BanjoMan64 Samba Member
Joined: November 21, 2021 Posts: 8 Location: Oklahoma
Posted: Thu May 25, 2023 2:00 pm Post subject: Advisable to open/rebuild transaxle if no known issues? |
This is my first restoration, and I’m still very new to everything. I’ve been rebuilding a 64’ beetle for the last two years. I have the body off the chassis right now, and I’m wondering if I should open up the transaxle. The car was running and driving before I starting rebuilding it and didn’t seem to have any issues shifting into all four gears.
I have some mechanic friends telling me that I should open up the transaxle and check for any wear while it’s out and accessible. However, I also have other mechanic friends telling me that if there aren’t any issues I should leave it be and save myself the hassle of rebuilding it. Neither of these friends have worked on beetles, though.
What is typically advisable in this instance? Is there anything on the transaxle that should be routinely replaced/inspected? Or should I leave it until it gives me cause for concern? |
SLO-N-LO-69 Samba Member
Joined: July 06, 2006 Posts: 629 Location: Central Florida
Posted: Thu May 25, 2023 2:08 pm Post subject: Re: Advisable to open/rebuild transaxle if no known issues? |
The trans and engine are the only part of my 73 I didn't rebuild after a 5 year sit. They ran fine before so I threw them back in and everything is fine to this day. I would leave it alone. |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31378 Location: Hot Arizona
Posted: Thu May 25, 2023 2:29 pm Post subject: Re: Advisable to open/rebuild transaxle if no known issues? |
SLO-N-LO-69 wrote: |
I also would not "open" it up. I would change the gear oil though, and check the drive axle boots. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9770 Location: Oregon
Posted: Thu May 25, 2023 5:56 pm Post subject: Re: Advisable to open/rebuild transaxle if no known issues? |
Another vote for, "If it ain't broke. Don't fix it!"
Change the gear lube, install new axle boots and call it, "Good to go." _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
esde Samba Member
Joined: October 20, 2007 Posts: 5969 Location: central rust belt
Posted: Thu May 25, 2023 7:17 pm Post subject: Re: Advisable to open/rebuild transaxle if no known issues? |
Change the fluid and drive it. If there are big chunks in the fluid, make a mental note that a rebuild may be in the future. Same if it whines or is noisy..
But if it shifts between all gears without grinding, don't mess with it. _________________ modok wrote:
gt1953 Samba Member
Posted: Thu May 25, 2023 7:24 pm Post subject: Re: Advisable to open/rebuild transaxle if no known issues? |
Agreed change fluid drive it for a while thousand miles or two change it again. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
wdfifteen Samba Member
Posted: Sat May 27, 2023 9:30 am Post subject: Re: Advisable to open/rebuild transaxle if no known issues? |
Cusser wrote: |
I also would not "open" it up. I would change the gear oil though, and check the drive axle boots. |
There you go. Do this. |
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9966 Location: Huntington Beach, CA
Posted: Sat May 27, 2023 10:18 am Post subject: Re: Advisable to open/rebuild transaxle if no known issues? |
Stick it in the car. Fill it up with gear oil. Drive it as is. It will most likely live past this restoration, too! Next time you restore the Bug, rebuild it then! _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
VWNate Samba Member
Joined: October 04, 2016 Posts: 357 Location: Sunny So. Cal.
Posted: Mon Jul 31, 2023 7:13 pm Post subject: Re: Advisable to open/rebuild transaxle if no known issues? |
Don't forget to clean the drain plug magnets and add one to the filler plug, if the drain plugs don't have magnets add some .
Don't freak out because there are jagged looking slivers of steel on the magnet(s) this is normal SWARF and isn't cause for concern as long as it's quiet and shifts well .
Replace the boots and ensure the seams at at the 9 O'clock level, not straight up . _________________ -Nate
One last Beetle : 1959 #113 DeLuxe survivor ~ 36HP & full synchro tranny, 6 volts etc. |
toxicavenger70 Samba Member
Posted: Tue Aug 01, 2023 9:40 am Post subject: Re: Advisable to open/rebuild transaxle if no known issues? |
This is what I would do to it. I would check the shifter cone to ensure it is not leaking, replacing the transmission bushing to the chassis, check the side differentials for leakage, replace the transmission fluid, check the rear main seal for leakage, and replace the boots if they are cracked. That way if it does work out you won't be removing it later on for some simple maintenance items. |
Helfen Samba Member
Joined: January 19, 2009 Posts: 3450 Location: Vulcania
Posted: Wed Aug 02, 2023 10:04 am Post subject: Re: Advisable to open/rebuild transaxle if no known issues? |
BanjoMan64 wrote: |
Everyone told you what they would do but apparently no one read your post carefully enough. You said you were restoring a 64 beetle. A restoration isn't just a cosmetic job, it's everything as it was when new from the factory. The mechanical parts are just as important from steering and kingpins to the engine at the other end. This doesn't mean you need new bearings or bushings, but they must be within specifications. Sacrificial parts like synchronizers are a different story. When I worked in unit repair, I didn't throw away good bearings, but they were always checked.
If you want to refurbish a car that is one thing, but a restoration is a formidable worthwhile task that's more than a pretty paint job. |
FPGT72 Samba Member
Posted: Thu Aug 03, 2023 7:00 am Post subject: Re: Advisable to open/rebuild transaxle if no known issues? |
Just this past weekend I put the trans back in my car. I was having the same thought. However mine was not running when it came apart so I really do have no idea if the thing even has teeth on the gears.
What I figured I would do is after the engine is finished and installed I will do a test drive of the "pan" with a bucket and gas can, see if it moves and if anything sounds funny.
At that point if something is messed up it is not a huge deal to pop the engine off and deal with the issue.
At least this is my plan. |
clarkster75 Samba Member
Joined: September 25, 2006 Posts: 161 Location: Lots of good clean livin' Utah
Posted: Thu Aug 03, 2023 9:31 am Post subject: Re: Advisable to open/rebuild transaxle if no known issues? |
I lean, too, for changing the oil and axle boots, and driving it. At worst, you are only down pulling the engine so you can pull the Trans to replace/repair. If it works well with fresh oil you just saved a lot of time dealing with trying to pull rear wheel bearings. Unless, you have a friend/club member with a puller. It's a fair amount of work pulling a trans but not too bad. Like Click and Clack said, "you could ask the doctor to put in a new heart with a transplant, but why, if you don't need it?" |
markendee Samba Member
Joined: April 30, 2009 Posts: 248 Location: Kyabram, Australia
Posted: Thu Aug 03, 2023 7:08 pm Post subject: Re: Advisable to open/rebuild transaxle if no known issues? |
Definitely check and if not already alloy, change the detent hole plugs, all four of them. (check the 8mm one hiding behind the stud)
Regards,
Mark.
_________________ Member # 145244 |
