Yabbadubbadoo Samba Member
Posted: Mon May 22, 2023 1:35 am Post subject: CB shorty IDF manifolds on 049 RM heads tight access issues |
Has anyone here done CB shorty IDF manifolds on Revmaster 049 heads? My DRD heads based on the 049 RM castings with 12mm plugs has virtually no space for plug leads and accessing the studs to bolt the manifolds down. My engine builder thinks I'll hate it. Reckons it's near impossible to fit the leads. Will surely also require full removal of the carbs and inlet manifolds to get at the spark plugs. I haven't been able to check it out yet but it has me concerned.
Can anyone here shed some light on the issue?
_________________ Sydney, Australia.
66 Type 3 Fastback |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13247 Location: Tejas!
Posted: Mon May 22, 2023 6:21 am Post subject: Re: CB shorty IDF manifolds on 049 RM heads tight access issues |
yes, everyone with IDF's / DRLA's on a type 3 has this issue |
VWporscheGT3 Samba Member
Joined: September 01, 2006 Posts: 2073 Location: Gardnerville, NV
Posted: Mon May 22, 2023 9:58 am Post subject: Re: CB shorty IDF manifolds on 049 RM heads tight access issues |
Yabbadubbadoo wrote: |
I used a wobly and shortish spark plug socket, to break them loose, then i jam a piece of fuel line on the end and twist it out , the reverse for install. it can be done with the carbs in place... not fun, requires a certain level of patience but it can be done _________________ Schnell, SCHNELL!
I like being wrong, Because, it is another opportunity to learn. If you stop learning from your mistakes than what is the point?
If you have any questions about Forged ICON 4032 VW pistons just shoot me a line. |
Erik G Samba Member
Posted: Mon May 22, 2023 10:12 am Post subject: Re: CB shorty IDF manifolds on 049 RM heads tight access issues |
VWporscheGT3 wrote: |
I used a wobly and shortish spark plug socket, to break them loose, then i jam a piece of fuel line on the end and twist it out , the reverse for install. it can be done with the carbs in place... not fun, requires a certain level of patience but it can be done |
also gotta cut the intake studs short as possible and use the tiny nuts with the flange, they really help https://www.thesamba.com/vw/classifieds/detail.php?id=929112
_________________ Stop dead photo links! Post your photos to The Samba Gallery! |
Posted: Mon May 22, 2023 12:27 pm Post subject: Re: CB shorty IDF manifolds on 049 RM heads tight access issues |
Erik G wrote: |
Yeah I'm starting to figure that out. I guess it's the price you pay for a rear trunk. _________________ Sydney, Australia.
Posted: Mon May 22, 2023 12:30 pm Post subject: Re: CB shorty IDF manifolds on 049 RM heads tight access issues |
Erik G wrote: |
Thanks for the tips. Exactly what I need. Did you have to do any mods to the cooling tins behind the manifold? _________________ Sydney, Australia.
Erik G Samba Member
Posted: Mon May 22, 2023 1:00 pm Post subject: Re: CB shorty IDF manifolds on 049 RM heads tight access issues |
It's been a while but yes I remember some dimpling and trimming of the dual port tin piece that looks like a mustache? _________________ Stop dead photo links! Post your photos to The Samba Gallery! |
Posted: Mon May 22, 2023 1:23 pm Post subject: Re: CB shorty IDF manifolds on 049 RM heads tight access issues |
Erik G wrote: |
It's been a while but yes I remember some dimpling and trimming of the dual port tin piece that looks like a mustache? |
I concur. tin snip time just sneak up on it, it didnt take much to finally clear _________________ Schnell, SCHNELL!
Posted: Mon May 22, 2023 2:56 pm Post subject: Re: CB shorty IDF manifolds on 049 RM heads tight access issues |
Erik G wrote: |
I concur. tin snip time just sneak up on it, it didnt take much to finally clear |
Erik G wrote: |
Thanks for the info guys. Much appreciated. _________________ Sydney, Australia.
W1K1 Samba Member
Joined: March 04, 2004 Posts: 4897 Location: Southern AB
Posted: Tue May 23, 2023 1:46 pm Post subject: Re: CB shorty IDF manifolds on 049 RM heads tight access issues |
aircraft nuts with the wobble and a 10" extension, and pull the carbs/manifold when you want to change the plugs
keep a supply of manifold gaskets, and it's a fun job getting the plug wires on/off
_________________ http://www.thesamba.com/vw/archives/manuals/jim_martin_engine_build.php
1973 super
1965 squareback 1500E
1971 bay window westy- subi swap |
Posted: Wed May 24, 2023 3:34 am Post subject: Re: CB shorty IDF manifolds on 049 RM heads tight access issues |
W1K1 wrote: |
Thanks for the tips. Fun job eh! 😖 _________________ Sydney, Australia.
Erik G Samba Member
