BWingate Samba Member
Posted: Mon May 15, 2023 5:48 am Post subject: Sudden Power Loss Then Poor or No Starting |
1974 SB with 1600 DP, as stock as can be expected on a 50 year old engine.
Cold starts like a champ, idles a little high but starts and runs for about 10-15 minutes and then starts to buck and lose power at 40-45 mph. This quickly gets progressively worse. After letting it sit for a while, its a really hard start with no real power. There is fuel in the fuel filter. Let is sit over night and it is fine and then starts all over again.
I first thought I was low on gas, but fresh gas in the tank didn't help.
This car sits way more than I would like. I cleaned the carb. My plan over the next few days is to do a full tune up (rotor, cap, coil, condenser, set timing) and adjust the valves (I don't know why, but this sounds like tight valves).
Any other low hanging fruit I should look at?
Tougher problems to think about?
Thanks all,
Bruce. |
Rickf1985 Samba Member
Posted: Mon May 15, 2023 5:53 am Post subject: Re: Sudden Power Loss Then Poor or No Starting |
Two things come to mind, clogged fuel filter or coil going bad with a leaning towards the bad coil. |
sb001 Samba Member
Posted: Mon May 15, 2023 6:01 am Post subject: Re: Sudden Power Loss Then Poor or No Starting |
This sounds strangely familiar...
Coil would be my first suspicion as well, I'd say do a resistance check on the windings but it would have to be when the car is having the problem, not when cold. _________________ I'm the humblest guy on this board.
1600 SP engine
Solex 30 PICT 3 carburetor
Posted: Fri May 26, 2023 3:30 am Post subject: Re: Sudden Power Loss Then Poor or No Starting |
Thanks for the replies - got around to changing the coil yesterday and it seems better. It starts and idles well. Test drive today after work to see if that was it. |
