Jeffhoehn Samba Member
Joined: January 18, 2021 Posts: 3 Location: Columbiana, al
Posted: Sun Apr 30, 2023 4:14 pm Post subject: 1969 Autostick expert needed |
When I turn the key on I can hear/feel the solenoid activate. The neutral switch works because it will not crank in gear. I put a new shifter contact in it and checked the wire. I am assuming you should hear the solenoid activate with the key on but I am not sure. It also gets very hot while car is running. I just need someone who has worked on these systems and really understands what could be wrong. There is absolutely no pressure to activate the pump and disengage the clutch. All hosed are new and not collapsing except the small one from the carb to the solenoid. Please ask me what else you need to know. I would love to talk with someone in person should you be near Birmingham,Al. Or on the phone.
mukluk Samba Member
Posted: Sun Apr 30, 2023 5:20 pm Post subject: Re: 1969 Autostick expert needed |
The shift solenoid should not automatically click/activate as soon as you turn the ignition on. If it does that indicates either the shifter contact wiring is shorted to ground or the contacts are adjusted too close. The solenoid should only activate when you physically move the shift lever and cause the contacts to close.
Have a read:
_________________ 1960 Ragtop w/Semaphores "Inga" |
mukluk Samba Member
Posted: Sun Apr 30, 2023 5:22 pm Post subject: Re: 1969 Autostick expert needed |
Shift lever diagram and contact adjustment courtesy of glutamodo:
sb001 Samba Member
Posted: Sun Apr 30, 2023 6:07 pm Post subject: Re: 1969 Autostick expert needed |
Jeffhoehn wrote: |
When I turn the key on I can hear/feel the solenoid activate. The neutral switch works because it will not crank in gear. I put a new shifter contact in it and checked the wire. I am assuming you should hear the solenoid activate with the key on but I am not sure. |
As stated above the solenoid should only activate when you shift gears. The noise you are hearing when you turn the key to the on position is just vacuum evacuating from the vacuum tank under the left rear fender (mine does the same thing.)
Jeffhoehn wrote: |
There is absolutely no pressure to activate the pump and disengage the clutch. |
By "pump" do you mean the control valve? That is a solenoid-operated vacuum control valve not a "pump"-- it is what controls sending vacuum through to the clutch diaphragm servo pictured in one of the excerpted pages above.
If you cannot shift with the engine running, and you are sure the contacts in the base of the shifter are properly set so as to contact each other when you shift (as mentioned above) then my first suspect would be your clutch servo diaphragm is shot.
First (easiest) thing to check is the wire going from your ignition coil over to the control valve, this should have an 8 amp inline fuse, check to make sure that fuse is good.
If so, try this test: (engine off) remove left rear wheel, locate the clutch servo canister attached to the transmission:
Pull off the hose going to that canister and cover that port with your thumb, then pull outward on the clutch servo arm, with your thumb covering that hose port the canister should retain pressure and that arm should remain in the outward position. If it sinks back into the canister then your diaphragm is shot. There are replacement diaphragm kits available.
Jeffhoehn wrote: |
It also gets very hot while car is running. |
This issue is most likely unrelated to the autostick issues, if you can please post pictures of your engine bay, and do you know where/ how you have the timing set? _________________ I'm the humblest guy on this board.
1600 SP engine
Solex 30 PICT 3 carburetor
Tom K. Samba Member
Joined: March 10, 2005 Posts: 1606 Location: Central Pennsylvania
bobalowbill Samba Member
Posted: Thu May 11, 2023 2:04 pm Post subject: Re: 1969 Autostick expert needed |
I ALSO HAVE A AUTOSTICK, I REPLACED ALL VACUUM HOSES, AND THE SWITCH IN THE SHIFTER, THE CLUTCH SERVO OPERATES, THE CONTROL VALVE OPERATES, I CAN SHIFT INTO ALL GEARS, REAR WHEELS DON'T TURN. I THOUGHT THE BRAKES WERE STUCK BECUSE I COULD NOT TURN REAR WHEELS BY HAND. REMOVED WHEELS AND BRAKE HUBS AXLES TURN WITH HUBS OFF BOTH FORWARD AND REVERSE. REINSTALLED THE HUBS AND NOW AXLES WON'T TURN IN ANY GREAR. BUT I CAN TURN THEM BY HAND. CAN ANYONE POINT ME IN THE RIGHT DIRECTION I WOULD LIKE TO KEEP THE AUTOSTICK. |
KTPhil Samba Member
Posted: Thu May 11, 2023 2:10 pm Post subject: Re: 1969 Autostick expert needed |
bobalowbill wrote: |
I also have an autostick, I replaced all vacuum hoses, and the switch in the shifter, the clutch servo operates, the control valve operates, I can shift into all gears, rear wheels don't turn. I thought the brakes were stuck because i could not turn rear wheels by hand. Removed wheels and brake hubs axles turn with hubs off both forward and reverse. Reinstalled the hubs and now axles won't turn in any gear. but I can turn them by hand. Can anyone point me in the right direction I would like to keep the autostick. |
Fixed it for ya.
(my ears are still ringing) |
mukluk Samba Member
Posted: Thu May 11, 2023 3:24 pm Post subject: Re: 1969 Autostick expert needed |
@bobalowbill
Check for low ATF level. If the fluid is filled to spec, check to see if you're getting ATF to and through the dual oil pump on the engine and that it's getting to and through the transaxle.
Check to see if either of the CV shafts have sheared or missing hardware.
Pull the rear hubcaps and check to see if either of the rear axle nuts spin when the car is running and in gear (indicates sheared splines in the drum). _________________ 1960 Ragtop w/Semaphores "Inga" |
Tom K. Samba Member
sb001 Samba Member
Posted: Fri May 12, 2023 8:59 am Post subject: Re: 1969 Autostick expert needed |
I THOUGHT THE BRAKES WERE STUCK BECUSE I COULD NOT TURN REAR WHEELS BY HAND. REMOVED WHEELS AND BRAKE HUBS AXLES TURN WITH HUBS OFF BOTH FORWARD AND REVERSE. REINSTALLED THE HUBS AND NOW AXLES WON'T TURN IN ANY GREAR. BUT I CAN TURN THEM BY HAND.. |
Are you saying with the wheels and brake hubs removed the axles will spin with the engine running and in gear?? Or are you just saying you can spin the axles by hand with those parts removed? _________________ I'm the humblest guy on this board.
1600 SP engine
Posted: Fri May 12, 2023 1:16 pm Post subject: Re: 1969 Autostick expert needed |
I started the engine put it in gear removed power from control valve and the clutch servo stayed pulled out.
I have it up on jack stands with the engine started in gear and the wheels and hubs are removed the axles turn. |
mukluk Samba Member
Posted: Fri May 12, 2023 1:38 pm Post subject: Re: 1969 Autostick expert needed |
Are you saying that the clutch servo is not releasing the clutch lever/arm on the transaxle? If yes, the control valve is sticking or you have the large vacuum hoses for the servo and vacuum tank reversed at the control valve. _________________ 1960 Ragtop w/Semaphores "Inga" |
Tom K. Samba Member
Posted: Fri May 12, 2023 5:30 pm Post subject: Re: 1969 Autostick expert needed |
I'm having a little trouble understanding your update. If the axles are now spinning from engine power with the control valve disabled, then I would next loosen the shift linkage under the shifter. Plug in the control valve. Keep the engine on and in gear as you loosen the linkage until the wheels start to spin. But if you go to far out you will get gear grind. Keep loosening, shifting, etc. Play with it and dial it in till you like it. Too tight and the wheels don't spin. Too loose and you'll get gear grind when shifting. _________________ '91 Vanagon Westfalia
'70 Beetle Convertible
'71 Super Beetle Semi-Automatic: https://www.thesamba.com/vw/forum/viewtopic.php?t=714131&highlight=
'65 Ghia: https://www.thesamba.com/vw/forum/viewtopic.php?t=762478&highlight= |
Posted: Sat May 13, 2023 12:24 pm Post subject: Re: 1969 Autostick expert needed |
I observed that when the engine is running, in gear or not that when I move the shifter to the left or right the clutch servo moves in an out is that suppose to happen, I am not pushing down on the shifter. wheels still not turning. |
sb001 Samba Member
Posted: Sat May 13, 2023 2:58 pm Post subject: Re: 1969 Autostick expert needed |
It sounds like the clutch servo is working properly but the clutch itself inside the transmission is not engaging.
Couple of things to check before concluding the issue is internal to the transmission:
1. Easiest-- observe whether the clutch arm -- the curved arm sticking out of the transmission attached to the end of the servo rod with a hinge pin-- is also moving when the servo rod moves in/out:
Can you ensure the pin is in place and the clutch arm is moving normally with the servo rod. If you can, check the other end of the clutch arm where it is attached to the throwout bearing rod:
Make sure the clamp bolt is there and not missing or loose.
2. Check the adjuster sleeve on servo rod- also shown in my picture above. This sleeve adjusts how much the servo rod moves in/ out and thus ultimately the play in the movement of the clutch itself. You want approx 4mm of space between the outer edge of the servo canister mounting bracket and that end of the sleeve. If you need to adjust it, loosen the locknut on the other side of the sleeve (NOTE: it is opposite-threaded so turn the locknut to the RIGHT to loosen.)
Then thread the sleeve down toward the servo canister until you have approx 4mm between it and the servo mounting bracket, then tighten the locknut.
If none of this is the issue I'm afraid it is probably internal to the transmission. Tom K has a good thread on autostick disassembly.
Do you hear any weird sounds when trying to engage a gear _________________ I'm the humblest guy on this board.
1600 SP engine
Tom K. Samba Member
sb001 Samba Member
Posted: Wed May 17, 2023 9:43 am Post subject: Re: 1969 Autostick expert needed |
Any updates on this?? _________________ I'm the humblest guy on this board.
1600 SP engine
Posted: Thu May 18, 2023 6:36 am Post subject: Re: 1969 Autostick expert needed |
I pulled the engine yesterday had metal shavings in torque converter going to pull transmission pan today to see if there is metal shavings there |
billmetric Samba Member
Joined: March 16, 2006 Posts: 1061 Location: Columbus City USA
Posted: Thu May 18, 2023 6:55 am Post subject: Re: 1969 Autostick expert needed |
just to clarify, the ATF fluid and gear oil have no contact with each other, metal shavings are unlikely to mix between the two, of course the engine oil and ATF can mix at the combined oil pump seals should they fail, these trans are somewhat notorious in my experience for rusted stuck clutches after extended moist storage and there is virtually no posibility of freeing up a stuck clutch without transmission removal and disassembly due to the torque convertor slippage, you can't just free up a stuck clutch like on a standard manual trans, also examine the provided wiring diagrams, the factory wiring and neutral safety switch bridges the clutch solenoid in neutral AND while shifting, that means that idling in neutral the solenoid is powered up, getting hot and the clutch diaphram is pulling the clutch arm, I usually modify my wiring harness to allow the clutch/solenoid to remain engaged/unpowered in neutral just to prevent excess heat and power draw at idle _________________ There is an idea of a Billmetric; some kind of abstraction. But there is no real me: only an entity, something illusory. And though I can hide my cold gaze, and you can shake my hand and feel flesh gripping yours and maybe you can even sense our lifestyles are probably comparable... I simply am not there... |
sb001 Samba Member
Posted: Thu May 18, 2023 7:22 am Post subject: Re: 1969 Autostick expert needed |
billmetric wrote: |
just to clarify, the ATF fluid and gear oil have no contact with each other, metal shavings are unlikely to mix between the two, of course the engine oil and ATF can mix at the combined oil pump seals should they fail, these trans are somewhat notorious in my experience for rusted stuck clutches after extended moist storage and there is virtually no posibility of freeing up a stuck clutch without transmission removal and disassembly due to the torque convertor slippage, you can't just free up a stuck clutch like on a standard manual trans, also examine the provided wiring diagrams, the factory wiring and neutral safety switch bridges the clutch solenoid in neutral AND while shifting, that means that idling in neutral the solenoid is powered up, getting hot and the clutch diaphram is pulling the clutch arm, I usually modify my wiring harness to allow the clutch/solenoid to remain engaged/unpowered in neutral just to prevent excess heat and power draw at idle |
This is a terrible idea IMO, you'll wear out your clutch lining WAAYYY faster by having it re-engage every time you're passing through neutral to shift and then where will you be, having to disassemble the tranny anyway (or find another one.) The reason the autosticks are known for their clutch longevity is precisely because they don't re-engage all the time and the system prevents them from slipping like drivers might a 4 speed one.
Also the solenoid control valves in these autosticks typically last decades, I'm still on the original in my 69. The absolute last thought in my mind is my control valve going out.
It boggles my mind how some folks think they know better than the German engineers who spent decades and tons of money RD'ing these things. _________________ I'm the humblest guy on this board.
1600 SP engine
