ggolds5 Samba Member
Joined: April 12, 2022 Posts: 97 Location: Farmington, CT
Posted: Wed May 24, 2023 9:54 pm Post subject: Steering box, new install. Clicks and odd play. |
HI all. So I've had my Bus with a local "guru". Everyone in the clubs in Connecticut and Mass love this person. I do to. So that said. He installed a new steering box in my 76 Bay Westy. The previous box was great, but leaked. Since it apparently was more time and work to just replace the seals in the old one, he just ordered a new one for me. I was good with that. I just got the Bus back. It now has an odd sensation when turning. I'll be turning and suddenly there is a 1-2 inch "slip" feeling. Another words, it just lets go for a small amount of the turn and then is normal. In addition, there is a disconcerting CLICK in turns also. He says it's an adjustment needed but I can't quite figure out how this could be just an adjustment. Am I wrong, and could this be a major safety issue?. How can this be fixed, and keep in mind, the box is a newly purchased professionally rebuilt unit by a very reputable company. He is very anal about where to buy parts. ANY help is much appreciated. What should I do prior to him getting this back and making an adjustment etc. |
SGKent Samba Member
Posted: Wed May 24, 2023 11:44 pm Post subject: Re: Steering box, new install. Clicks and odd play. |
take it back to him and explain it. Anything less is wasting your time. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22665 Location: NYC/Upstate/ROW
Posted: Thu May 25, 2023 1:40 am Post subject: Re: Steering box, new install. Clicks and odd play. |
Gurus are still human, and letting a Bus out of a shop like this just proves that point. Back it goes, on a flatbed so you don’t hurt others.
Waiver if it is less than 5 KM and under 50 KM per hour to shop _________________ .ssS! |
richparker Samba Member
Joined: November 24, 2011 Posts: 6982 Location: Durango, CO
Posted: Thu May 25, 2023 6:08 am Post subject: Re: Steering box, new install. Clicks and odd play. |
Many of us fill our leaking boxes with grease instead of oil. Lots of threads here on the samba about it and what grease to use.
Good luck! _________________ __________
’71 Westy build
Adventure thread
’65 Deluxe Build
’63 Deluxe Build |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21518 Location: Oklahoma City
Posted: Thu May 25, 2023 6:16 am Post subject: Re: Steering box, new install. Clicks and odd play. |
Not from a bus....but from an acvw.
Many years ago after having the steering box out and back in.....I had that same 1-2" slip feeling only when turning either sitting still or at very low speed when there is a lot of tire friction to overcome.
Turned out.....I had forgotten to re-install the cross bolt that went through the splined yoke that connected steering column to the steering box. They have a little slack and without the cross bolt can rotate about 1/3 of a clock position each direction.
Worth checking. But yes....take it back to who worked on it. Ray |
Joined: January 01, 2007 Posts: 16878 Location: sticksville, ct.
Posted: Thu May 25, 2023 7:09 am Post subject: Re: Steering box, new install. Clicks and odd play. |
sorry
time for a new "guru"
any asshole that lets bad steering out of the shop needs a 27mm wrench across the teeth
I have yet to find a "reputable" rebuilder for these boxes and when I build them, it takes 4-5 cores to build 1 and by the time the parts and machining come together they are close to 1k for a rebuilt box
there is absolutely no adjustment that is going to fix your complaint. either the pinch bolt isn't tight or there is something horribly wrong with the steering box.
so sick of people getting a "pass" because "he's a 'guru'" or a "nice guy" _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
W1K1 Samba Member
Joined: March 04, 2004 Posts: 4921 Location: Southern AB
Posted: Thu May 25, 2023 7:43 am Post subject: Re: Steering box, new install. Clicks and odd play. |
that should have been as simple as draining the existing oil, and filling it with grease, and putting it back in. _________________ http://www.thesamba.com/vw/archives/manuals/jim_martin_engine_build.php
1973 super
1965 squareback 1500E
1971 bay window westy- subi swap |
orwell84 Samba Member
Joined: May 14, 2007 Posts: 2537 Location: Plattsburgh, New York
Posted: Thu May 25, 2023 7:47 am Post subject: Re: Steering box, new install. Clicks and odd play. |
I’m no guru, but after fixing something on my bus, I go for a test drive; first somewhere safe and close to home, in case the wheels come off. Then, actual driving with other cars and people.
I agree that you should first take it back to the mechanic for a solution.
I had the same issue with my steering box. It wouldn’t hold oil. I could order one on eBay and get a turd, or a super duper expensive one and get a turd or spend the summer hunting down 5 used turd boxes to build 1 ok box. I have absolutely no confidence whatsoever that spending good money for a steering box will result in a good one arriving at my door.
I filled it with corn head grease. So far it has stayed in. |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16970 Location: San Diego, California
Posted: Thu May 25, 2023 7:53 am Post subject: Re: Steering box, new install. Clicks and odd play. |
I’ll bet you steering coupler is folding. Get a genuine one with the VW logo _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
mikedjames Samba Member
Joined: July 02, 2012 Posts: 2742 Location: Hamble, Hampshire, UK
Posted: Thu May 25, 2023 10:51 am Post subject: Re: Steering box, new install. Clicks and odd play. |
If you fail to fully torque up the fixing bolts for your steering box, it can give suddenly as the whole thing rotates a fraction.
A clue is that the position of the steering wheel driving straight on a flat road will be different each time you go out after one of these jumps.
I managed this by forgetting the fourth bolt on the final tightening...
I used the ' feature' to straighten up the steering wheel so spokes were horizontal straight ahead before I re torqued the bolts. _________________ Ancient vehicles and vessels
oscarsnapkin Samba Member
Joined: October 22, 2013 Posts: 558 Location: Bucks County, PA
Posted: Thu May 25, 2023 4:13 pm Post subject: Re: Steering box, new install. Clicks and odd play. |
aeromech wrote: |
I’ll bet you steering coupler is folding. Get a genuine one with the VW logo |
Definitely worth a check. I had a similar issue on an International truck a few years back that was caused by the steering column not being pressed all the way onto the input shaft on the steering box. This caused too harsh of an angle at the u-joint creating symptoms similar to the OP. Skills is right though, if the ‘guru’ did the work himself and let it leave his shop like this he needs a beating. Steering and brakes are life and death, not just yours but my kids’ as well. Let us know the outcome. _________________ - 1977 CEI Sunroof Bus 2.0L F.I. Hydraulic Lifters
- 1973 Thing
"It’s so easy to laugh, it’s so easy to hate, it takes strength to be gentle and kind." |
Xevin Samba Member
Posted: Thu May 25, 2023 5:23 pm Post subject: Re: Steering box, new install. Clicks and odd play. |
Just curious of what year bus this is? What brand of steering box? Was it rebuilt in Northern California? _________________ Keep on Busin'
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Clatter wrote: |
Damn that Xevin... |
skills@eurocarsplus wrote: |
SGKent wrote: |
Posted: Thu May 25, 2023 5:32 pm Post subject: Re: Steering box, new install. Clicks and odd play. |
Xevin wrote: |
Just curious of what year bus this is? What brand of steering box? Was it rebuilt in Northern California? |
New steering boxes for late bays are readily available. _________________ __________
’71 Westy build
Adventure thread
’65 Deluxe Build
’63 Deluxe Build |
Xevin Samba Member
Posted: Thu May 25, 2023 5:42 pm Post subject: Re: Steering box, new install. Clicks and odd play. |
richparker wrote: |
Xevin wrote: |
New steering boxes for late bays are readily available. |
Thanks Rich, I kept missing the 76 in his post. I looked and looked _________________ Keep on Busin'
Clatter wrote: |
SGKent wrote: |
Posted: Sat May 27, 2023 10:23 pm Post subject: Re: Steering box, new install. Clicks and odd play. |
aeromech wrote: |
When you say the steering box is folding, can you explain further what that means?. Thanks. |
Posted: Sat May 27, 2023 10:26 pm Post subject: Re: Steering box, new install. Clicks and odd play. |
Xevin wrote: |
Going there on Wed. Not sure how to answer your questions other than to say that it is a VW Box not a repro. I'll find out where he got it, and look at it with him. Thanks for asking. |
Posted: Sat May 27, 2023 10:29 pm Post subject: Re: Steering box, new install. Clicks and odd play. |
richparker wrote: |
Good luck! |
I wish I had just left the leaky box in there , it worked great otherwise. The "NEW" box doesn't leak but is disconcerting to drive with the click and odd slip feeling. Going there on Wed. Hopefully it will be all sorted out by then. |
Posted: Sun May 28, 2023 11:46 am Post subject: Re: Steering box, new install. Clicks and odd play. |
I said that your steering coupler might be folding. Not steering box.
https://www.thesamba.com/vw/forum/viewtopic.php?t=435679&highlight=steering+coupler _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Posted: Sun May 28, 2023 1:08 pm Post subject: Re: Steering box, new install. Clicks and odd play. |
Another thought is that if the box is OK, the new box is showing up other defects in the remainder of the steering:
Drag link rod ends loose.
Centre pivot pin and bushings worn.
Track rod ends loose.
Ball joints worn.
You did not notice them before but now the box is not clunking away, you can hear the rest ... _________________ Ancient vehicles and vessels
