VWinny Samba Member
Posted: Fri Jun 02, 2023 3:58 pm Post subject: 95 eurovan manifold vaccum pressure sensor location |
anyone know where this is? I'm trying to resolve a check engine code 2222 |
EuroTec Samba Member
Joined: August 24, 2020 Posts: 381 Location: Asheville, North Carolina
Posted: Fri Jun 02, 2023 7:08 pm Post subject: Re: 95 eurovan manifold vaccum pressure sensor location |
It's located inside the ECU next to the battery. There should be a vacuum line going to it. Check that line and all other vacuum lines for leaks. _________________ If it ain't broke, don't fix it!
TheOneTrueQuux Samba Member
Posted: Mon Jun 05, 2023 8:27 am Post subject: Re: 95 eurovan manifold vaccum pressure sensor location |
VWinny wrote: |
See this thread:
https://www.thesamba.com/vw/forum/viewtopic.php?t=754716&highlight=map+sensor
If you have even minimal soldering skills, or know someone who does, this is easily resolvable for about $30 in parts.
UPDATE:
I checked eBay, and while the sensor is still available, it's only from one source, and is more expensive, about EUR 45 now. Still not a bad deal considering the alternative is to source another used ECU which may also have a bad sensor. |
VWinny Samba Member
Posted: Fri Jun 23, 2023 7:08 pm Post subject: Re: 95 eurovan manifold vaccum pressure sensor location |
I swapped out the map with a "new"one that was on ebay, they are coming from ireland around 40 bucks.
ran great for a while then had same no start issues.
sent the computer in to have it inspected and they said the map was faulty. company sent me a new one ive just replaced the one that failed inspection with the new one. will update after install this weekend.
i have a suspicion that the exhaust tubing coming from the valve cover that goes to the intake is failing these sensors.? |
