Snollygoster11 Samba Member
Joined: March 09, 2023 Posts: 8 Location: New Zealand
Posted: Sat May 27, 2023 7:01 pm Post subject: Body going back on pan. Set up the front suspension first ? |
I am in the process of rebuilding my 71 Super beetle which has been completely stripped down with the body removed for painting. Like my title says. I'm not too far away from reinstalling the body on the pan. My question is...Is there much advantage setting up front suspension first ?
I think I know the answer to this but would be interested to hear from those that have done this.
As usual thanks in advance for any advice. |
OTTO 1303 Samba Member
Joined: March 17, 2020 Posts: 636 Location: Louisiana
Posted: Sun May 28, 2023 4:51 am Post subject: Re: Body going back on pan. Set up the front suspension first ? |
I would install all body to pan bolts first, then install struts.
From my experience, the strut springs tend to keep the front of body lifted requiring tightening body bolts from rear to front in order to compress springs.
You may get around this by using a strut spring compressor on both struts so the struts can be put in place without them lifting the front as you bolt the body to the pan.
It’s just easier to deal with if the struts are not a factor, you want a good body to pan fit.
Good Luck _________________ 74 Super Sun Bug - OTTO
74 Super - DANZIG
74 Super - HERZOG |
Michael Ambrozik Samba Member
Joined: October 17, 2020 Posts: 631 Location: San Jose, CA
Posted: Sun May 28, 2023 12:13 pm Post subject: Re: Body going back on pan. Set up the front suspension first ? |
Install your rear heat ducts before installing the body to the chassis. The front suspension can be done after the body is on due to the extra weight. |
