jonat Samba Member
Joined: July 16, 2013 Posts: 74 Location: United Kingdom
Posted: Sat May 27, 2023 7:31 am Post subject: Fitting rear tombstone light housings |
hello,
I am fitting a replacement pair of Tombstone housings to the rear wings. (The Bolts had seized/sheared off on the previous ones despite lots of different lubricants applied)
I wondered how I can prevent that happening again - what should be applied to the threads and would a washer be necessary? Threadlock, grease?
Cusser Samba Member
Joined: October 02, 2006 Posts: 31385 Location: Hot Arizona
Rome Samba Member
Joined: June 02, 2004 Posts: 9654 Location: Pearl River, NY
Posted: Sat May 27, 2023 12:38 pm Post subject: Re: Fitting rear tombstone light housings |
ALWAYS fit a flat washer on the underside of the fastening nut! They spread the attachment force of the small-sized nuts over a larger area against the fender/wing surface. I agree with some grease on the housing's threads, since they are otherwise exposed to road/drive water. You can also apply some pliable sealing compound to the threads after the nuts are installed, as a further shield to dirt/water. |
clockworkbox Samba Member
Joined: July 12, 2020 Posts: 286 Location: Williamsport, PA
Posted: Sat May 27, 2023 1:58 pm Post subject: Re: Fitting rear tombstone light housings |
Permatex 80078 _________________ '69 Beetle (pieces)
Learning the hard way is still learning... |
Starbucket Samba Member
Posted: Sat May 27, 2023 3:11 pm Post subject: Re: Fitting rear tombstone light housings |
Brush on some Liquid electrical tape on the threads after installing the nuts. |
jonat Samba Member
Posted: Sat May 27, 2023 5:21 pm Post subject: Re: Fitting rear tombstone light housings |
not sure I can find Never Seez in the UK, other than really expensive options from abroad with high postage. Permatex 80078 might be a good alternative maybe which is available.
Is pliable sealing compound the same as liquid electrical tape? |
viiking Samba Member
Joined: May 10, 2013 Posts: 2668 Location: Sydney Australia
Posted: Sat May 27, 2023 5:53 pm Post subject: Re: Fitting rear tombstone light housings |
Any anti-seize will do.
Just google anti-seize UK and you'll get lots of (cheap) options. _________________ 1968 1500 RHD Lotus White Beetle since birth. In the hospital for major surgery
Discharged: 1983 Vanagon, 1974 1800 Microbus,1968 Low Light,1968 Type 3 |
Posted: Sat May 27, 2023 6:52 pm Post subject: Re: Fitting rear tombstone light housings |
jonat wrote: |
Google liquid electrical tape and see what comes up in the UK I'm sure an electric shop will know about it. |
jonat Samba Member
Posted: Sun May 28, 2023 3:49 am Post subject: Re: Fitting rear tombstone light housings |
I have some multi purpose copper grease - will that be good enough vs something like Permatex 80078? |
