TCK123 Samba Member
Joined: August 01, 2022 Posts: 8 Location: Silicon Valley
Posted: Sun May 28, 2023 2:04 pm Post subject: MAP sensor connection on Kadrons for crank trigger ignition |
I am trying to find the best way to get a manifold vacuum signal to the MAP sensor for a Microsquirt V3 crank trigger ignition. I am thinking that I can tee into the balance tube with a vacuum manifold and then out to the MAP sensor. Or, is it a better signal coming off just one manifold. Any help would be greatly appreciated.
Thanks,
TCK123 _________________ TCK123 |
Vanapplebomb Samba Member
Joined: November 03, 2010 Posts: 5417 Location: Holland, MI
Posted: Sun May 28, 2023 3:40 pm Post subject: Re: MAP sensor connection on Kadrons for crank trigger ignition |
If the balance tube is big enough (1/2” +), vacuum should be stable enough to tap it right off the manifold. _________________ 1800 Type 4 Berrien 295
http://www.thesamba.com/vw/forum/viewtopic.php?t=487021 |
clonebug Samba Member
Joined: January 29, 2005 Posts: 4028 Location: NW Washington
Posted: Sun May 28, 2023 7:16 pm Post subject: Re: MAP sensor connection on Kadrons for crank trigger ignition |
You don't need a big line for a Map sensor. A smaller line will give better resolution.
I have a 5/32nds line running from my intake manifold along the passenger side to the front under the buggy hood to the ECU and a boost gauge.
It's been that way for 50,000 miles.
Put a Tee in your balance tube and shrink it down to a small line. Whatever size the fitting is on the map sensor is the size you should use. _________________
vwracerdave wrote: |
Take a good long look in the mirror and report back on what you see. |
Paul.H wrote: |
That one line on that chart is probably better info than you can get from this place in a month |
Water/Alcohol Injection
Audi TT intercooler
Upgraded to MS3Pro-Evo
EcuMaster PMU16
ECUMaster ADU5 Digital Dash
http://www.shoptalkforums.com/viewtopic.php?f=3&t=127936 |
oprn Samba Member
Joined: November 13, 2016 Posts: 12744 Location: Western Canada
Posted: Mon May 29, 2023 5:17 am Post subject: Re: MAP sensor connection on Kadrons for crank trigger ignition |
Your balance tube is fine. That way you will get a smoother signal than if you just tapped one manifold. I tapped all 4 on my Webers, ran a 1/8" line from them into a small RC model airplane fuel tank, then another 1/8" line to the MAP sender. Nice smooth signal and has been working this way for 3 years now. You won't need a dampening bottle, your balance tube will do all the signal dampening you require.
_________________ We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age) |
Posted: Mon May 29, 2023 8:35 am Post subject: Re: MAP sensor connection on Kadrons for crank trigger ignition |
clonebug wrote: |
X2. Also keep it as short as possible. Makes it respond quicker to vacuum changes. _________________ 1800 Type 4 Berrien 295
Posted: Mon May 29, 2023 8:42 am Post subject: Re: MAP sensor connection on Kadrons for crank trigger ignition |
As for vacuum stability with dual singles, I have measured smoother vacuum at the manifold than off the balance tube. The balance tube was surprisingly bouncy on the gauge, which sort of makes sense given that the air is rapidly oscillating back and forth between the manifolds.
If your balance tube is less than 1/2” ID, manifold vacuum starts to get pretty bouncy. In that case, either use a larger balance pipe, or tap MAP off the balance pipe if it measures smoother.
I find a 1/3” - 5/8” balance pipe to be ideal with dual singles and shorter duration/high vacuum cams. Going bigger doesn’t help, and going smaller reduces vacuum stability. _________________ 1800 Type 4 Berrien 295
boxer74 Samba Member
Joined: July 03, 2011 Posts: 709 Location: Ontario, Canada
Posted: Mon May 29, 2023 12:44 pm Post subject: Re: MAP sensor connection on Kadrons for crank trigger ignition |
oprn wrote: |
What kind of tubing is that? _________________ 74 Super
84 Westy |
mikedjames Samba Member
Joined: July 02, 2012 Posts: 2745 Location: Hamble, Hampshire, UK
Posted: Mon May 29, 2023 12:52 pm Post subject: Re: MAP sensor connection on Kadrons for crank trigger ignition |
You would have thought that by now you should be able to tune the filtering on the MAP signal using software in the Microsquirt rather than rigging a hardware low pass filter ( thin tubes and a plenum ..)
I use a MAP sensor created from a Bosch BMP280 mobile phone sensor for my vacuum advance, you can tune the filtering on the sensor. I was using 2Hz .. you could feel the kicks from the timing advance jumping . At 8Hz it is smooth but still filters out the pulses from the engine. _________________ Ancient vehicles and vessels
oprn Samba Member
Posted: Mon May 29, 2023 4:32 pm Post subject: Re: MAP sensor connection on Kadrons for crank trigger ignition |
boxer74 wrote: |
What kind of tubing is that? |
I should remember but I don't at the moment. It's industrial instrument tubing. We inherited it at work from a sister shop that shut down and my Boss just pitched it in the garbage. I saved one roll so I have 80 feet of it here. _________________ We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age) |
TCK123 Samba Member
Posted: Mon May 29, 2023 7:05 pm Post subject: Re: MAP sensor connection on Kadrons for crank trigger ignition |
A lot of great ideas. I was thinking of putting a 2 way connector off each manifold, one large connection for the balance tube and one small connection for the vacuum line. I was going to run the two small vacuum lines to a vacuum manifold and then out to the MAP sensor. I am a little ways out from getting it running, but I am one step closer now.
Thanks,
