madmike Samba Member
Joined: July 11, 2005 Posts: 5292 Location: Atlanta,Michigan
Posted: Thu May 11, 2023 5:22 pm Post subject: CDI boxes |
Casper love'em, eats them like there going out of style
I've had at least 6 or 7 boxes take a shit. all diff. MSD 6al, ate two of them, sent them in to MSD both had diff. issues , mallory's work the longest, got a couple years out of a brand new Mallory 6al box, then I had a hankering to try a 2step so i hooked up a MSD 7 box worked great for about 200 miles, had to 'Walk' home today ,bug was running great today, acted like I just reached up and shut it off yesterday it started to miss ,spit & backfire slightly ,then pick up and run so so,, always missing ,, ran fine when cooled down again,, swapped coils twice, I was about 40 miles from home, but it ran good enuff to get me home MSD dizzy was bought new years ago boxes were all rubber mounted too., Any guesses?????, I'm going to slap in my last Mallory box or an 009 I have to pick up my grandson from skool tomorrow
_________________ 'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9767 Location: Oregon
Posted: Thu May 11, 2023 5:50 pm Post subject: Re: CDI boxes |
Have you thought abut trying a different brand of CDI?
Maybe a Crane Hi6N will last a little longer than the MSD/Mallory units you have been killing with reckless abandon!
Or reach out to Jon Miller and see if he can build something a little more sturdy than what you were running. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
Posted: Thu May 11, 2023 6:08 pm Post subject: Re: CDI boxes |
was thinking about it but i like the features,like a 2 step _________________ 'Black Ice'Drag Buggy 'Turbo'
jpaull Samba Member
Joined: February 22, 2005 Posts: 3465 Location: Paradise, Ca
Posted: Thu May 11, 2023 7:13 pm Post subject: Re: CDI boxes |
Hey Mike, if your able to kill a MSD 7al within 2 years. The problem is not the box |
Joined: May 17, 2003 Posts: 4863 Location: Harmony, PA
Posted: Thu May 11, 2023 7:52 pm Post subject: Re: CDI boxes |
I would create some new, and over redundant grounds. Also check for anywhere the spark from the coil could be arcing to ground. They don’t like odd voltage spikes. Maybe try using the ignition wire to trip a relay to turn the box on.
I’ve known numerous people that have killed MSD boxes by doing a quick weld somewhere on the car with the electrical system fully hooked up.
I’ve seen poor/nonexistent engine grounds arc through throw out bearings. |
stevemariott Samba Member
Joined: November 09, 2003 Posts: 1052 Location: Portland, OR
Posted: Thu May 11, 2023 10:00 pm Post subject: Re: CDI boxes |
Mike,
I don't have the CDI knowledge that others do, but I made sure to ground my old Mallory Hyfire 6a directly to the battery per the instructions - no issues here. Double check your grounding. _________________ 1963 Manx copy
1968 Bus |
mikedjames Samba Member
Joined: July 02, 2012 Posts: 2742 Location: Hamble, Hampshire, UK
Posted: Fri May 12, 2023 12:18 am Post subject: Re: CDI boxes |
As they say.. if you are killing so many CDI boxes the problem lies outside the boxes...
Voltage regulator issues causing high voltages and or voltage spikes on DC feed.
Earthing layout causing voltage spikes on DC feed ?
I mess a lot with electronics around the engine and I have found fitting an 18 volt Transient Voltage Suppressor diode across the DC feed to electronics in the engine bay gets rid of a lot of problems.. these are like grown up Zener diodes.. the 600 size can dump 600 watts of power for a short time, about 2 watts average. _________________ Ancient vehicles and vessels
dunk Samba Member
Posted: Fri May 12, 2023 1:59 am Post subject: Re: CDI boxes |
Adding to what the above has to say... regardless of box manufacturer, they will want a smooth input..i.e. no surges in the supply...
Maybe try a smoothing capacitor, or "noise filter" as I believe msd call it... most of the cdi box companies have offered one... or just use a capacitor of a relevant spec..
I have a generic capacitor on mine... have used crane and msd boxes through it... no problems as of yet....
https://www.erareplicas.com/427man/wiring/msd-install.htm
The above is worth a read..
Fred Winterburn Samba Member
Joined: April 17, 2013 Posts: 423 Location: Ripley Ontario Canada
Posted: Fri May 12, 2023 3:18 am Post subject: Re: CDI boxes |
Heat is another electronics killer. Do you have it mounted in a cool enough location? Fred |
Posted: Fri May 12, 2023 4:18 am Post subject: Re: CDI boxes |
Hey Jeff, 7 box, try 200 miles not 2 years
Fred, I mount them in the Back seat area , see Photo above,,I'll recheck all grounds today :wink
No welding on the bug,, all wire's installed properly,,,checked a thousand times _________________ 'Black Ice'Drag Buggy 'Turbo'
Posted: Fri May 12, 2023 4:52 am Post subject: Re: CDI boxes |
Probably voltage spikes then as mentioned already. However most CDIs have built in filtering. Yet another possibility are misfires due to too wide a plug gap that could stress the discharge capacitor or whatever switching means is being used, IE SCR for example. It could also stress the power supply depending on the design. That's not as likely a scenario though and you would likely notice the misfires if they are frequent enough to damage the unit. Fred
madmike wrote: |
No welding on the bug,, all wire's installed properly,,,checked a thousand times |
Posted: Fri May 12, 2023 5:12 am Post subject: Re: CDI boxes |
Perhaps your coil is leading to the short life spans? Some CDI coils aren't much better than dead shorts on the output which will stress components within the CDI. A slightly tamer coil might be all it takes if that is the issue. Fred
Fred Winterburn wrote: |
madmike wrote: |
Clatter Samba Member
Joined: September 24, 2003 Posts: 7544 Location: Santa Cruz
Posted: Fri May 12, 2023 8:14 am Post subject: Re: CDI boxes |
Could a janky VW ignition switch kill a CDI?
Ignition switches on these old cars can be intermittent on a good day..
There’s also the big black wire that usually feeds the coil a.k.a. “Old crispy”. _________________ Bus Motor Build
What’s That Noise?!? |
Posted: Fri May 12, 2023 9:07 am Post subject: Re: CDI boxes |
I have a 'switch panel' no stock vw ignition switch
Thinking about pulling that Alternator,because, well just Because
Fred I've tried 2 different coils _________________ 'Black Ice'Drag Buggy 'Turbo'
chrisflstf Samba Member
Joined: February 10, 2004 Posts: 3442 Location: San Diego
Posted: Fri May 12, 2023 9:12 am Post subject: Re: CDI boxes |
Failing alternators can put out over 18vdc |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13278 Location: Tejas!
Posted: Fri May 12, 2023 9:19 am Post subject: Re: CDI boxes |
I'm with the above on the grounds
I'd think you would fry batteries if it was alternator over current |
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7215 Location: Videbaek Denmark
Posted: Fri May 12, 2023 9:30 am Post subject: Re: CDI boxes |
I´m with Fred on the ground. But it is not just the box that needs good ground. The engine/transmission needs good ground too. Both rust, paint and sloppy ground wires can be the reason to not sufficient ground.
When using especially powerfull CDI´s i always add a second ground between trans and chassis. _________________ https://www.thesamba.com/vw/forum/viewtopic.php?t=435993 |
Posted: Fri May 12, 2023 10:44 am Post subject: Re: CDI boxes |
That wasn't my suggestion but it certainly is something to check. Without a good ground for the case, high voltage might try to sneak back via a more delicate part of the circuit. Fred
Alstrup wrote: |
When using especially powerfull CDI´s i always add a second ground between trans and chassis. |
VdanielW Samba Member
Posted: Fri May 12, 2023 12:56 pm Post subject: Re: CDI boxes |
I'm running the summit racing cdi box in my daily driver and seems to be doing good. My fitech unit handles rev limiter and 2 step if I wanted to hook it up.
Don't you have a mallory hyfire VI? |
74 Thing Samba Member
Posted: Fri May 12, 2023 1:39 pm Post subject: Re: CDI boxes |
Where are your grounds?
Do they ground to the body or the floorpan or both?
I would ground them to the battery or the panel that the battery is grounded to (eg floor pan). I know the body is supposed to be grounded to the floor pan through the body mounting bolts but there is corrosion there so I ran a separate ground wire on mine from the body to the battery floor pan grounding point. |
