Akasharaja Samba Member
Joined: June 20, 2019 Posts: 40 Location: Shrewsbury, UK
Posted: Fri May 26, 2023 2:27 am Post subject: Brakes not working after m/c change |
Hi all, the brakes recently failed on my ‘72 Bay. There were no leaks bad the shoes were properly adjusted. Having asked around I concluded it was the master cylinder. They aren’t expensive, so I replaced it. But when bleeding the brakes with the new cylinder in place, the fluid only moves through very feebly, and I can hear bubbling from the reservoir. Still no leaks, though Any ideas on what’s wrong? Thanks! |
Posted: Fri May 26, 2023 4:30 am Post subject: Re: Brakes not working after m/c change |
Did you bench bleed the master? You need to check and adjust the pushrod length when installing a new master as well. |
Posted: Fri May 26, 2023 4:41 am Post subject: Re: Brakes not working after m/c change |
I did not bench bleed the master, no. Though I’ve replaced it before and didn’t need to then. |
bsairhead Samba Member
Joined: October 08, 2008 Posts: 3565 Location: viroqua wi.
Posted: Fri May 26, 2023 5:08 am Post subject: Re: Brakes not working after m/c change |
Soft lines swelled shut. |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22648 Location: NYC/Upstate/ROW
Posted: Fri May 26, 2023 6:52 am Post subject: Re: Brakes not working after m/c change |
You need to bench bleed to not only help bleeed the system, but confirm you have a working new part. Welcome to the Scatty Supply Chain of 2023. _________________ .ssS! |
Bonesberg55 Samba Member
Posted: Fri May 26, 2023 6:53 am Post subject: Re: Brakes not working after m/c change |
Bench bleeding the MC is necessary if you don't want to be bleeding the system for hours. |
Posted: Fri May 26, 2023 7:57 am Post subject: Re: Brakes not working after m/c change |
Gotcha. I’ll do that thing and hope I haven’t got a duff part. Is there a specific bleed kit for master cylinders? |
kreemoweet Samba Member
Joined: March 13, 2008 Posts: 3898 Location: Seattle, WA
Posted: Fri May 26, 2023 9:05 am Post subject: Re: Brakes not working after m/c change |
I've never had to "bench bleed" any m/c. My bus brake system bleeds fine. If you keep the bus level, the m/c will bleed itself, as the air in it rises by buoyancy (i.e. reverse gravity) up into the reservoir. It takes a minute or two. It is also perfectly normal for fluid to just barely dribble out of the bleeder valves when beginning the bleed procedure, because the lines are full of air and the pedal movement produces squat for pressure in air.
This all assumes you have functional brake parts of course. It is not rare for m/c's to be bad new out of the box from your crappy vw parts vendor. _________________ '67 bug: seized by the authorities
Joined: January 01, 2007 Posts: 16863 Location: sticksville, ct.
Posted: Fri May 26, 2023 11:14 am Post subject: Re: Brakes not working after m/c change |
kreemoweet wrote: |
I've never had to "bench bleed" any m/c.. |
X2
it's a total b/s statement to say "it has to be done"
besides making an epic mess, by the time you get the m/c mounted and the lines hooked up, all the brake fluid has pissed out everywhere anyway
one thing you have to look out for is the pushrod freeplay in the MC. if there isn't enough you'll never get it to bleed as the transfer ports never close.
not bench bleeding the MC is NOT your problem. you may have a bad MC but I wouldn't worry about the bench bleed thing one bit _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
wagohn Samba Member
Joined: June 24, 2014 Posts: 740 Location: United States
Posted: Sat May 27, 2023 9:16 pm Post subject: Re: Brakes not working after m/c change |
skills@eurocarsplus wrote: |
kreemoweet wrote: |
X2
100%. We've put in 2 new MC and tried to bench bleed twice. It's next to impossible to crawl under the bus and fit the MC while retaining any fluid. The fluid everywhere just made the job messier and awkward.
We gave up on the bench bleed, bled from the furthest wheel first, and had pressure first time around. _________________ 1976 VW Transporter, 2.0 FI Engine |
Posted: Sun May 28, 2023 8:57 am Post subject: Re: Brakes not working after m/c change |
A couple of you have mentioned Push rod adjustment. Is there a rule of thumb to get the push rod length adjusted for a new mc? |
wagohn Samba Member
Posted: Sun May 28, 2023 10:57 am Post subject: Re: Brakes not working after m/c change |
Akasharaja wrote: |
First, if it were me, I think I'd try to gravity bleed the bleed screws. Fill the reservoir, leave the top off, and partially open a bleed screw. Let it bubble away for a half reservoir of fluid. Rinse and repeat for each wheel.
I think a mis-adjusted MC pushrod would likely either have the brakes constantly on slightly, or have a weak brake pedal slightly. I think you have air in the system or a faulty MC.
I've fitted 2 cheap (O'Reilly) MCs and not adjusted the pushrod. I may be lucky, but we have many miles on the second $70 MC. _________________ 1976 VW Transporter, 2.0 FI Engine |
Posted: Sun May 28, 2023 11:13 am Post subject: Re: Brakes not working after m/c change |
I’ve now picked up a vacuum kit, which also says I should bench bleed the master, though I can’t really think of a sound physical reason why I would need to do so. Surely the vacuum will just draw all the air out of the cylinder chamber and through the brake line, to be replenished with fluid from the reservoir? |
W1K1 Samba Member
Joined: March 04, 2004 Posts: 4919 Location: Southern AB
Posted: Mon May 29, 2023 7:12 am Post subject: Re: Brakes not working after m/c change |
kreemoweet wrote: |
X2
I never understood the bench bleed, other than wetting the seals with brake fluid so you don't use the M/C dry. It's impossible to install a M/C with the fluid in it, and it's only maybe a tablespoon of fluid in the whole master cylinder.
I've used the DIY pressure brake bleeder for a long time.
https://ibmwr.org/original/ktech/pressure-bleeder/bleeder.shtml _________________ http://www.thesamba.com/vw/archives/manuals/jim_martin_engine_build.php
1973 super
1965 squareback 1500E
1971 bay window westy- subi swap |
chuckpolzin Samba Member
Joined: March 14, 2022 Posts: 147 Location: Wisconsin, USA
Posted: Tue May 30, 2023 11:04 am Post subject: Re: Brakes not working after m/c change |
use a power bleeder system and save yourself the headache, i tried to do it with the crappy little suction harbor freight deal and it was a pain, the power bleeder worked amazingly well and will eliminate any need to "bench bleed" the system. The standard power bleeder , i forgot the name brand, does not come with the correct resevoir cap so you will need to order the one that will fit the VW rez.
i believe the brand is motive but cant remember, nor can i remember the part number that fits the vw resevoir. |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21513 Location: Oklahoma City
Posted: Tue May 30, 2023 12:20 pm Post subject: Re: Brakes not working after m/c change |
Bench bleeding works.....as a concept....just not on the workbench.
As mentioned, there is just no way to reasonably keep it from getting messy and getting it into the bus (or any car for that matter) without losing most of the fluid.
I find a version of bench bleeding...or "pre-bleeding" really helps especially in type 3 and 4 car master cylinders because some makes of them can have an odd port to seal geometry issue inside that traps air.
Fill the MC with a little fluid to wet everything. Cycle it. Drain excess and wipe off.
Do not open any bleeder valves yet.
Install MC and pump the pedal hard and fast downward and very slow upward. It's easier at this point to pump the pedal with your hand.
Push it down to bottom of stroke and block it there with a rod. Get kut with your flare wrench and crack each hard line at the MC just until you hear or see air/fluid escape. Repeat a couple times. Keep a rag handy. Wash down when done.
This is essentially the same as bench bleeding but actually works. Bleed with normal method or with pressure bleeder from here. Ray |
75 Westy FI noob Samba Member
Joined: November 04, 2022 Posts: 330 Location: MidWest
Posted: Tue May 30, 2023 6:49 pm Post subject: Re: Brakes not working after m/c change |
Did you change the shoes on the rear drums by any chance ? |
Posted: Wed May 31, 2023 9:41 am Post subject: Re: Brakes not working after m/c change |
i worked on my brakes for nearly a month without getting any pedal at all.
Bleeding, bleeding again, moving bus, leveling bus, bleeding again, reversing , leveling, bleeding.. vacuum.. pedal pump partner.. bleeding...
in the end, the drum shoes on the rear were not adjusted properly.. allowing too much travel in the cylinder... not enough pressure to activate the rear or the front.
tightened them sob's all the way, backed it off 5 clicks.. now the brakes are solid. |
Posted: Thu Jun 01, 2023 10:31 am Post subject: Re: Brakes not working after m/c change |
Thanks for all your help. In the end it was down to pumping the pedal and waiting and pumping the pedal again till the air bubbles had stopped rising up into the reservoir and using the pedal method for each brake in turn. Worked absolutely fine. |
