cafo76 Samba Member
Joined: April 23, 2012 Posts: 12 Location: Tustin, CA
Posted: Tue May 23, 2023 5:58 pm Post subject: Rattle in vent wing hardware |
It appears that the vent wing pivot rivet hardware is loose and rattling. Any guidance on how to tighten? Is that even possible? The loose section is on the upper bracket? Can I expose the rest of the hardware behind the rubber seal. Any guidance is much appreciated.
_________________ Late 68-69, Type 3 Fastback, Automatic.
Always a work in progress.. |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22413 Location: Kimball, Mi
Posted: Tue May 23, 2023 7:07 pm Post subject: Re: Rattle in vent wing hardware |
It depends on whether the fiber washer is still in between those 2 tabs. If it is, you could clamp down on the rivet with some vice grips to try and tighten it up.
If the fiber washer is gone, you'll need to replace it and the rivet.
I hope this helps. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
cafo76 Samba Member
Posted: Wed May 24, 2023 7:02 pm Post subject: Re: Rattle in vent wing hardware |
Bobnotch wrote: |
I hope this helps. |
Much appreciate the input Bobnotch...my follow up question is that the "jiggle" is not felt at the joint of the rivet, but at the upper bracket connecting to the door frame (covered by the rubber seal). Is there something that can be tightened in there? Thanks _________________ Late 68-69, Type 3 Fastback, Automatic.
Posted: Thu May 25, 2023 11:42 am Post subject: Re: Rattle in vent wing hardware |
cafo76 wrote: |
Bobnotch wrote: |
Much appreciate the input Bobnotch...my follow up question is that the "jiggle" is not felt at the joint of the rivet, but at the upper bracket connecting to the door frame (covered by the rubber seal). Is there something that can be tightened in there? Thanks |
To be honest, I've never ran into a problem of the upper "hinge" half being loose, but I suppose there's a rivet or 2 hiding behind the seal that could be tightened up with a hammer and punch. I only say that, as the wing windows were made up of multiple parts that were riveted together. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
