VWinny Samba Member
Posted: Mon May 08, 2023 8:32 am Post subject: Drive 30 miles to beach and no start/ hard strart. |
I drive 30 miles to the beach this past weekend through several stop lights down major roads, idles perfectly at 750 as soon as i mash the clutch. Park and spend day at beach, turn key and it cranks and then immediately dies, will not start, keep turning key doesn't turn over smells of gas, finally starts after about 15 minutes of really getting on the starter and gas pedal, runs choppy for a minute or so and then begins to idle perfectly at 750rpms. I drive her home, runs fantastic the whole way there. next morning same no start problem.
I have all new sensors including map. spark fuel and compression ok. my suspicion is there is some type of fuel pump relay fuse issue during startup. The actual fuel pump relay is brand new and I can hear it come on when i turn the key. IAC is also new and functioning.
I took a picture of the relays in question and put it below, the relays I have not swapped out are the ones that are in upper left hand corner upside down labeled 38 and 53, I looked up the serial numbers and they say engine compartment, fuel pump relay etc. also number 18 which is ignition auxiliary
I'm also concerned that the ecm is acting funny because I did a swap to a manual, but I have started the engine numerous times and it always cranks first time until now.
mikemtnbike Samba Member
Joined: March 26, 2015 Posts: 2795 Location: North Carolina
VWinny Samba Member
Posted: Mon May 08, 2023 8:37 am Post subject: Re: Drive 30 miles to beach and no start/ hard strart. |
ecu relay brand new. do you know how to test? |
VWinny Samba Member
Posted: Mon May 08, 2023 8:48 am Post subject: Re: Drive 30 miles to beach and no start/ hard strart. |
I'll also note that after I got home I went back out to crank after about an hour and it turned over and idled just fine. |
Posted: Mon May 08, 2023 9:45 am Post subject: Re: Drive 30 miles to beach and no start/ hard strart. |
There's some youtube videos that explain it way better than I can, I've watched one or two and done some bench testing. I'd have to watch them again to be confident in my explanation, not trying to say "use the search," not that guy. _________________ 1991 Vanagon GL 2.1 AT Westfauxlia. "Frankie" Totaled https://www.thesamba.com/vw/forum/viewtopic.php?t=764510&highlight=carnage
2020 GTI SE manual |
VWinny Samba Member
Posted: Mon May 08, 2023 11:00 am Post subject: Re: Drive 30 miles to beach and no start/ hard strart. |
UPdate:
All relay fuses bench tested OK. |
Posted: Mon May 08, 2023 5:45 pm Post subject: Re: Drive 30 miles to beach and no start/ hard strart. |
Check the resistance on your coil? I have a theory that they get a little out of spec and then when they get too hot (heat increases resistance) they get too far out of spec, then will work again when they cool down- for a little while.
I'd also just because it would make me feel like I was doing something and could be the problem do the following:
- Wiggle the ECU connection in the engine bay.
- Check the central wire on the distributor, but that's because mine is a little loose and doing this actually worked once.
- Check the wires at the starter. If the ignition signal one is loose, it can cause intermittent starting issues.
- Change the ignition switch. Just plug the new one in and cheat start with the tool that does so.
Probably before all that, I'd run a VCDS check, because I own it. Can't hurt.
After that, I'd check my tempII sensor, since it's tied to the starting circuit and also is in play for the first minute of running. The 02 sensor could affect the first minute of running, but usually not starting, I think.
If it's still not running, dammit. Time to dig deeper, which I'd be figuring out. _________________ 1991 Vanagon GL 2.1 AT Westfauxlia. "Frankie" Totaled https://www.thesamba.com/vw/forum/viewtopic.php?t=764510&highlight=carnage
subdewd Samba Member
Posted: Tue May 09, 2023 4:29 am Post subject: Re: Drive 30 miles to beach and no start/ hard strart. |
Classic symptom of bad coil on 95. Or distributer pickup |
Zeitgeist 13 Samba Member
Posted: Tue May 09, 2023 4:55 am Post subject: Re: Drive 30 miles to beach and no start/ hard strart. |
Ignition switch _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
volkybus Samba Member
Joined: November 03, 2013 Posts: 481 Location: CASTLETON VT USA
Posted: Wed May 10, 2023 8:23 pm Post subject: Re: Drive 30 miles to beach and no start/ hard strart. |
Well my 95 Jetta does the same thing on startup,but only from time to time..my Eurovan (93) never does that.I swapped out the coil and same I end up unplugging the fuel pump and then it runs fine till I run out of fuel so then I plug it back in and after a couple of cycles like that it runs perfect till it repeated itself ,some time later .It's been this way since I installed another ECU Over a year ago.fuel pressure is steady around 40psi.. PERHAPS U COULD TRY THAT...unplugging the fuel pump or pulling the fuse out .5th one from the rt. on the jetta..same I think on EV but double check..GOOD LUCK Bill PR & Vt |
EuroTec Samba Member
Joined: August 24, 2020 Posts: 382 Location: Asheville, North Carolina
Posted: Thu May 11, 2023 4:07 am Post subject: Re: Drive 30 miles to beach and no start/ hard strart. |
Ignition coil. Swap in a new one. They go bad, often. _________________ If it ain't broke, don't fix it! |
Posted: Fri May 12, 2023 4:32 am Post subject: Re: Drive 30 miles to beach and no start/ hard strart. |
I would get a coil, even if it isn't the problem, they are inexpensive easy to swap, and you're going to need one sooner or later. I carry a spare with me. Saved my bacon on 2 occasions |
VWinny Samba Member
Posted: Sat May 20, 2023 3:14 pm Post subject: Re: Drive 30 miles to beach and no start/ hard strart. |
I installed a new NGK coil pack and engine is running great, i took it for a long drive and noticed it also stays much cooler it is built with a casing that radiates heat better, and the quality of the starter you can see is much better than most others.
Great advice on the second coil pack carry.
I carry an extra IAC, Starter, belt and now will be adding the coil pack to my tool box!
thanks everyone for great info |
Posted: Sat May 20, 2023 4:26 pm Post subject: Re: Drive 30 miles to beach and no start/ hard strart. |
Good newy |
