Diesel Vanagon starter - replace or rebuild?
Country Doc1
Country Doc1 is offline
PostPosted: Sun Jun 04, 2023 11:46 am    Post subject: Diesel Vanagon starter - replace or rebuild? Reply with quote
Hi to all, thanks in advance for any advice!
I have an 89 factory TD Vanagon that now has a 1.9AAZ, and the starter clutch drive is starting to slip when it's hot. I have had some people tell me that the rebuilds use aftermarket clutch drives which fail within a few years, and that it's better to rebuild the original Bosch one.
I also spoke to a rebuilder in the Finger Lakes area who recommended consider a Mahle starter instead of a rebuild, as a direct replacement option, but I can't find any reference to a Mahle starter that is a compatible fit?
For reference, the PN he suggested was Mahle MAH-MS285.
Thanks!
dc
crazyvwvanman
crazyvwvanman is offline
PostPosted: Sun Jun 04, 2023 12:59 pm    Post subject: Re: Diesel Vanagon starter - replace or rebuild? Reply with quote
https://www.summitracing.com/parts/mah-ms285
Country Doc1
PostPosted: Sun Jun 04, 2023 1:06 pm    Post subject: Re: Diesel Vanagon starter - replace or rebuild? Reply with quote
Yes, that's the only internet page I could find - I'm just not sure it would actually work, given that I can't find any reference to it on thesamba or other Vanagon places? (The starter shop seemed to think it would).
crazyvwvanman
PostPosted: Sun Jun 04, 2023 1:56 pm    Post subject: Re: Diesel Vanagon starter - replace or rebuild? Reply with quote
https://partinfo.org/mahle-original-ms285/
Sodo
Sodo is offline
PostPosted: Sun Jun 04, 2023 2:12 pm    Post subject: Re: Diesel Vanagon starter - replace or rebuild? Reply with quote
While you're under the van, optimizing....
it's a good time to ALSO delete that satanic front transaxle ground strap
and upgrade to a proper eqpt ground from the starter case to the chassis.
Someone told me the diesel bolt head is in a recess and to do this you need to procure a longer bolt+spacer. I've never seen a diesel starter bolt.
....KTMs, GasGas, SPOT mtb
Country Doc1
PostPosted: Sun Jun 04, 2023 2:37 pm    Post subject: Re: Diesel Vanagon starter - replace or rebuild? Reply with quote
Ah, thanks! That looks like the Mahle would fit. The rebuilder felt it was a better option than the reman Bosch ones - maybe I'll go that way.
Thanks for the tip on the ground strap Smile
dc
crazyvwvanman
PostPosted: Sun Jun 04, 2023 4:06 pm    Post subject: Re: Diesel Vanagon starter - replace or rebuild? Reply with quote
Diesels are different. The two 19mm headed starter bolts are not a great place to add a ground over to the chassis.
Other spots are better IMHO.
I've replaced a bunch of diesel van starters but have never run into a Mahle branded one.
It seems lots of old big "names" now sell asian parts so I'd hesitate to pay much for the Mahle without knowing where the current supply comes from.
You can buy new diesel starters from asia for $75+ and they seem to last as well as some rebuilt ones.
Mark
it's a good time to ALSO .....upgrade to a proper eqpt ground from the starter case to the chassis.
Gnarlodious Premium Member
Gnarlodious is offline
PostPosted: Sun Jun 04, 2023 4:36 pm    Post subject: Re: Diesel Vanagon starter - replace or rebuild? Reply with quote
Good time to upgrade to the SR28X gear reduction starter. It'll cost more but be way better. It is smaller so easier to install, and less heavy so you won't bash your brains in if you drop it on your face. I put in a Genuwine new Bosch starter in 2008 and it is still going strong. Worth every dollar.
ALIKA T3
ALIKA T3 is offline
PostPosted: Sun Jun 04, 2023 10:41 pm    Post subject: Re: Diesel Vanagon starter - replace or rebuild? Reply with quote
X is for rebuild. Same at VW's.
SR28 is the late T3 diesel starter. I'm not sure you can find genuine Bosch these days, the market is plagiued with chinese junk, the aluminum housing is made of sugar and internals much cheaply made, plastic parts that don't withstand a lot of heat...
I would go the Tdi way. SR0408X with adapter plate.
valvecovergasket
valvecovergasket is offline
PostPosted: Mon Jun 05, 2023 7:48 am    Post subject: Re: Diesel Vanagon starter - replace or rebuild? Reply with quote
i just went through this on our tdi swapped van
it had the original starter, i took it to my local rebuilders and they decided itd be easier to replace with a new bosch unit
it was bosch part number 001 110 009
its smaller than the really big original starter, and appeared to not be too exotic or tough to get since they only charged me something like $130 for it.
i looked into the tdi swaps but it seemed like the juice wasnt worth the squeeze considering how cheap this one was.
MegaSquirt resource - SpitfireEFI.com
gone, but not forgotten: '83 tdi westy - swap thread
ALIKA T3
ALIKA T3 is offline
PostPosted: Mon Jun 05, 2023 11:01 am    Post subject: Re: Diesel Vanagon starter - replace or rebuild? Reply with quote
Looks like it was used until recently on Polaris machines. Interesting!
Found them rebuilt only though.
https://www.motorcityreman.com/booe00st1.html
Description: Starter
OEM(s): Bosch, Hatz, Lombardini
Voltage: 12
Power: 1.6kW / 2.14HP
Rotation: CW
Starter Type: PMGR
Number of Teeth: 9
Gear OD: 1.146in / 29.1mm
Mtg Ear 1 Hole: 10mm Unthreaded
Mtg Ear 2 Hole: 10mm Unthreaded
Notes:
Lombardini Diesel Engines on Hatz Applications
Replaces:
Bosch 0001109009, 0-001-109-009, 0-001-110-042
Used On:
Arctic Cat 700 Diesel 2007, 2008, 2009, 2010, 2011, 2012, 2013, 2014, 2015
Massey Ferguson 700 Diesel 2007, 2008
Piaggio PORTER Daihatsu / Lombardin
Piaggio QUARGO Daihatsu / Lombardin
Polaris Brutus 1000 HD PTO 2015, 2016, 2017, 2018
Polaris Ranger 1000 Diesel 2015, 2016, 2017
Polaris Ranger 1000 Diesel Crew 2015, 2016, 2017
Polaris Ranger 1000 Diesel HST 2015, 2016, 2017
valvecovergasket
PostPosted: Mon Jun 05, 2023 7:39 pm    Post subject: Re: Diesel Vanagon starter - replace or rebuild? Reply with quote
Granted, I haven't started the van yet as I'm wrapping up a suspension and brake refresh but it sure popped into the stock spot like it was meant to go there.
And I trust these guys they've been really good with oddball custom stuff and all they do is alternators and starters.
westyventures
westyventures is offline
PostPosted: Tue Jun 06, 2023 11:18 pm    Post subject: Re: Diesel Vanagon starter - replace or rebuild? Reply with quote
Ditch the antiquated starter and upgrade to the TDI starter, using the adaptor plate available from T3 Technique. Self-supporting nose too so no more interference issues with larger clutch setups including the dual-mass.
Country Doc1
PostPosted: Thu Jun 08, 2023 1:54 pm    Post subject: Re: Diesel Vanagon starter - replace or rebuild? Reply with quote
Thanks Karl, unfortunately missed this post before ordering the Bosch SR28X.
crazyvwvanman
PostPosted: Thu Jun 08, 2023 8:45 pm    Post subject: Re: Diesel Vanagon starter - replace or rebuild? Reply with quote
Hopefully the SR28X you receive will be the newer type gear reduction version.
Bosch ships large older type and compact newer type under the same rebuild number.
Mark
