing the seats & cleaning the decades of accumulated crap (literally)
Hey! I found the church key…
Rather appropriately, right next to the remains of a pocket Bible.
With all of the major chunks of crap, upholstery shreds, & rust removed, I finally accessed the nuts on the parking brake cable.
Since the bottom fell out of the sky, this was the end of today’s endeavors. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Mon May 01, 2023 5:15 pm Post subject: Re: Der Wiedergänger |
My task for today was to TRY to remove the cables & shift rod, but that was thwarted by a seized bolt on the front joint of the shift rod. So I soaked it with PBlaster & walked away.
In an attempt to keep some rain out of the hulk, I slipped the front vent wing in. However, the rivet was bad & the window fell out when I closed the door. Not having a 3mm bolt, I grabbed an old spark plug, broke the ceramic off & made an impromptu nut & bolt.
It’ll do fo now.
The next thing that I did was to scrape off & wire brush the wheel tub to see how salvageable it was.
There are a few holes that will need to be addressed, but I slathered some Ospho on it to preserve what I had.
finster Samba Member
Joined: May 26, 2012 Posts: 7951 Location: north o' the border
Posted: Tue May 02, 2023 3:47 am Post subject: Re: Der Wiedergänger |
I've been looking everywhere for that moccasin! _________________ "we're here on Earth to fart around" kurt vonnegut
nothing lasts, nothing is finished, and nothing is perfect... |
Huetti_1989 Samba Member
Joined: February 13, 2011 Posts: 1136 Location: Austria
Posted: Tue May 02, 2023 12:38 pm Post subject: Re: Der Wiedergänger |
finster wrote: |
I've been looking everywhere for that moccasin! |
I hope that they fell out during transit.
Huetti_1989 wrote: |
nice Projekt!
once it is cleaned it should be fun to patch all that rusted areas!
-Christian |
That’s the plan…
Speaking of which…
It’s like Christmas all over again. And the you realize someone slipped you the cheaper ripoff version of it.
And it’s already been out of the package & played with.
Of course it had to be the part that was actually going to be seen.
Oh well, a little hammer & dolly work, and a couple of light passes through the English wheel…
Kb65single Samba Member
Posted: Tue May 02, 2023 1:40 pm Post subject: Re: Der Wiedergänger |
Take a picture and ask them send you an undented one. |
Braukuche Samba Member
Posted: Tue May 02, 2023 4:26 pm Post subject: Re: Der Wiedergänger |
Wolfsburgwest has really gone down hill. That’s a pile of b.s. right there… _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now |
ryans65 Samba Member
Joined: February 16, 2016 Posts: 1263 Location: Yulee FL
Posted: Tue May 02, 2023 5:19 pm Post subject: Re: Der Wiedergänger |
yeah screw that, funky green would send you panel after panel until you get a good one! |
Posted: Wed May 03, 2023 7:28 am Post subject: Re: Der Wiedergänger |
Kb65single wrote: |
Eh, I already worked the shipping damage out of the panel.
Braukuche wrote: |
Wolfsburgwest has really gone down hill. That’s a pile of b.s. right there… |
That was the only Krapperholm panel in the batch. While it seemed a bit bait & switch-ish since they don’t show that it’s a Klokkerholm panel, they do show that panel (without the sticker) in their catalog.
ryans65 wrote: |
I tried to order from them first, but their catalog is more difficult to navigate unless you know exactly each piece that you need, & when I tried to checkout, it popped up that there wasn’t a shipping option to my city.
Anywho, I carefully removed the lower Deluxe trim.
With that Klokkerholm patch panel in hand, I gave it a rough fit to the bus, dropped it down about an inch, & scribed a line on the side.
I then cut across the dotted line.
All to reveal the remains of the inner rocker.
Posted: Thu May 04, 2023 9:15 am Post subject: Re: Der Wiedergänger |
I began to chisel the remainder of the outrigger off the front, driver side frame rail, and, as expected, I found a soft spot in the frame rail.
So I lopped it out to find that it was packed full of muck.
Having some sections of rail left over from another project, I hacked a piece out…
And whittled it down to size.
And fused it in place.
Then I gave it a quick clean up.
Posted: Fri May 05, 2023 10:30 am Post subject: Re: Der Wiedergänger |
To avoid the painstaking process of measuring, recording those numbers, & then probably losing or mismeasuring as I try to reinstall all this shit, I prefer to use the original parts as guides to accurately reconstruct these beasts. This morning, I continued with my “strategic demolition”.
After cleaning all the existing floor supports of the remains of floor, I attached a few bits of scrap to the top of them.
With the “alignment tabs” in place, I then clamped the inner rocker to the supports.
With the inner rocker attached, I was now able to clamp the outer rocker in place.
Stocknazi Samba Member
Posted: Fri May 05, 2023 10:53 am Post subject: Re: Der Wiedergänger |
This is going to be a nice looking patina bus when you're done. Really like you creativity with the spark plug. _________________ WANTED:
"Resistance to tyrants is obedience to God."
Thomas Jefferson |
