19VDuB68 Samba Member
Joined: February 29, 2016 Posts: 166 Location: Illinois
Posted: Tue May 30, 2023 1:07 pm Post subject: Turn signal issues |
HELP..... My front turn signals work fine until driving lights and headlights are on,when on they just light up. Rear no issues. Brand New wiring whole car last year only thing not changed was fuse box.
EDIT: Also what's weird is 4th fuse blew then drivers side worked replace the fuse back to just on no blinking. |
itsawesty Samba Member
Joined: April 25, 2016 Posts: 101 Location: St Albans, UK
Posted: Tue May 30, 2023 3:13 pm Post subject: Re: Turn signal issues |
Will do thank you. |
Posted: Tue May 30, 2023 6:00 pm Post subject: Re: Turn signal issues |
Checked grounds all seem fine. If I pull fuse 3 and 4 both work perfectly. Replace they quit again. |
Posted: Tue May 30, 2023 9:31 pm Post subject: Re: Turn signal issues |
My headlight switch went out and I got this one. I am wondering if it's wired wrong what goes to X?
Dwighia Samba Member
Joined: November 26, 2010 Posts: 78 Location: Arlington, VA
Posted: Fri Jun 16, 2023 2:11 pm Post subject: Re: Turn signal issues |
Hey, I have the same problem with my front turn signals not working when the headlights are on. Everything else works fine.
Was this issue ever resolved?
Any ideas?
Thanks
1968 Ghia Convertible. _________________ '71 Ghia Sedan
'68 Ghia Convertible
'84 Vanagon
If you dismantle a VW engine and reassemble it enough times, will you end up with enough extra parts for another engine? |
SandHamwich Samba Member
Joined: April 26, 2020 Posts: 95 Location: Orangevale
Posted: Fri Jun 16, 2023 3:45 pm Post subject: Re: Turn signal issues |
Check the sockets to make sure the electrodes aren’t crossing and also that you have a proper dual filament bulb in there. I had a single filament bulb in one side and it caused the craziest electrical issues. |
Posted: Sat Jun 17, 2023 3:37 pm Post subject: Re: Turn signal issues |
Thank you for your suggestions.
Yes I have the correct bulbs and contacts are clean. All the bulbs work fine and flash on both turn signals and emergency flasher. However, the front flasher bulbs just don't work when the headlights are on.
But I did clean one of the ground connections between a screw in the trunk that leads to the clock. As a result of either that or me wiggling enough wires, I now have blinkers on the right side.
But unfortunately not on the left (again, only when the headlights are on)
Any other ideas?
Thanks,
Dwight _________________ '71 Ghia Sedan
'84 Vanagon
Posted: Sun Jun 18, 2023 8:48 am Post subject: Re: Turn signal issues |
Mine was I had led bulbs in rear. I put regular bulbs back in and they work. Not sure why I have a led flasher relay. With original relay and the led bulbs it all worked but the rear turn signals were super slow. Not sure why it's not working with new relay. |
