vdubjiunkie Samba Member
Joined: August 03, 2017 Posts: 99 Location: Northwest Arkansas
Posted: Mon May 22, 2023 5:55 am Post subject: Inside scraper madness |
Hey all,
I'm doing the door seals on my '64 notch, and yes it's challenging, but it's not like I'm pulling out the really choice turns of phrase.
That said, I see no earthly way that the clips on these bus scrapers, which also kind of work for Type 3s are supposed to securely lock into position, and not pop out forever again and again.
I have adjusted the arc between the end of each clip as it bends toward the "straight" piece between each clip, so they lay more flat, but it really doesn't seem to be enough.
One side of each clip sticks up more than the other side, which seems to work against the idea that they would lock into position.
Has anybody else worked with these, and maybe have a tip for what it is that I'm missing?
_________________ 1964 Type 3 Notchback
1969 Karmann Ghia shell in need of full body off restoration
2004 WRX
"It Is Difficult to Get a Man to Understand Something When His Salary Depends Upon His Not Understanding It" - Upton Sinclair |
notchboy Samba Member
Joined: April 27, 2002 Posts: 22449 Location: Escondido CA
Posted: Mon May 22, 2023 7:57 am Post subject: Re: Inside scraper madness |
Do you still have the original wire from the OG one? The OG ones always hold way better than this cross over bay window bus stuff available now. _________________
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
Erik G Samba Member
Joined: October 16, 2002 Posts: 13271 Location: Tejas!
Posted: Mon May 22, 2023 8:12 am Post subject: Re: Inside scraper madness |
yeah gotta re-use OG wires in the new rubber |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22413 Location: Kimball, Mi
Posted: Mon May 22, 2023 12:57 pm Post subject: Re: Inside scraper madness |
Erik G wrote: |
Yup, you gotta use the type 3 wires and cut new slots in the rubber for the wire to align with the slots in the door. It's kind of fiddly work, but they can work. Just remember that the bus rubber is longer and has to be cut down too. I cut it at the wing window. The outer seal is a real PIA to do.
I think I've got pics on page 18 of my 71 Notch rebuild of doing the doors and seals. The link in my signature will take you to the build thread.
I hope this helps. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Mon May 22, 2023 8:29 pm Post subject: Re: Inside scraper madness |
Funny story. I’m a recovering hoarder, and I actually threw away my inside scrapers some time ago. However, when I pulled my outside scraper the other day, I retained the clips from that.
I’m not sure if they are the same ones used on the inside scraper, but they certainly do fit the holes. They are now swimming in evaporust!
2004 WRX
andybla Samba Member
Posted: Tue May 23, 2023 12:36 am Post subject: Re: Inside scraper madness |
also used my og wire, much better, new wire sucks |
Posted: Tue May 23, 2023 4:19 pm Post subject: Re: Inside scraper madness |
vdubjiunkie wrote: |
You want to hang onto those as they fit the door very well.
I believe the bus wires could be used, but you'll want to check them against the slots in the door. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
