t-royR Samba Member
Joined: April 19, 2012 Posts: 464 Location: Minnesota
Posted: Fri May 05, 2023 4:54 pm Post subject: Windshield needed |
Just had my windshield tinted and it developed a crack. Crap!
Anybody point me to a good source for windshield for a 69 fastback?
T-roy _________________ T-roy
75 Super
71 Super
71 Ghia coupe auto-stick
71 Ghia conv
69 Fasty
74 Ghia conv |
Jason37 Samba Member
Posted: Fri May 05, 2023 11:38 pm Post subject: Re: Windshield needed |
You could try ISPwest or Bill and Steve’s. |
eyetzr Samba Member
Joined: October 09, 2013 Posts: 1425 Location: Toronto, Ontario. Canada
Posted: Sat May 06, 2023 6:07 am Post subject: Re: Windshield needed |
I went to my local glas shop and got a new one. Took a couple of days _________________ I think he meant "rare", as in "not well-done" |
t-royR Samba Member
Posted: Tue May 23, 2023 6:28 pm Post subject: Re: Windshield needed |
Okay, I have new windshield in hand along with a new window seal. I"ve replaced all the other windows on this vehicle except the windshield.
I know how to use a cord to pull the window seal onto the frame. I am wanting to know from anyone who has replaced a windshield on a fastback, if you can do it without removing the dashpad. It looks tight down there at the bottom of the windshield on the inside where it meets the dash. I am wondering If I'll be able to get that lower seal pulled on while leaving the dashpad in.
Thanks
75 Super
71 Super
71 Ghia conv
69 Fasty
74 Ghia conv |
Bobnotch Samba Member
Posted: Tue May 23, 2023 8:51 pm Post subject: Re: Windshield needed |
t-royR wrote: |
Thanks
T-roy |
My wife and I have done it on a Fastback, a Squareback, a Notchback, and even a T-34. No the dash pad can stay put. I usually start pulling the rope out of the bottom first, but I've also pulled it out of the top first before. It's not really any harder than doing any of the other stationary glass. We've done rear side windows on a Chevy suburban (the glass is thinner), and even glass in a sliding van door. It's really no harder than doing the rear window of a pickup truck. The rear window of a Fastback is harder than the front, due to the limited amount of room between the seal and the rear deck tray. At least a Notch has a little more room since it stands up more.
I hope this helps.
Someone on here used masking or duct tape to hold the glass and seal in position, then pulled the rope. Someone else used a ratchet strap to replace the 2nd person (including pics). Where there's a will, there's a way. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
andybla Samba Member
Posted: Wed May 24, 2023 3:59 am Post subject: Re: Windshield needed |
yup, replaced my front wind nshield also last week with new seals, just had someone pushing on the outside because the windshield tends to pop out, after that started pulling the ropes from the bottom middle to the sides and going up
when done, gentle tapping the windshield in all places to give a final seat for the new rubber |
Posted: Wed May 24, 2023 9:47 am Post subject: Re: Windshield needed |
andybla wrote: |
Yup, the big key is to keep the outer lip from trying to roll under. You want it to lay out flat against the body. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
old_man Samba Member
Joined: June 19, 2018 Posts: 1382 Location: Newfoundland
Posted: Fri May 26, 2023 2:42 pm Post subject: Re: Windshield needed |
Bobnotch wrote: |
Someone else used a ratchet strap to replace the 2nd person (including pics). Where there's a will, there's a way. |
I did that. I used good quality suction cups as well to help pull from the inside.
i
I've used this technique sucessfully on a Vanagon and 911 as well.
Remember to put the metal trim in BEFORE installing the windshield. That trim is honestly the hardest, longest, and most painful part.
They make tools to insert the rope, they make things faster. I went around twice with the rope.
Lastly, you could always get one of those mobile glass companies to install it for you. |
