GasBuggy Samba Member
Joined: March 08, 2023 Posts: 23 Location: West Chester PA
Posted: Wed May 03, 2023 2:43 pm Post subject: Cold Start Question and Fuel Pump Issue on 1965 1200cc (video) |
I'm making some progress on my barn find 1965. Got her tuned up and running better. I figured out something odd. If I pump the gas pedal at all before trying to cold start, it won't fire up, no matter what I do. You'll need starting fluid to get it running but with a little starting fluid it will fire right up and run smooth. BUT If you don't touch the gas pedal it will always fire right up. As seen in this video.
Aside from that, I have a major fuel leak from I'm assuming the fuel pump. I looked on RockAuto for a rebuild kit, they just sell individual gaskets. I'm looking for someone to tell me that I should buy X kit from X vendor. Or, perhaps I need to send it out for a rebuild? Or perhaps just gaskets usually solve this problem. This is my first VW.
[/youtube] |
rcroane Samba Member
Joined: January 03, 2013 Posts: 1996 Location: Springfield, Virginia
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9665 Location: Oregon
Posted: Wed May 03, 2023 5:54 pm Post subject: Re: Cold Start Question and Fuel Pump Issue on 1965 1200cc (video) |
The latest WW FP rebuild kits are excellent.
Clean and reuse the original diaphragm spring, to make sure that the pump output pressure is with in the VW spec. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
Posted: Wed May 03, 2023 11:28 pm Post subject: Re: Cold Start Question and Fuel Pump Issue on 1965 1200cc (video) |
Im glad they're good quality. The cost is close to what a new Carter fuel pump is on Rock Auto. But I would like to keep the original
Does Wolfsburg West have a discount code for the forum? |
Posted: Mon May 08, 2023 4:24 pm Post subject: Re: Cold Start Question and Fuel Pump Issue on 1965 1200cc (video) |
Does anyone have an opinion about the odd cold start?
Fires up great with no pressing the pedal, but if you press the pedal first you'll not be able to start it without starting fluid, however, it doesn't seem to be flooded or running rich.
At the moment I thought I would fix the pump and see what changes with the starting. But since I'm going to be ordering parts, if there is something else I likey need from WW, I would like to get it on one order. |
wcfvw69 Samba Purist
Posted: Thu May 25, 2023 5:27 am Post subject: Re: Cold Start Question and Fuel Pump Issue on 1965 1200cc (video) |
67rustavenger wrote: |
Clean and reuse the original diaphragm spring, to make sure that the pump output pressure is with in the VW spec. |
While the WW kits are currently the best out there, there are some issues with a few of the parts in that kit. Their new rocker pin is undersized and there is an issue with a part that goes in the square top pumps. I only rebuild the original Pierburg diaphragm assemblies using new OEM Effbe diaphragm assemblies. It's a bummer that like most other "new" parts for our VWs, they are not as good as the original parts. _________________ Contact me at [email protected]
The Samba member since 2004.
wdfifteen Samba Member
Posted: Thu May 25, 2023 11:35 am Post subject: Re: Cold Start Question and Fuel Pump Issue on 1965 1200cc (video) |
GasBuggy wrote: |
Or, perhaps I need to send it out for a rebuild? Or perhaps just gaskets usually solve this problem. This is my first VW. [/youtube] |
Your engine sounds like the carb is leaking into the manifold.
Don't use starting fluid!!
Send it out.
I've spent many decades doing it all myself on my Porsches and VWs. They always ran, and most of the time ran really well. But since I started passing the detail stuff off to pros with experience and right tools and equipment I learned how marginal my work really was.
I know it involves some $$ and I may be at a different place in life than you, but if I wanted to drive and really enjoy a sweet running VW I would send the carb, distributor, and fuel pump out to the pros first thing. A great running old VW is a joy to drive, and marginal one is ... not. Life is too short for "not." |
scrivyscriv Samba Electrician
Joined: October 04, 2011 Posts: 2918 Location: Memphis
Posted: Thu May 25, 2023 2:30 pm Post subject: Re: Cold Start Question and Fuel Pump Issue on 1965 1200cc (video) |
GasBuggy wrote: |
… But I would like to keep the original
Excellent train of thought my guy! Most new owners want to replace parts right away with bolt on new stuff, which sometimes works, but many times leads to frustrated and disappointed experiences because of the underwhelming quality of many “new” parts. Rebuilding a good core is usually the preferred option, and fuel pumps are a fantastic place to get your feet wet (not with fuel hopefully)!
As an example of the parts quality issues we have; replacement fuel pumps are commonly diagnosed with excessive fuel pressure, due to inappropriate spring rate and pressure one the diaphragm, which causes hard starting and flooded carburetors.
I’m not aware of a Wolfsburg west coupon code, they tend to be a little higher in price but they also carry a lot of good quality part that they have engineered and/or had made themselves.
I can’t answer your pump-the-gas question, it sure seems opposite of how VW designed it. The owners manuals usually tell the driver to press the gas twice and then start. _________________ Robert in Memphis
Engine rebuild thread
If you're ever in the Memphis area, you are welcome to stop by for advice and help. |
VWNate Samba Member
Joined: October 04, 2016 Posts: 355 Location: Sunny So. Cal.
Posted: Mon Jul 31, 2023 7:25 pm Post subject: Hard Start Issue |
Order in the pump kit you need or send it out, meanwhilst you need to do a complete and PROPER service / tune up and this always begins with adjusting the valves ~ you can't hear them in the video and this means they're tight, a very bad thing indeed .
Remove the sump cover and oil screen and clean it well, replace with the correct typ of 6X1.0MM cap nuts and copper washers, not just 6MM nuts .
Remove the spark plugs and inspect them, use a wire typ gauge or drill bit to adjst the gap to .030" ~ .035" .
Look across the plug gap ~ if the center electrode is rounded on the edges, that spark plugs os kaput, get new ones, Bosh (?) of NGK copper cored ones, the good folks here will tel you the correct part #, most of the time the parts counter guy will give you the wrong ones or try to up sell you to !!PLATINUM!! or other crap your old tech engine doesn't need nor want .
Then set points gap / dwell angle then the timing, then and only then can you touch the carby .
Do things in the correct order and you'll love the car .
Do it half/@$$ed and you'll hate it and it won't be reliable .
GET RID OF THAT 1/4" FUEL HOSE BEFORE THE CAR CATCHES FIRE ! no foolin' . _________________ -Nate
One last Beetle : 1959 #113 DeLuxe survivor ~ 36HP & full synchro tranny, 6 volts etc. |
