brightcourse Samba Member
Joined: June 19, 2014 Posts: 41 Location: Rochester, NY
Posted: Mon May 29, 2023 8:09 am Post subject: Clacking sound out of #4 Intake when turning the Engine |
Reinstalled my engine today, started right up. Then we heard a clang. Upon further investigation, we narrowed it down to the intake on #4. Does anyone have any thoughts on the sound in the video below? We feel the vibration in the pushrod tube and it is very clear that it is where it is coming from. We verified that the pushrod is seated well.
I will note that the valve is moving.
Here is the 6-second video:
orwell84 Samba Member
Joined: May 14, 2007 Posts: 2539 Location: Plattsburgh, New York
Posted: Mon May 29, 2023 11:36 am Post subject: Re: Clacking sound out of #4 Intake when turning the Engine |
That’s a weird one. I got nuthin’, but someone will know. |
bsairhead Samba Member
Joined: October 08, 2008 Posts: 3579 Location: viroqua wi.
Posted: Mon May 29, 2023 11:45 am Post subject: Re: Clacking sound out of #4 Intake when turning the Engine |
Valve spring |
Whaanga Samba Member
Joined: May 07, 2016 Posts: 627 Location: Rochester, NY
Posted: Mon May 29, 2023 11:51 am Post subject: Re: Clacking sound out of #4 Intake when turning the Engine |
So with a valve spring, might this indicated a stuck valve? _________________ Late 1973 Bay w/a transplanted 914 Engine |
Posted: Mon May 29, 2023 11:54 am Post subject: Re: Clacking sound out of #4 Intake when turning the Engine |
Whaanga wrote: |
So with a valve spring, might this indicated a stuck valve? |
This makes sense. |
Posted: Mon May 29, 2023 12:28 pm Post subject: Re: Clacking sound out of #4 Intake when turning the Engine |
And here’s the dumb question ….
But is it possible to get the vale freed up from the outside or must the head come off? (And I’m sure the answer is somewhat dependent on the situation/condition of the valve). _________________ Late 1973 Bay w/a transplanted 914 Engine |
Posted: Mon May 29, 2023 12:48 pm Post subject: Re: Clacking sound out of #4 Intake when turning the Engine |
Whaanga wrote: |
But is it possible to get the vale freed up from the outside or must the head come off? (And I’m sure the answer is somewhat dependent on the situation/condition of the valve). |
Yes and no. Make sure your at TDC for that cylinder, take the rocker assembly off and the valve spring,(tricky but can be done with the right spring compressor) Next is to see how the valve spins and goes in and out with your fingers. Sometimes you can feel a tight spot. If this is the case get a small piece of surgical tubing a chunk of wood dowel close to the same size as the valve stem and a a drill or just your hands. Spin in out Spin in out. If the valve still is tight the head needs to come off. |
Posted: Mon May 29, 2023 2:17 pm Post subject: Re: Clacking sound out of #4 Intake when turning the Engine |
Looks like you have a lot of thread showing on the adjustment screw. How does this compare to the thread on other other screws? |
Posted: Mon May 29, 2023 2:22 pm Post subject: Re: Clacking sound out of #4 Intake when turning the Engine |
You can get oil to the valve stem by just taking a bottle of engine oil and poring it through the valve spring at the retainer end. If that seems to help, then dump a full quart of synthetic oil into a full tank of fuel and let that help lube the valve stem. Premixing the fuel with gasoline will help make it mix instead of just sitting in the bottom of the tank and possibly clogging the outlet. |
Posted: Mon May 29, 2023 4:23 pm Post subject: Re: Clacking sound out of #4 Intake when turning the Engine |
Thank you for the responses.
The real question here is what is the cause of the issue?
If you read through Randy's post, what lead us to this point was a hot running #3 cylinder. We pulled the engine a few weeks ago in an attempt to discover the cause of the hot running #3. We were mostly wanting to see if the new AMC heads on this recently built engine were clogged with cast flashing.
We pulled the engine, removed the push rods/tubes, and the tin underneath the 3/4 side of the heads to get a closer look. Once we took photos of the head, we put everything back together and torqued the valve trains to spec. We checked and adjusted the hydraulic valves.
So today, on startup after the installation, we experienced a smooth running engine (which ran quieter). We let it run a few minutes and then shut it off.
A few minutes later, we were prepping to go on a test drive and started the engine again. This time, it did not start right up, and I was in the back and heard a ticking sound. We quickly abandoned the staring process and soon found the issue as explained above by Randy.
The question I have is, what might have caused this issue? We have to consider the valve adjustment and re-installation of the valve train, but these are things we have experience doing before and we did our due diligence with this work.
We turned the engine many times by hand during the last couple of weeks and found no issues. So again, we are trying to evaluate what might have caused this issue and 'HOPE' we can resolve it.
Jeff _________________ Late 1973 Bay w/a transplanted 914 Engine |
Posted: Mon May 29, 2023 4:37 pm Post subject: Re: Clacking sound out of #4 Intake when turning the Engine |
A chunk of carbon can cause this. |
timvw7476 Samba Member
Posted: Mon May 29, 2023 5:55 pm Post subject: Re: Clacking sound out of #4 Intake when turning the Engine |
Just pull the pushrod tube, pushrod & check the lifter.
80% chance it came apart. There's a retainer spring that holds the 'guts' together. Either it's let go & made this happen, or a valve seat is popped loose.
Start with the lifter. It may come out in pieces. |
Posted: Tue May 30, 2023 1:37 pm Post subject: Re: Clacking sound out of #4 Intake when turning the Engine |
We pulled the pushrod out on #4 Intake and look what we found...
Suggestions on finding a new pushrod? |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22668 Location: NYC/Upstate/ROW
Posted: Tue May 30, 2023 1:54 pm Post subject: Re: Clacking sound out of #4 Intake when turning the Engine |
I think you had better fix that stuck valve first. _________________ .ssS! |
Posted: Tue May 30, 2023 1:58 pm Post subject: Re: Clacking sound out of #4 Intake when turning the Engine |
At least that WAS the proper pushrod for a hydro engine. |
Posted: Tue May 30, 2023 2:01 pm Post subject: Re: Clacking sound out of #4 Intake when turning the Engine |
The valve is not stuck. It moves just fine - I’m pretty sure this was our error with the installation - we didn’t get the rod seated correctly.
To check the health of the lifter and valve, we swapped the rod from #4 exhaust and 1), the noise is. Is gone, and 2), the intake valve moved freely as designed. _________________ Late 1973 Bay w/a transplanted 914 Engine |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12722 Location: on a bike ride somewhere
Posted: Tue May 30, 2023 8:05 pm Post subject: Re: Clacking sound out of #4 Intake when turning the Engine |
timvw7476 wrote: |
Was it? Looks like light trickery… I thought the originals were thicker steel on original hydro Type 4's.
From Ratwell:
Mofoco has some custom lifters, and might have custom pushrods too. Not sure of that applies to the Type 4 though.
I think the pushrod wasn't fully seated in the rocker arm, and was caught between a rock and a hard place when the lifter inflated after startup. We've all done it on a hydraulic pushrod installation at some point, but it still sucks.
Pushrod lengths of stock engines listed here;
https://ratwell.com/technical/HydraulicLifters.html
Good luck!
www.airschooled.com |
Posted: Tue May 30, 2023 9:10 pm Post subject: Re: Clacking sound out of #4 Intake when turning the Engine |
Good Catch (on the steel pushrod)
The aluminum body solid lifter units are so thick it's obvious when it's those.
And yeah, bummer. Always 'feel' the ends go in the 'cups'. I unwind my adjusters because I've snagged one or two in the past. And come close to stripping those delicate rocker studs. The tiny ones with 11mm nuts. Treat those gently, you cannot just shove pushrod ends in the cups & torque down, those rockers rae best torqued flush to the surfaces on the heads, all four, before you even think to set lash, solid or hydro. Yes I stripped a nut back in the day. Not my finest hour. : l |
Clatter Samba Member
Joined: September 24, 2003 Posts: 7544 Location: Santa Cruz
Posted: Wed May 31, 2023 8:36 am Post subject: Re: Clacking sound out of #4 Intake when turning the Engine |
Yep, happens.. BTDT.
I'd be putting your leak-down tester on that hole to be sure the valve didn't kiss a piston and get bent. _________________ Bus Motor Build
What’s That Noise?!? |
