hulbyw Samba Member
Joined: April 24, 2021 Posts: 127 Location: Australia
Posted: Thu Jun 01, 2023 1:35 am Post subject: Piston Pins Too Tight? |
I neglected to check the piston pin fitment in the rebuilt stock connecting rods before I sealed up the case. Now when I need to assemble a piston and cylinder to check deck height, the pin will not push through the rod by hand. If I freeze it and heat the rod small end it will go through with some hits with a plastic hammer however when the temps even out it will likely not be a floating piston anymore. Do I need to split the case, disassemble then take the pins and rods to a machinist to get the rods reamed out so the piston can self centre in the barrel? |
oprn Samba Member
Joined: November 13, 2016 Posts: 12714 Location: Western Canada
Posted: Thu Jun 01, 2023 3:44 am Post subject: Re: Piston Pins Too Tight? |
Why would you have to split the case to remove the rods? You can reach the rod bolts through the cylinder holes. _________________ We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age) |
Nitramrebrab72 Samba Member
Joined: November 10, 2018 Posts: 485 Location: France
Posted: Thu Jun 01, 2023 3:52 am Post subject: Re: Piston Pins Too Tight? |
You can't split the case without removing the pistons. I would of thought the piston pin needs to be turned down as the con rod has a bearing shell. Having said that the piston pin has a chrome surface treatment. So you need the right parts for the job. |
MuzzcoVW Samba Member
Joined: February 21, 2018 Posts: 1462 Location: Westfield, MA.
Posted: Thu Jun 01, 2023 4:04 am Post subject: Re: Piston Pins Too Tight? |
Sounds like it's time to consider hone the rod bushings. No, the pins don't get turned. Seen this many times with rebuild rods. |
hulbyw Samba Member
Posted: Thu Jun 01, 2023 4:36 am Post subject: Re: Piston Pins Too Tight? |
oprn wrote: |
Why would you have to split the case to remove the rods? You can reach the rod bolts through the cylinder holes. |
Good point- thanks! |
oprn Samba Member
Posted: Thu Jun 01, 2023 4:47 am Post subject: Re: Piston Pins Too Tight? |
On this subject, the machinist I took my engine parts to for balancing told me the pin fit in the pistons was too tight and had to be corrected. He said they should never be an interference fit at room temperature. They should be a thumb press fit, about 1/2 thou clearance. These were not new pistons either.
I told him that all air cooled VW pistons were like that. He insisted that it was still wrong. I let him have at it and he did an amazing job, they were indeed a thumb press fit when he was done! When I think back on all the hassle over the years trying to get used pins out of pistons without bending the rods I think he is on to something. In all the engines I have disassembled over the years I have never seen pin bores in the pistons worn. It's always the rod bushing. They are probably too tight to even turn most of the time! _________________ We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age) |
Posted: Thu Jun 01, 2023 5:27 am Post subject: Re: Piston Pins Too Tight? |
oprn wrote: |
I told him that all air cooled VW pistons were like that. He insisted that it was still wrong. I let him have at it and he did an amazing job, they were indeed a thumb press fit when he was done! When I think back on all the hassle over the years trying to get used pins out of pistons without bending the rods I think he is on to something. In all the engines I have disassembled over the years I have never seen pin bores in the pistons worn. It's always the rod bushing. They are probably too tight to even turn most of the time! |
Years ago a guy who taught me how to assemble my first type 1 engine said exactly the same thing. I believe he used a wheel cylinder hone to clearance them... don't exactly remember. VERY little had to be removed for proper clearance. And you're right, I don't think I've run across all but one set that I could push in by thumb. It makes complete sense that they need to be able to float. I always make sure that I'm able to do this, and not have to smack them in with a hammer |
jbbugs Samba Member
Joined: September 16, 2002 Posts: 2152 Location: Behind the wheel
Posted: Thu Jun 01, 2023 5:32 am Post subject: Re: Piston Pins Too Tight? |
A small ball hone works well for this. _________________ Drag bus! http://www.youtube.com/watch?v=s2MOVmKdhX4
69 OG paint Transporter
73' Super Beetle Champcar Endurance Roadracer
Patina my ass, that's a Rust Bucket! |
oprn Samba Member
Posted: Thu Jun 01, 2023 5:42 am Post subject: Re: Piston Pins Too Tight? |
He used a bushing reamer that is long enough to do both pin holes at once on the piston to keep the holes parallel. A brake cylinder hone could taper the hole if the stone pivot point is not centered in the hole. As for ball hones... they don't tend to keeps things true at all! _________________ We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age) |
Vanapplebomb Samba Member
Joined: November 03, 2010 Posts: 5410 Location: Holland, MI
Posted: Thu Jun 01, 2023 5:46 am Post subject: Re: Piston Pins Too Tight? |
I agree 100% with oprn. The reamer is the way to go. Pistons are soft, and abrasives from homes, like a ball hone embed the bore, and can score the piston pin. Like he says, ball homes don’t necessarily keep things round… especially when there may be different surface areas from one side to the other. The side with less area wears more, and the bore goes egg shaped. _________________ 1800 Type 4 Berrien 295
http://www.thesamba.com/vw/forum/viewtopic.php?t=487021 |
RWK Samba Member
Posted: Thu Jun 01, 2023 10:43 am Post subject: Re: Piston Pins Too Tight? |
Check for burrs around the snap ring groove from mfg. always one there on used pistons. Also burrs from driving them in and out if driver touches piston bore, best to have pin driver fit into ID of pin closely and plenty of clearance around OD of driver to clear bore, that's how I make my pin drivers. _________________ 73 Type 181
63 Type 113
63 Type 261- 428 071
62 Type 241-378 025 178 530 |
modok Samba Member
Joined: October 30, 2009 Posts: 26785 Location: Colorado Springs
Posted: Thu Jun 01, 2023 1:10 pm Post subject: Re: Piston Pins Too Tight? |
And this is why you need to have a rod honing machine to build engines.
Or rather you need that as part of your team, maybe not you personally.
If there is no such service in your city then I would buy a rod honing machine, or move to a different city. |
tcoop1100 Samba Member
Joined: August 12, 2004 Posts: 194 Location: Hilo, Moku O Keawe, Moana Pakipika
Posted: Thu Jun 01, 2023 1:28 pm Post subject: Re: Piston Pins Too Tight? |
My understanding has always been to have a push fit in the rod and an interference fit in the piston at room temperature. Any "float" of the piston in the cylinder is from the pin in the rod, not the pin in the piston. If you ream the piston for a push fit wouldnʻt you have too much clearance at operating temps and have pistons rocking in the cylinders, increasing wear, scuffing and galling? I briefly heat the pistons at the pin boss and pins slide right in, easy-peasy, no hammer required. Removal, same thing. No hammer, no chance of damaging anything. _________________ Aloha,
Tim
January '57 Sedan with April '64 40hp big bore |
Rome Samba Member
Joined: June 02, 2004 Posts: 9641 Location: Pearl River, NY
Posted: Thu Jun 01, 2023 3:34 pm Post subject: Re: Piston Pins Too Tight? |
My choice is this small sanding cylinder for a 1/4" electric drill, found at local HW store in a fine grit such as 220. The diameter I chose is slightly larger (e.g., 1" = 25 mm) than the small end bushing (22 mm) so that there is nearly no compression of the flaps. Just a single push-thru and pull-back. Spray the bushing with WD-40 to clean off debris, and do a test fit of the wrist pin with a nice easy and smooth push-thru. I also run this cylinder around the perimeter of the wrist pin holes of the pistons so that any minor standing-up fragment does not hinder the movement of the wrist pin into each side of the piston hole.
Hack? Yes, but effective. |
VWporscheGT3 Samba Member
Joined: September 01, 2006 Posts: 2076 Location: Gardnerville, NV
Posted: Thu Jun 01, 2023 3:41 pm Post subject: Re: Piston Pins Too Tight? |
tcoop1100 wrote: |
My understanding has always been to have a push fit in the rod and an interference fit in the piston at room temperature. Any "float" of the piston in the cylinder is from the pin in the rod, not the pin in the piston. If you ream the piston for a push fit wouldnʻt you have too much clearance at operating temps and have pistons rocking in the cylinders, increasing wear, scuffing and galling? I briefly heat the pistons at the pin boss and pins slide right in, easy-peasy, no hammer required. Removal, same thing. No hammer, no chance of damaging anything. |
Dont take this as me being a jerk as there is no tone intended. piston pin fit on a cast piston is usually anywhere from .0005" to .0006" meaning your pin bore in your piston should be AT LEAST 5 tenths larger than your pin, forgings on average are closer to almost a full thou pin to piston. the only time you should have any interference is with a PRESS FIT rod... like the old SBC's and such meaning the pin is pressed into the ROD. floating is full floating , you want that pin as free as possible.
If a piston builder is doing there job a pin should fit nice and easy with little to no effort. its when the pistons have been run that you will usually see high spots at the locking grooves from the pin going back and forth over the millions of revolutions its spun pounding at the locks, when a pin only has 5 to 10 thou to travel "pounding" is a gross exaggeration
-Trevor
UEM pistons _________________ Schnell, SCHNELL!
I like being wrong, Because, it is another opportunity to learn. If you stop learning from your mistakes than what is the point?
If you have any questions about Forged ICON 4032 VW pistons just shoot me a line. |
modok Samba Member
Posted: Thu Jun 01, 2023 4:33 pm Post subject: Re: Piston Pins Too Tight? |
You probably aren't old enough to be familiar with why it was how it was.
It has a lot to do with the piston alloy, and the piston alloy had to do with ease of casting and machining, before CARBIDE never mind PCD.
LOW silicon cast pistons in our OLD vw they had the pins a zero fit at room temp. So did many engines with similar pistons and floating pins.
This gave better longevity.... keeping in mind in those days it was common to re-groove and knerl the piston and use it again, and in they even had oversize pins too.
Floating pins were necessary to get away with running the pin so tight in the piston.
Today almost nothing is using pistons like that, but there are still a few if you look.
oil and oil filters and piston alloys have changed to the point that the pin wearing out the piston bores is a very rare problem so it isn't necessary to make it as tight as practical to start.
The physics have not changed. If you wanted to run a low silicon racing piston the same way today you could, and it would work, but it would be super rare anybody would want to do that.
Personally, on the pin bushing I would like to have slightly MORE clearance than VW spec, ideally .0008", because loose is happy when your crank is a noodle. And with an oil filter and a good tune there is almost no wear. |
hulbyw Samba Member
Posted: Thu Jun 01, 2023 4:58 pm Post subject: Re: Piston Pins Too Tight? |
Thanks for all the help folks. I will have a chat with local VW shop today to see what they can offer to ream out the small ends and maybe the pistons as well. Pistons are NOS Mahle 90.5 (bought about 25 years ago). Seem to remember being told they were forged but honestly have no idea and no skills to tell by just looking at them whether they are cast or forged. |
Posted: Thu Jun 01, 2023 5:12 pm Post subject: Re: Piston Pins Too Tight? |
VWporscheGT3 wrote: |
tcoop1100 wrote: |
-Trevor
UEM pistons |
So wouldn't there be enough float at operating temps, similar to my heating the pistons to install the pins? I'm just wondering if there is a reason for having an interference fit, besides the continual fit quality issues we seem to have with all the parts we buy these days.
I've never seen any issues with tight pins I've installed, but the motors I've built are all stock or close to it. Is there something else I should worry about that I haven't seen yet? _________________ Aloha,
Tim
modok Samba Member
Posted: Thu Jun 01, 2023 6:43 pm Post subject: Re: Piston Pins Too Tight? |
25 year old mahle pistons would be a good time capsule for 50 year old piston technology.
They didn't really change much over the years.
And another thing that experience teaches better than words..... is you can hone a very close fit of say .0003" and have the pin slide free, but then leave that part on a shelf for a year or two then it won't slip through anymore. It only gets smaller as oxide forms. Pin bushings and valve guides are this way.
If that's the problem here I might recommend you make a basic scotch bright flap wheel and run that wet with solvent to freshen up the pin bushing bore.
Pistons bored with PCD will do that far LESS than older methods because it's so much smoother, or you might say pre-glazed surface finish.
And yet again another difference in technology is that a HONED surface CAN run tighter than a super smooth PCD bored hole because of the surface texture, but when that texture gets smooshed flat in operation then the true clearance is is slightly larger than measured.
New ways work, old ways work, but mixing them together may be confusing. |
Posted: Thu Jun 01, 2023 9:14 pm Post subject: Re: Piston Pins Too Tight? |
modok wrote: |
I always learn something from your posts, Modok. Just to clear one thing up, though- right now I'm working with brand new AA 83mm 40hp p&c's. The pins are too tight for push fit at room temperature. _________________ Aloha,
Tim
