wwwben Samba Member
Joined: September 18, 2022 Posts: 28 Location: Upper Peninsula of Michigan
Posted: Mon May 01, 2023 1:11 pm Post subject: Help.. Twisted Engine!! |
HELP my engine seems to be rotated to one side ..
is it OK to drive?
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76940 Location: Sneaking up behind you
Posted: Mon May 01, 2023 1:13 pm Post subject: Re: Help.. Twisted Engine!! |
Safe????
Something is bent or broken. I wouldn't until its fixed. _________________ Glenn
Member #1009
#BlueSquare |
wwwben Samba Member
Posted: Mon May 01, 2023 1:18 pm Post subject: Re: Help.. Twisted Engine!! |
I cant find anything bent or broken .. of course maybe I don't know what to look for .. I have only had it thru the winter and have only driven it maybe 10 miles mostly on pavement. |
71StandardReduction Samba Member
Joined: December 04, 2012 Posts: 715 Location: Louisiana
cbeck Samba Member
Posted: Mon May 01, 2023 3:35 pm Post subject: Re: Help.. Twisted Engine!! |
More pics. Top, bottom, sides. Torsion at frame. Enough pics, and somebody will spot it. _________________ My cut in half and rebuild thread
www.thesamba.com/vw/forum/viewtopic.php?t=647779 |
Glenn Mr. 010
Posted: Mon May 01, 2023 3:39 pm Post subject: Re: Help.. Twisted Engine!! |
Measure the ends of the framehorns to the ground.
Member #1009
#BlueSquare |
cbeck Samba Member
Posted: Mon May 01, 2023 3:40 pm Post subject: Re: Help.. Twisted Engine!! |
Secpnd glance. The motor plate bolts into the frame horns are off. Bent frame horns or the torsion housing is twisting. Do you have frame horn supports tying into the frame? _________________ My cut in half and rebuild thread
DesertSasquatchXploration Samba Member
Posted: Mon May 01, 2023 8:19 pm Post subject: Re: Help.. Twisted Engine!! |
That's a Beater Yikes I would sell it to someone that's blind in one eye and cant see out of the other or... do a full tear down Re Fab the whole ass end. |
wwwben Samba Member
Posted: Tue May 02, 2023 6:15 am Post subject: Re: Help.. Twisted Engine!! |
I measured the horns .. the one on passenger side is an inch or so lower than the other
ORANGECRUSHer Samba Member
Joined: June 09, 2006 Posts: 2675 Location: West Coast (Michigan's)
Posted: Wed May 03, 2023 4:20 pm Post subject: Re: Help.. Twisted Engine!! |
Looking at that trans brace you can see how much it has moved. The strange thing is for everything to be moved that much I would expect to see a failed weld somewhere or a crease in the frame horn where it's given way.
Pull the motor out. Takes 30 minutes. It's easy and you'll learn a lot about your rig just from that. Then get your head in there with a spotlight on all the seams and welds.
It's very possible you might be looking at welding in a new IRS. Unless you did this I bet someone unloaded this on you and didn't tell you. Frame horns are pretty stout and for it to be that f'ed you're gonna remember the event. I bet you find an impact spot on the driver side somewhere, probably the rear trans mount plate.
It's possible it's driveable though. Depends on whether your driveaxles aren't angled too much now or if there's something broken or about ready to snap. Just being crooked isn't a deal breaker necessarily. Just kinda sucks. _________________ Brian H.
I may not know everything,but I will try to help if I can
OrangeCrushER Berrien Warrior 2.4L Quad4
LAZY MARY 1970 Baja 1835cc |
Glenn Mr. 010
Posted: Wed May 03, 2023 6:51 pm Post subject: Re: Help.. Twisted Engine!! |
[quote="wwwben"]I measured the horns .. the one on passenger side is an inch or so lower than the other/quote]
That's why it's twisted.
Now how did it happen and how do you fix it are the questions. _________________ Glenn
Member #1009
#BlueSquare |
wwwben Samba Member
Posted: Wed May 10, 2023 3:05 am Post subject: Re: Help.. Twisted Engine!! |
yeah… i have only driven it a few miles .. and i’m not able to weld. i’ll see if i can find someone who can fix this .. i live in the middle of no where uggg |
Posted: Wed May 10, 2023 1:46 pm Post subject: Re: Help.. Twisted Engine!! |
I would help, but you'd have to bring it down to muskegon.
No spots of damage have been identified yet except the fact that the one side is bent up. If it's only a matter of a bent horn it might be possible to get a porta-power on it and push it back where it needs to be or at least even with the other horn. Or a frame tube could be added that could be wedged in there permanently to push it back if there's room. I wouldn't say that's the ideal fix. But if you could remove the engine and trans and take it to a place that has body shop style tools they may be able to push it back where it needs to be without welding anything as long as there are no rips or broken seams in the metal. I would still do some frame strengthening after that, adding some triangulated tubes to help strengthen a weakened area, but that's up to you and how hard you want to drive it. _________________ Brian H.
Dale M. Samba Member
Posted: Wed May 10, 2023 6:20 pm Post subject: Re: Help.. Twisted Engine!! |
If you are not setup to "fix" the problem, you might consider getting estimate from a shop that can do chassis/frame straightening.... _________________ “Fear The Government That Wants To Take Your Guns" - Thomas Jefferson.
