Frame number start by "POS"
ostrogoth
ostrogoth is offline
PostPosted: Thu May 11, 2023 10:00 pm    Post subject: Frame number start by "POS" Reply with quote
Hi
I got a frame here that has the number POS more 4 number. Can anyone help with this frame ? Best regards
VW_Jimbo Premium Member
VW_Jimbo is offline
PostPosted: Thu May 11, 2023 10:32 pm    Post subject: Re: Frame number start by "POS" Reply with quote
Maybe a picture? Maybe read that sentence out loud to yourself. That has helped me several times, to help hear how a written sentence, sounds. I have read what you typed, but do not understand what is being asked.
Jimbo
TDCTDI wrote:
67rustavenger wrote:
djfordmanjack
djfordmanjack is offline
PostPosted: Fri May 12, 2023 3:07 pm    Post subject: Re: Frame number start by "POS" Reply with quote
That sounds like a factory exchange/ replacement chassis. Many reconditioned engines have 'POS' numbers re-stamped, where once the og engine number was located.
62 Dickholmer, custom color Seeblau L360
janerick3
janerick3 is offline
PostPosted: Fri May 12, 2023 7:59 pm    Post subject: Re: Frame number start by "POS" Reply with quote
Wasn't POS Salzburg?
Thanks,
Jan K.
Grot
Grot is offline
PostPosted: Thu May 25, 2023 12:54 am    Post subject: Re: Frame number start by "POS" Reply with quote
I managed to secure a NOS floorpan for my 1954 cabrio. It came from a VW dealer's spare parts store. It has an extra number stamped on the tunnel between the gearstick and the handbrake that I have never seen on any other tunnel. I assume it was identifying a spare part. The number stamped on mine is -KU-U222
65-
redmain
redmain is offline
PostPosted: Thu May 25, 2023 10:48 am    Post subject: Re: Frame number start by "POS" Reply with quote
I have a 56 Oval with the prefix POS, I was told it was a factory replacement chassis
txoval
txoval is offline
PostPosted: Fri May 26, 2023 8:27 am    Post subject: Re: Frame number start by "POS" Reply with quote
That’s crazy but interesting
A replacement chassis…the body had to be destroyed if the chassis needed to be replaced
splitjunkie
splitjunkie is offline
PostPosted: Fri May 26, 2023 9:53 am    Post subject: Re: Frame number start by "POS" Reply with quote
Says who?
Chris
txoval
txoval is offline
PostPosted: Fri May 26, 2023 10:07 am    Post subject: Re: Frame number start by "POS" Reply with quote
I’m just saying it would take a lot for the chassis to be replaced…bent forks/napoleon hat/torsion bar housing failure
splitjunkie
PostPosted: Fri May 26, 2023 10:47 am    Post subject: Re: Frame number start by "POS" Reply with quote
OK.
You could have rust damage as well. It's hard to comprehend how much the repair bill would be for replacing a pan, but VW did supply pans as well as body shells so there must have been enough call for those parts for them to bother supplying them.
Chris
