Gtp70 Samba Member
Joined: May 10, 2023 Posts: 62 Location: Mission Viejo, CA
Posted: Wed May 31, 2023 8:11 pm Post subject: 69 Beetle rear brake hoses |
I ordered new rear brake hoses. I took one off and noticed both ends are female. The ones they sent have one female and one male end. I do a search and all I see are the female/male hoses. Is this right? Did a previous owner change out the brakes on my car or something. Or are there two types of these hoses and I just have to find the right ones.
Cusser Samba Member
Joined: October 02, 2006 Posts: 31268 Location: Hot Arizona
Posted: Wed May 31, 2023 8:24 pm Post subject: Re: 69 Beetle rear brake hoses |
Gtp70 wrote: |
I ordered new rear brake hoses. I took one off and noticed both ends are female. The ones they sent have one female and one male end. I do a search and all I see are the female/male hoses. |
When I resurrected my 1970 VW back in 2016-2017, I discovered the same. There are female/female hoses available, I had to return and order correct hydraulic lines for mine.
And also had similar issue with rear on my 1971 Super two decades earlier. Learned to remove parts and THEN compare !
Computers are only as smart as the information entered ! _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Joined: May 17, 2003 Posts: 4863 Location: Harmony, PA
Posted: Wed May 31, 2023 9:13 pm Post subject: Re: 69 Beetle rear brake hoses |
A US 69 Chassis would have a CV joint axle IRS suspension rear with the male/female hoses. Maybe your 69 has had an earlier chassis installed with the Swing Axle tube style suspension that would of had the female/female hoses. Below is what a common 69 chassis would look like where the male portion of the brake hose threads into the brass mounted fittings. If you need the female/female hoses, they are simply 67 and earlier rear Beetle ones.
Gtp70 Samba Member
Posted: Thu Jun 01, 2023 7:08 am Post subject: Re: 69 Beetle rear brake hoses |
Dang it, turns out I do have a swing arm suspension. Finding out all kinds of things wrong with this car. No idea why previous owner(s) would have changed the suspension. And my brake lines look nothing like yours, looks like all kinds of things were modified. Thanks for the tip, Ill look into getting 67 F/F hoses. |
sb001 Samba Member
Joined: May 19, 2011 Posts: 10399 Location: NW Arkansas
Posted: Thu Jun 01, 2023 7:15 am Post subject: Re: 69 Beetle rear brake hoses |
Gtp70 wrote: |
No idea why previous owner(s) would have changed the suspension. And my brake lines look nothing like yours, looks like all kinds of things were modified. |
My guess is they dropped a 69 body on a 67 chassis. Do the VIN numbers match between the plate on the dashboard under the windshield and the rear tunnel hatch under the rear seat? _________________ I'm the humblest guy on this board.
1600 SP engine
Solex 30 PICT 3 carburetor
clockworkbox Samba Member
Joined: July 12, 2020 Posts: 253 Location: Williamsport, PA
Posted: Thu Jun 01, 2023 7:20 am Post subject: Re: 69 Beetle rear brake hoses |
'68 was also swing axle except for autostick. _________________ '69 Beetle (pieces)
Learning the hard way is still learning... |
sb001 Samba Member
Posted: Thu Jun 01, 2023 7:28 am Post subject: Re: 69 Beetle rear brake hoses |
clockworkbox wrote: |
'68 was also swing axle except for autostick. |
You are correct sir, sorry _________________ I'm the humblest guy on this board.
1600 SP engine
Gtp70 Samba Member
Posted: Thu Jun 01, 2023 7:34 am Post subject: Re: 69 Beetle rear brake hoses |
Yes, all Vins match under the hood, under the rear seat, and my pink - 119263344, did a vin search and some research and its definitely a 69 |
Posted: Thu Jun 01, 2023 9:01 am Post subject: Re: 69 Beetle rear brake hoses |
It was built in September of '68 and sometimes they used left over parts early in production runs but I thought all '69s were IRS. _________________ '69 Beetle (pieces)
Gtp70 Samba Member
Posted: Thu Jun 01, 2023 5:00 pm Post subject: Re: 69 Beetle rear brake hoses |
Yeah it’s all messed up. And I just put on 69 rear drum pads, now I’m wondering if those are wrong to, and if I need to start ordering for a 67 instead of a 69, even though the car is a 69 |
OldSchoolVW's Samba Member
Posted: Thu Jun 01, 2023 7:23 pm Post subject: Re: 69 Beetle rear brake hoses |
Gtp70 wrote: |
If you haven't already gotten around to the front brakes and replaced the wheel bearings, be advised that you might have earlier spindles which have a smaller diameter and use a different inner bearing and grease seal than what is typically sold for a '69. This is what I have on my '69 (built in November, 1968). No way to tell if it came from the factory this way or a PO (or VW repair shop) swapped early spindles for late ones somewhere along the line. It's very possible that various parts got interchanged and swapped out over the last 50+ years on most of our cars. _________________ Tom
"Following distance is proportional to IQ."
'63 Beetle Sedan
'69 Beetle Sunroof
'70 Beetle Sedan
'73 Type 3 Fastback |
Cusser Samba Member
Posted: Thu Jun 01, 2023 7:40 pm Post subject: Re: 69 Beetle rear brake hoses |
OldSchoolVW's wrote: |
It's very possible that various parts got interchanged and swapped out over the last 50+ years on most of our cars. |
THIS !!!
THIS !!!
THIS !!! _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
