Hartfiel Samba Member
Posted: Thu May 25, 2023 7:58 pm Post subject: 1968 Karmann Ghia repair kit for Brake Master cylinder |
My Ghia is leaking brake fluid out of the end of the Master cylinder. Filling the space between the firewall and the inside wall of the car. Are there any sources for a repair kit?
Sandy |
Posted: Thu May 25, 2023 8:02 pm Post subject: Re: 1968 Karmann Ghia repair kit for Brake Master cylinder |
Or does anyone have a part number for a new old stock Master cylinder for a 1968 Ghia convertible? |
runamoc Samba Member
Joined: June 19, 2006 Posts: 5601 Location: 37.5N 77.1W
Posted: Fri May 26, 2023 6:16 am Post subject: Re: 1968 Karmann Ghia repair kit for Brake Master cylinder |
Hartfiel wrote: |
The MC fits the floor pan, convertible doesn't matter. It will fit coupes too. Quick search found this. or use the part # listed to find it elsewhere
https://www2.cip1.com/vwc-113-611-015-bd/ _________________ Daily driver: '69 Baja owned 44 yrs - Plan B: '81 Rabbit Diesel LS Deluxe - Plan C: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs-
VW Wiring = It's just wires |
Ian Godfrey Samba Member
Joined: September 25, 2006 Posts: 1137 Location: Melbourne Australia
Posted: Fri May 26, 2023 4:11 pm Post subject: Re: 1968 Karmann Ghia repair kit for Brake Master cylinder |
most of the original master cylinders on our cars were ATE but these are hard to find. I also like Varga
Nobody much rebuilds master cylinders as kits are hard to find and often the cylinder is rusted meaning it needs to be bored and sleeved before it can be rebuilt. It is much cheaper to buy a new one
Cip1 have 2 European made ones that I would hope would be good quality:
https://www2.cip1.com/search-results-page?q=VWC-113-611-015-B&Search2.x=16&Search2.y=18
good luck |
Posted: Sun May 28, 2023 5:09 pm Post subject: Re: 1968 Karmann Ghia repair kit for Brake Master cylinder |
We've ordered a new Brake master cylinder and 2 switches that have 3 wires. Compared to what is on there has 3 switches that each have 2 wires. How do we know which wires from the old one will go onto the new switches so everything works. Is there a comparison diagram somewhere? |
jeffrey8164 Samba Member
Joined: January 06, 2018 Posts: 3819 Location: Georgia
Posted: Mon May 29, 2023 10:55 am Post subject: Re: 1968 Karmann Ghia repair kit for Brake Master cylinder |
The third switch in the weird place on your original master cylinder activates the brake warning light on the dash. You should be able to trace it back from the indicator to that switch.
On the new switches , the middle prong will activate that circuit so you will have to splice in another length of wire in parallel to connect both new switches.
Don’t be surprised if the new chinesium switches light up the warning light when you apply the brakes. It happened to me and I’ve read here that it’s fairly common. Since I didn’t want to go through the process again to change them I just learned to like it. Now I just look at it as a visual representation that my brake lights turn on. _________________ Volkswagen!
(Compression 8.7:1) |
Posted: Mon May 29, 2023 7:06 pm Post subject: Re: 1968 Karmann Ghia repair kit for Brake Master cylinder |
Thank you! |
