mbruell Samba Member
Posted: Wed May 31, 2023 2:48 pm Post subject: Replacing exhaust manifold gaskets 1987 VW Syncro - tutorial? |
Hey Folks,
I’m going to be replacing the exhaust manifold gaskets on my 1987 Syncro. The rest of the exhaust system appears to be ok.
Have any of you seen a youtube video on this type of job? I haven’t been able to find one.
In addition to the exhaust manifold gaskets, what other parts should I purchase for this job?
Thanks,
M |
markswagen Samba Member
Joined: January 28, 2018 Posts: 1039 Location: san diego
Posted: Wed May 31, 2023 5:03 pm Post subject: Re: Replacing exhaust manifold gaskets 1987 VW Syncro - tutorial? |
have stud extractors and a torch on hand, the studs/bolts that hold the headers to the heads, have been known to snap off, if one does, it'll keep you out of mischief for a while. _________________ markswagen {mobile mechanic} san diego area all early VW's cared for.
619 201 0310 |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17155 Location: Retired South Florida
Posted: Wed May 31, 2023 6:12 pm Post subject: Re: Replacing exhaust manifold gaskets 1987 VW Syncro - tutorial? |
I have seen exhaust manifold bolts and studs with nuts or a combination. If you are unfamiliar with dealing with rusted, frozen, rounded hardware, I would recommend you not learn on this job. As suggested, this job can go off the rails quick. This might be a job better left for a seasoned VW technician. Break a stud, drill off center, snap off an extractor and a job that a seasoned tech could do quickly may be come a cylinder head that needs to be removed.
If you intend to plug on, look for videos on frozen nuts and bolts. Removing broken studs and bolts by welding, drilling, extracting and inserting. Probably not what you want to hear. Every task I can think of on a syncro is 3x more difficult. Removal if you can unbolt it with no trouble is fairly straightforward. I’d have 4 exhaust manifold gaskets and all the other exhaust gaskets in the system. I’m sure the big 3 suppliers have all you need. Copper high temp silicone comes in handy sealing imperfect flange surfaces. There are a few threads where an owner attempted this job only to have it turn way south quick. _________________ ☮️ |
dhaavers Samba Member
Joined: March 19, 2010 Posts: 7757 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Wed May 31, 2023 6:31 pm Post subject: Re: Replacing exhaust manifold gaskets 1987 VW Syncro - tutorial? |
Not a syncro, but my recent visit to this project expanded to almost 3 weeks, between
soaking in penetrating oil, tapping, waiting, soaking, tapping, waiting, wrenching, soaking,
tapping, waiting, heating, breaking, welding (fail…I’m not a welder), drilling, breaking,
drilling, tapping, helicoil-ing, JB Weld-ing, waiting, replacing hardware, wrenching,
snugging & final torque-ing.
Ugh.
Three words for you:
- Copper anti seize
- Brass acorn nuts
- Good F-ing luck
…you’ll need it…
- Dave _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
MsTaboo Samba Member
Joined: June 02, 2006 Posts: 4098 Location: East Kootenay, British Columbia
Posted: Wed May 31, 2023 6:45 pm Post subject: Re: Replacing exhaust manifold gaskets 1987 VW Syncro - tutorial? |
I haven't had to deal with rusted exhaust hardware on the Wasserboxer for many years since doing an engine conversion back in '09, but here are a few tips for any rusted-heat fused nuts and bolts.
First off get a can of PB Blaster and carefully soak the various hardware. Do this several times over a few days (at the very least overnight). Try not to get the stuff all over your exhaust because it will be kinda stinky when it burns off.
Really let it have a chance to soak in.
Next is to use a small stiff steel brush, I like those ones that are about the same size as a toothbrush. You can get them at any decent hardware store, welding supply, or Harbor Freight for the cheapie ones. Use to knock off as much rust as possible before attempting to remove the nuts.
And finally, don't use a power tool. Use quality wrenches and sockets. Break the nut loose and only turn a small ways, then spray some more PB Blaster onto the bolt, retighten the nut part way, and loosen again, repeat.
The trick is to not use brut force but to slowly work the nut off, letting the juice work into the threads and cleaning away the swarf.
I've used this method over the years and have saved many a bolt from breaking.
If you get some really bad ones you can try heat, but of course you'll need to be careful not to burn down your Syncro .
Even if you decide to let a shop do the work it will pay to pre-treat the nuts and bolts so the shop monkeys don't snap off dry bolts and charge you $$ to save the situation.
Good luck!
( edit for spelling, damn spellcheck turned swarf into scarf ) _________________ Currently:
Defend democracy, support Ukraine.
Posted: Wed May 31, 2023 8:18 pm Post subject: Re: Replacing exhaust manifold gaskets 1987 VW Syncro - tutorial? |
FYI: “brass acorn exhaust nuts“ https://www.thesamba.com/vw/forum/viewtopic.php?t=714759 _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
Posted: Thu Jun 01, 2023 7:14 am Post subject: Re: Replacing exhaust manifold gaskets 1987 VW Syncro - tutorial? |
Wow - great info. I’ll keep y’all posted.
Thanks everyone,
M |
hardway Samba Member
Joined: January 03, 2012 Posts: 416 Location: Fidalgo Island
Posted: Thu Jun 01, 2023 5:54 pm Post subject: Re: Replacing exhaust manifold gaskets 1987 VW Syncro - tutorial? |
An ounce of prevention is worth a pound of cure. Waterboxers left the factory with each head having two exhaust studs. The other exhaust flange on that head received two bolts. I always install four exhaust studs per head. If the nuts on the studs do not move easily then stop. I like to expand frozen exhaust nuts by hitting them on a flat with a sharp air chisel. I also walk them off by turning the chisel after the nut is expanded. But waterboxer exhaust studs can only take so much side force. Sometimes I have to cut a slice out of the side of the nut down to the threads to loosen it.
If a bolt breaks and is seized in the head then you in for a world of hurt. If you have to drill out a broken bolt then you had better make a jig to guide the drill or a new head will be in your future. As others have advised, this is not the place to learn these skills. But there is no harm in trying to remove the fasteners unless you do not stop before things go wrong. The most important thing is knowing when to stop before it goes sideways.
Sometimes heat is necessary. Sometimes heat is not enough. But when it comes to penetrating oils I would advise Kroil. |
Posted: Wed Jun 14, 2023 4:11 pm Post subject: Re: Replacing exhaust manifold gaskets 1987 VW Syncro - tutorial? |
Well, thanks everyone. It seems this job is too much for me, so I’m looking for a shop to do the work. I took it to the local Midas shop, and the guy there was super helpful and knowledgeable, but in the end said he’d have to drop the engine to do the work (most likely), and certainly have to the drop the engine if the bolts in the heads were to break, and he just wasn’t set up to do that work these days.
I’m thinking of taking it to VanCafe.
Do any of you have thoughts on whether it’s worth it to install/replace most or nearly all of the exhaust system on the old wbx, or whether it's time to consider a subaru conversion, or a tdi?
I probably won’t drive more than 65-70 most of the time anyway, so having more power or acceleration, though nice, isn’t that important. More confidence in the reliability would be nice.
Anyway - it would be good to hear y’all’s thoughts on the pros and cons, and how one might go about making the decision.
Thanks,
Marc |
Posted: Wed Jun 14, 2023 5:42 pm Post subject: Re: Replacing exhaust manifold gaskets 1987 VW Syncro - tutorial? |
Replacing the exhaust is a straightforward job for an experienced tech. If Van Cafe is able to take your van in and do the work, they should have the skills. An engine conversion is an entire new level of money and time.
Worse case, all 8 fasteners snap off at the head. Figure 1/2 hour to drill and repair each one. The other fasteners are through bolted and get discarded. The trick is to snap as few as possible of the exhaust studs/bolts. _________________ ☮️ |
Posted: Thu Jun 15, 2023 7:50 am Post subject: Re: Replacing exhaust manifold gaskets 1987 VW Syncro - tutorial? |
yeah, the more I read about it, the more that makes sense.
Although the stainless steel exhaust seems like a good idea, from what I’ve read around here, folks are having problems with some of the related fasteners and such. I’m planning to go with the stock replacement.
Hopefully it’ll hold up well enough until I can get it in. The voicemail message indicated they were a month out.
Here’s a photo of the crack in the exhaust pipe. When they had it up on the list at Midas, one could see that the crack went almost 3/4 the way around the pipe. There’s probably an inch or two left.
dobryan Samba Member
Joined: March 24, 2006 Posts: 16505 Location: Brookeville, MD
Posted: Thu Jun 15, 2023 10:15 am Post subject: Re: Replacing exhaust manifold gaskets 1987 VW Syncro - tutorial? |
Thanks. I have appointment for next week, which I’m psyched about. Makes me wonder if there’s anything else I should have them look at. |
Posted: Mon Jun 19, 2023 9:59 pm Post subject: Re: Replacing exhaust manifold gaskets 1987 VW Syncro - tutorial? |
Well, my good and talented friend helped me tackle the removal of the exhaust header pipes. I sprayed PB Blaster on the bolts in the morning, and we took a shot about 4 hours later. The plan was to try to loosen each of the 8 bolts connecting the pipes to the heads, and if any of them put up too much of a fight, we’d bail and I’d take my van to VanCafe. As it turned out, all of the bolts came loose reasonably easily. We’re going to be replacing the pipes and collectors up to the catalytic converter. From the cat to the end of the tail pipe is in good shape. Here’s a photo of the removed exhaust header pipes.
Thanks for all the advice and warnings. It took us a little less than 3 hours to remove all parts. |
Posted: Tue Jun 20, 2023 2:14 pm Post subject: Re: Replacing exhaust manifold gaskets 1987 VW Syncro - tutorial? |
If you don't go, you don't know.
The Dansk (JP) replacement pipes did not fit well decades ago and they seem to fit worse now. Fitting the pipes can be a challenge. It is important that exhaust components fit well. They all need to lie naturally in the right place. If they are installed under tension by forcing them together, they will crack. They may need to be bent, slotted and cut, shaped and welded. The brackets at the rear bottom of the case halves always seem to need clearancing now.
Measure thrice. Cut once.
Have at it.
Posted: Tue Jun 20, 2023 3:17 pm Post subject: Re: Replacing exhaust manifold gaskets 1987 VW Syncro - tutorial? |
Good job! Now you have some extra money to spend on other maintenance items . _________________ Currently:
Posted: Tue Jun 20, 2023 4:55 pm Post subject: Re: Replacing exhaust manifold gaskets 1987 VW Syncro - tutorial? |
hardway wrote: |
Have at it. |
Really! My goodness, that’s too bad. Thanks for the heads up. |
Posted: Wed Jun 21, 2023 10:15 am Post subject: Re: Replacing exhaust manifold gaskets 1987 VW Syncro - tutorial? |
Again, it's been a really long time since I had to wrestle with a Wasserboxer but the trick with any exhaust system is to assemble everything without tightening the hardware.
Once you have all the pieces connected you can start tightening the nuts and bolts, giving the different pieces a jiggle so they settle where they want to be, as Hardway noted you don't want to stress the pipes.
I've used a rat tail file (round) in the past to elongate the holes a bit to allow more movement, being careful not to remove too much metal.
Good luck! _________________ Currently:
Posted: Wed Jun 21, 2023 10:45 am Post subject: Re: Replacing exhaust manifold gaskets 1987 VW Syncro - tutorial? |
MsTaboo wrote: |
Good luck! |
That sounds like solid advice. Thank you. Parts are arriving today, but I don’t think I’ll be able to tackle it until the weekend. I’ll keep y’all posted. |
