VR6zamboni Samba Member
Joined: January 16, 2012 Posts: 98 Location: Somewhere, Earth
Posted: Thu May 25, 2023 5:43 pm Post subject: Vanagon Automatic Transmission Weight |
Couldn't find this anywhere so figured I would let the webs know.
A completely drained Vanagon automatic transmission without the torque converter weighs 147lbs
The torque converter and mounting plate weighs 26lbs. I could still hear some fluid in the converter but I drained it as much as I could.
termuehlen Samba Member
Joined: May 02, 2012 Posts: 993 Location: Redwood City
Posted: Thu May 25, 2023 7:47 pm Post subject: Re: Vanagon Automatic Transmission Weight |
Good to know! I just shipped one complete, with fluids, completely enclosed in a shipping crate and all of that came in at 270 pounds. _________________ 1988 Westfalia automatic Subaru OBD1
1986 syncro tintop wbx |
VicVan Samba Member
Joined: July 01, 2015 Posts: 1840 Location: Vancouver Island, BC
Posted: Fri May 26, 2023 9:17 am Post subject: Re: Vanagon Automatic Transmission Weight |
Thanks for sharing the info, and for putting a clear title for future searches!
_________________ '90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH) |
Posted: Mon May 29, 2023 12:48 pm Post subject: Re: Vanagon Automatic Transmission Weight |
No worries! Further good info to know. UPS/FedEx is quoting $800+ to ship all the parts to make a manual Vanagon an Automatic from Montana to Maryland.
I split the trans in half and threw in a gasket kit (Elring 094072).
Box #1 34x23x18 - 133 lbs Transmission, Converter, Plate, Starter, Trans Mount
Box #2 28x21x18 - 107 lbs Bell Housing/Differential
Box #3 24x16x11 - 30 lbs Pedal Assembly/Brake Booster & Gear Selector
Box #4 71x18x3 - 14 lbs Shifter Rods and Cables
Box #5 24x16x11 - 8 lbs Lower Dash Trim, Gear Selector Cover, and Brake Fluid Reservoir
Box #6 24x9x4 30 - lbs Drive Shafts |
