malacarr Samba Member
Joined: May 06, 2014 Posts: 44 Location: Bermuda Run, NC
Posted: Thu May 04, 2023 4:25 am Post subject: Do they make kits for Super Beetle chassis |
I started with a 73 Super Beetle and enjoyed restoring it when COVID got in the way. Anyway, after post COVID I found a 74 that I preferred and am now driving and working on it. I still have the 73 and would like to finish working on it but I was thinking maybe a Dune Buggy type kit would make more sense. I think there might be a problem front suspension. Any help of guidance would be appreciated, thanks... |
slalombuggy Samba Member
Posted: Thu May 04, 2023 5:34 am Post subject: Re: Do they make kits for Super Beetle chassis |
You'll need to change the front of the pan to mount a beam style suspension. No one makes a kit to support strut suspensions |
Posted: Thu May 04, 2023 6:31 am Post subject: Re: Do they make kits for Super Beetle chassis |
Is there a kit to make that change? |
NJ John Samba Member
Joined: September 21, 2007 Posts: 2224 Location: HdG, MD & NJ
Posted: Thu May 04, 2023 7:06 am Post subject: Re: Do they make kits for Super Beetle chassis |
Any company’s or shops that did, probably don’t anymore.
Here’s a topic covering it. But you could also cut the frame head off and craft in a standard frame head.
https://www.thesamba.com/vw/forum/viewtopic.php?t=460537 _________________ 1973 standard, yellow, lowered, 3” narrowed front, 1600 blo-thru turbo w/single dell 15.4@86, so far
11.41 et buggy. Long gone
Let’s go O’s! Let’s go O’s!
https://www.youtube.com/@AirSpooledGarage |
mikemck Samba Member
Posted: Thu May 04, 2023 3:01 pm Post subject: Re: Do they make kits for Super Beetle chassis |
The now-dead Classic Motor Carriages had a kit for this. You may be able to find one. |
Posted: Thu May 04, 2023 3:24 pm Post subject: Re: Do they make kits for Super Beetle chassis |
I will look, thanks man... |
oprn Samba Member
Joined: November 13, 2016 Posts: 12740 Location: Western Canada
Posted: Fri May 05, 2023 5:11 am Post subject: Re: Do they make kits for Super Beetle chassis |
Super Beetles are the pinnacle of the Beetle evolution. The best of the best so to speak. I personally hate to see them chopped up for other purposes as the front suspension does not really suit either kit cars or off road. Most of these conversions end in projects that sit for years and are then set to the recyclers.
In my part of the world the floor pans rust the worst so if the floor pan is salvageable the rest of the body is usually not so bad. Maybe someone else would be interested in continuing the restoration? _________________ We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age) |
Posted: Fri May 05, 2023 6:10 am Post subject: Re: Do they make kits for Super Beetle chassis |
Well I replaced the pans on it and most of the work is done. The company that I work the owner has a race a shop and was restoring it there. Anyway, we are in the multi-family building business and they need some room for storage of material and the Beetle is now in a race car trailer. Have really enjoyed the 74 that I am now driving and was looking to do something different with the 73. I think you might be right, I will probably finish reassembling it and sell it on to someone else... |
Dusty1 Samba Member
Posted: Fri May 12, 2023 11:21 am Post subject: Re: Do they make kits for Super Beetle chassis |
malacarr wrote: |
Race shop?!
Weld up a goody to do the job the upper strut mounts used to do. Upper strut mounts are on the body.
Even if you sell your Super, it shouldn't be that difficult to track down an orphan Super pan for a kit car build.
Once you figure out your upper strut mounts fabricate a jig. If no one else sells the parts you need to make your Super pan work under a kit car... sounds like an opportunity. You won't get rich but you might sell a few.
BL3Manx Samba Member
Joined: August 29, 2006 Posts: 6767 Location: Northern California
