52 split Samba Member
Joined: December 19, 2007 Posts: 150 Location: the best island in the world, vancouver island
Posted: Tue Apr 25, 2023 9:23 pm Post subject: Split glove box doors |
can anyone help with glove box door install.are the hinges screwed through the trim into the dash or some how only attached to the trim which would be very flimsy. photos or how to will be much appreciated. |
empiracer Samba Member
Joined: December 17, 2002 Posts: 1098 Location: Issaquah / Seattle, Wa.
Posted: Wed Apr 26, 2023 6:29 am Post subject: Re: Split glove box doors |
depends on which type of doors you have, I have a set of perohaus doors on my Beetle , no drilling / screwing required
they clip onto the steel around the glovebox hole not the aluminum trim its self
splitjunkie Samba Member
Posted: Wed Apr 26, 2023 3:43 pm Post subject: Re: Split glove box doors |
The type with the key lock and the round horn grills are riveted onto the aluminum glove box trim and then the trim is installed as normal. _________________ Chris
Posted: Thu Apr 27, 2023 8:02 pm Post subject: Re: Split glove box doors |
yes i have the hand made repos from germany that have a hinge and spring that needs to be assembled, does the spring act to snap the door back up to the close position, yes they have the grill holes in them. having one pain of time to get the hinge pin in place holes to small out of round you name it then one side of hinge thats attached to the lid comes of. looks like it was glued on. joy. will clean mess and spot weld it to lid. Repo fun. thanks for the help |
sweden Samba Member
Posted: Fri May 19, 2023 8:59 am Post subject: Re: Split glove box doors |
_________________ Me and my sons cars Typ1 -49 -50 -51 -52 -52 -53 -53 -54 -55 -55 -56 -56 -57 -58 cab -64 cab
T3 TriStar airride with Audi 1,8T engine and Porsche 996 gearbox. |
