haz77 Samba Member
Posted: Sat May 27, 2023 2:42 pm Post subject: sealing exhaust slip joints |
So here in Nz every 6months we have to have our cars check for road worthiness, its a pretty basic mech inspection that's a TPINA more so given I struggle to do >200m between checks,,,
But hey ho,,,
SO last check the guy commented that my exhaust slip joints leak gas as they don't seal, he did acknowledge that that's how they are made but said ultimately exhausts are not allowed to leak, he left it that is they don't get worse hell let it go.
Exhaust is a EMPI single quiet pack, yes I know most people think there shit but TBH I actually like the sound(!).
has anyone ever sealed these slip joints?
Wondered about;
- Trying to cut length ways along the outer pipe then put clamps on,
- Ramming exhaust sealant into the joints,
- squirting high temp silicon / mastic into the joints,
- wrapping the pipe in tape (heard this causes them to corrode fast?),
Don't really have the desire or $'s to 'upgrade' to say a VS, doesnt help that I heard a few not so good things about them & that to me they sound like a low revving non turbo Subaru, & not really many other off shelf options over here.
Cheers. _________________ '71 Type 3 Fastback, Sunburst Yellow, Lowered on Riviera's.
1776cc, Fully balanced, 8 Dowel fly, W100, DRD L3 heads, 1:25-1 CB rockers, 8.2:1, Twin 34's, Elec fuel pump, Fuel press reg, Full flowed, Single Quiet pack. |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76939 Location: Sneaking up behind you
Posted: Sat May 27, 2023 2:49 pm Post subject: Re: sealing exhaust slip joints |
Muffler cement or high temp silicone. _________________ Glenn
Member #1009
#BlueSquare |
bsairhead Samba Member
Joined: October 08, 2008 Posts: 3580 Location: viroqua wi.
Posted: Sat May 27, 2023 4:14 pm Post subject: Re: sealing exhaust slip joints |
Aluminium foil tape. |
Dangermouse Samba Member
Joined: November 23, 2005 Posts: 1266 Location: Beautiful New Zealand
Posted: Sat May 27, 2023 4:50 pm Post subject: Re: sealing exhaust slip joints |
Find a different WoF man
Technically my windscreen washer squirter is supposed to work too, but never failed a WoF on it _________________ Do not follow me, for I may not lead. Do not lead me, for I may not follow. Do not walk beside me either; actually just bugger off and stand over there will you. |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51150 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sat May 27, 2023 5:10 pm Post subject: Re: sealing exhaust slip joints |
Wood stove door gasket tape/ribbon/cord, whatever it's called, the woven asbestoseyish stuff that's sold by wood stove stores, a wrap of that secured with a worm drive hose clamp will solve the problem. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
clonebug Samba Member
Joined: January 29, 2005 Posts: 4027 Location: NW Washington
Posted: Sat May 27, 2023 5:31 pm Post subject: Re: sealing exhaust slip joints |
Are you talking about the stock heater box replacement slip connector with the donut and clamp????
I slathered Copper Seal on the pipe slide part and both sides of the donut then clamped it and it was leak proof at over 22 lbs. of boost....back pressure was pushing 30 lbs when I checked it with a gauge. _________________
vwracerdave wrote: |
Take a good long look in the mirror and report back on what you see. |
Paul.H wrote: |
That one line on that chart is probably better info than you can get from this place in a month |
Water/Alcohol Injection
Audi TT intercooler
Upgraded to MS3Pro-Evo
EcuMaster PMU16
ECUMaster ADU5 Digital Dash
http://www.shoptalkforums.com/viewtopic.php?f=3&t=127936 |
74 Thing Samba Member
What size is the exhaust pipe?
You can always weld flanged on it. |
BFB Samba Member
Posted: Sat May 27, 2023 7:11 pm Post subject: Re: sealing exhaust slip joints |
Could try to find a “ lap joint band clamp” , seen some on Amazon for as small as 1.5” . Maybe smaller out there, i dont know.
_________________ Forced induction can overcome a lot of obsticles that gets in it's way
"You are the Engineer and the Mechanic.
Build it your way not the way someone else does it. Their way might not work for you." - clonebug
“ The monkey see monkey do mentality seems to run deep in VW people. "Gene Berg said it was so 30 years ago so thats the way it is" “ - bdkw1 |
b-man Samba Member
Posted: Sat May 27, 2023 7:35 pm Post subject: Re: sealing exhaust slip joints |
Walker Acousti-Seal works nicely.
I’ve not only used it on these 36hp heater box slip joints pictured below but also on the donut seals on later 1600 heater boxes. No leaks, just heat it with a torch to soften it for removal when swapping to new exhaust parts.
_________________ 1956 Dove Blue Panel
1966 Velvet Green Single Cab
1957 L41 Black Oval Window Beetle |
modok Samba Member
Joined: October 30, 2009 Posts: 26789 Location: Colorado Springs
Posted: Sun May 28, 2023 10:08 am Post subject: Re: sealing exhaust slip joints |
A weld seals it pretty good.
If you don't like that then weld on flanges. |
