cafo76 Samba Member
Joined: April 23, 2012 Posts: 12 Location: Tustin, CA
Posted: Wed May 24, 2023 9:55 pm Post subject: Window regulator clean/lube/love |
Can anyone direct me to a decent resource (video if possible) or previous post on a step wise removal and proper clean and lube of the window regulator for a 1969 Fastback? I'm pretty clear on door panel removal. But specifically, not coming up with much on youtube as to the regulator. Any help is appreciated. _________________ Late 68-69, Type 3 Fastback, Automatic.
Always a work in progress.. |
andybla Samba Member
Posted: Thu May 25, 2023 2:17 am Post subject: Re: Window regulator clean/lube/love |
it's the same principle as in beetle's etc so those movies will work also
wind window down, remove 4 bolts and slide it out the window frame, i put grease on the whole spring assy |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Thu May 25, 2023 11:22 am Post subject: Re: Window regulator clean/lube/love |
Take it apart and clean/lube everything.
You have wing window problems anyway.
I like to clean greasy parts in a drain pan with gasoline/tooth brush.
Clean out the drain holes in the bottom of the doors. _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Bobnotch Samba Member
Posted: Thu May 25, 2023 11:53 am Post subject: Re: Window regulator clean/lube/love |
Mike Fisher wrote: |
Clean out the drain holes in the bottom of the doors. |
This one especially, as most of our cars have a layer of dirt along the bottom waiting for some water to keep it wet and start to rust. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
gt1953 Samba Member
Posted: Thu May 25, 2023 7:16 pm Post subject: Re: Window regulator clean/lube/love |
After cleaning and reassembly, do a good job on the vapor aka plastic sheet. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
cafo76 Samba Member
Posted: Mon May 29, 2023 8:15 pm Post subject: Re: Window regulator clean/lube/love |
Got them out, nicely cleaned and lubed...wow what a difference. One of the tension coils still has sounds a little crackly for lack of a better word...sometimes it is what it is.
Many thanks for the input. _________________ Late 68-69, Type 3 Fastback, Automatic.
