2WD front lift springs for 19 inch ride height?
snoop
snoop is offline
PostPosted: Sun May 28, 2023 8:06 am    Post subject: 2WD front lift springs for 19 inch ride height? Reply with quote
Hi Sambanistas. With Schwenk Syncro rear lift springs and GoWesty 2WD front lift springs (and T3 shims and tall upper ball joints/Burley upper control arm) the van rides at 19" on all four corners and aligns just fine. This allows me to easily run the 225/70/16 tires that work well with the 5.43:1 R&P in the DX 5-speed in the van. I'd prefer a linear rate front spring like Schwenk over the GoWesty progressive rate springs in order to reduce the slight dive that the van experiences in cornering.
Pretty sure that even with shims, the Schwenk 2WD option would result in about an 18" ride height. I could go with something like this with the Schwenks to get there:
https://www.amazon.com/gp/product/B00029K20C/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
but I'd prefer to find a set of linear rate springs that fit the 2WD front suspension architecture and yield a 19" ride height (or nearly so that can be brought there with a shim).
Any ideas?
87 Westy Camper w/GW 2.4L, DX 5-speed and Peloquin TBD
tjet Premium Member
tjet is offline
PostPosted: Sun May 28, 2023 1:54 pm    Post subject: Re: 2WD front lift springs for 19 inch ride height? Reply with quote
I don't think I'd use those clamp things. Maybe double up some spacers?
Try looking at this to see what 2wd guys are using
https://www.thesamba.com/vw/forum/viewtopic.php?t=389820&highlight=prerunner
snoop
snoop is offline
PostPosted: Mon May 29, 2023 8:00 am    Post subject: Re: 2WD front lift springs for 19 inch ride height? Reply with quote
I resemble that remark Smile
snoop wrote:
Time I posted up the sopwith camel...
Top of Quartz Mtn., OR
GW 2.4L, tencentlife oil cooler with custom cooling fan, custom low restriction exhaust, DX 5-speed, Peloquin TBD, GW H&R 1.5" lift springs, custom swing arm clearancing/reinforcing, Monroe Sensatrac shocks (58263 front, 58633 rear...with lower shock mount lengthener), UBJ adapter, custom UCA BJ angle modification, Addco F&R swaybars, custom extended grade 8 front swaybar drop links, Lobro Type 4 CVs with Empi offroad boots, CLK wheels with LT225/75/16 mud terrains, T3 center caps...old school (plain) vintage (not shown) and a partridge in a pear tree Very Happy
Christopher Schimke
PostPosted: Wed May 31, 2023 5:41 pm    Post subject: Re: 2WD front lift springs for 19 inch ride height? Reply with quote
Christopher
shagginwagon83
shagginwagon83 is offline
PostPosted: Thu Jun 01, 2023 6:22 am    Post subject: Re: 2WD front lift springs for 19 inch ride height? Reply with quote
Christopher Schimke wrote:
Brandon
'83.5 Westfalia "Jo Ann" EJ22e w/Peloquin
DM me on IG for quicker responses @brandon.r2
snoop
snoop is offline
PostPosted: Thu Jun 01, 2023 10:07 am    Post subject: Re: 2WD front lift springs for 19 inch ride height? Reply with quote
Well okalee dokalee then. El maestro has spoken.
Would one need to change to all syncro suspension architecture (arms, hubs, spindles, etc.) or could just the syncro shock and spring be fitted to the 2WD architecture?
Thanks Christopher. And thanks Brandon; that GIF perfectly captures my thoughts too!
mike
