RexMax Samba Member
Joined: July 21, 2022 Posts: 99 Location: S.F Bay area
Posted: Sun Jun 04, 2023 2:48 pm Post subject: Transaxle undercoating. Was it ever done by a dealer? |
So my VW friend gave me a transaxle to replace the one in my 74. It came out of a 74 with a blown motor that he bought for parts, and he says it should be a good one. Here's the deal, it is covered with what looks like undercoating. Thick, sticky tar like, and it doesn't come off easily. He thought that maybe the nose cone, or the gear case gaskets were leaking and the owner sprayed some kind of sealer on it. This would have been many years ago. Before the advent of stuff like Flexseal. The thing is, it's not just in that area. It's everywhere, and I mean everywhere. Halfway to the top of the bellhousing, starter mtg. the side cover, even the axle shafts that are still attached. We'll never know because the body is long gone, and he doesn't remember what the rest of the underside looked like. I've has some success with pressure washing, spraying it with WD40, and using a wire wheel. Rinse and repeat. I'm putting a dent in it, but not a lot What's your thoughts? |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76940 Location: Sneaking up behind you
Posted: Sun Jun 04, 2023 2:51 pm Post subject: Re: Transaxle undercoating. Was it ever done by a dealer? |
Not factory. _________________ Glenn
Member #1009
#BlueSquare |
RexMax Samba Member
Posted: Sun Jun 04, 2023 3:09 pm Post subject: Re: Transaxle undercoating. Was it ever done by a dealer? |
Glenn wrote: |
Not factory. |
I didn't think so either, but what do think it is? Best guess without seeing it. |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9772 Location: Oregon
Posted: Sun Jun 04, 2023 4:01 pm Post subject: Re: Transaxle undercoating. Was it ever done by a dealer? |
RexMax wrote: |
Glenn wrote: |
Not factory. |
Use a solvent of some sort, to soften the undercoating.
Believe it or not, WD-40 is a solvent.
Spray it on the coated goodies and wait a day.
The solvent should soften the undercoating a bit. Reapply as needed, until the trans is clean to your liking. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
busdaddy Samba Member
Posted: Sun Jun 04, 2023 4:15 pm Post subject: Re: Transaxle undercoating. Was it ever done by a dealer? |
Many years of gear oil sweating out or leaking and spreading in a hot dusty climate hardens up just like undercoating, even worse if it was seeded by some sort of dealer applied "rust proofing" coating beforehand, long term solvent soaking is the only way to soften it up. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
RexMax Samba Member
Posted: Tue Jun 06, 2023 5:08 pm Post subject: Re: Transaxle undercoating. Was it ever done by a dealer? |
I'm not getting anywhere with this stuff. I don't expect it to look like new, but I would like it to look halfway decent, and easier to handle without looking like I've been tared and feathered. I have a portable sandblaster. Would you have any objection to trying it? I plan on replacing all the seals anyway, plug the breather hole in the nosecone, and protect the mainshaft. Blast it and then pressure wash this thing. My understanding is people use these in sand rails, so what could it hurt if I'm reasonable careful? |
Posted: Tue Jun 06, 2023 5:20 pm Post subject: Re: Transaxle undercoating. Was it ever done by a dealer? |
Don't be surprised if the sand just bounces off that stuff, but it's worth a try.
Steam and heat is also effective, or maybe a propane torch and wire brush or scraper? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Busstom Samba Member
Joined: November 23, 2014 Posts: 3853 Location: San Jose, CA
Posted: Tue Jun 06, 2023 6:23 pm Post subject: Re: Transaxle undercoating. Was it ever done by a dealer? |
busdaddy is right, I'm going through the exact same pleasantry right now, and my trans is out of my '65 which had no undercoating anywhere. Looks exactly like what you're describing, thick, heavy, coating that's tough as nails. And I agree, blasting sand would bounce off this stuff, I've tried it before (not on this particular project).
I've also tried a heavy duty heat gun, which does help prior to scraping, but be prepared for SUPER stinky smoke (or fumes at the least), which is probably worse than huffing crack from a hot spoon.
Best to use a 1" soft paint brush or similar, work in small-ish areas at a time, and soften the stuff up with solvents like mentioned already. I also got some nice little plastic scrapers off Amazon for this, because I didn't want to gouge up the case with a screwdriver or putty knives. Your mileage may vary, but I take LONG breaks between, like a week here and a week there!
Mine...
_________________ My name's Steve and it's pronounced "Bust 'em" (cuz people think I'm Tom) 😏 |
RexMax Samba Member
Posted: Tue Jun 06, 2023 7:11 pm Post subject: Re: Transaxle undercoating. Was it ever done by a dealer? |
I'm also tempted to try some paint remover. I have a gallon of the not
environmentally friendly stuff. It will take your skin off. I may try that in a small area and see how it does. I'll let you know how that goes. |
sb001 Samba Member
Posted: Tue Jun 06, 2023 8:22 pm Post subject: Re: Transaxle undercoating. Was it ever done by a dealer? |
Agree with busdaddy that is just crap from axle grease or maybe gear oil hardened up and dried out over the years. Both of my spare autostick trannies I have had that gunk on them.
I had some pretty good luck with oven cleaner, might try that to loosen it up and then scrape it off. _________________ I'm the humblest guy on this board.
1600 SP engine
Solex 30 PICT 3 carburetor
RexMax Samba Member
Posted: Tue Jun 06, 2023 10:04 pm Post subject: Re: Transaxle undercoating. Was it ever done by a dealer? |
sb001 wrote: |
I had some pretty good luck with oven cleaner, might try that to loosen it up and then scrape it off. |
Oven cleaner. Good call. I've used it before on the tin work, and it worked great. I completely forgot. |
BMFBMF Samba Member
Joined: November 13, 2020 Posts: 358 Location: Swtzerland
Posted: Wed Jun 07, 2023 1:24 am Post subject: Re: Transaxle undercoating. Was it ever done by a dealer? |
Watch out for oven cleaner on aluminium though!!! Very corrosive.
As suggested above I would try some kind of steam cleaning service. _________________ -----Slava Ukraini-----
1971 Stock South African Beetle 1300 : My mom's european "Thin Chick" spec. Completely stock with torsion bar front, swingaxle rear, smooth hubs, single MC, 40 mm shoes, 31PICT3 carb and 5 bolt drums all round, currently Running a 1976 SF:AS engine with the original SF:AD engine overhauled in a box, waiting to go back in one day. |
Posted: Wed Jun 07, 2023 8:08 am Post subject: Re: Transaxle undercoating. Was it ever done by a dealer? |
X2, some oven cleaners will remove more transmission metal than goo, be careful.
The paint stripper might work though. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
busman78 Samba Member
Joined: August 17, 2004 Posts: 4524 Location: Oklahoma City, OK
Posted: Wed Jun 07, 2023 9:21 am Post subject: Re: Transaxle undercoating. Was it ever done by a dealer? |
If you use oven cleaner which I found to be the fastest do not spray on and walk away. Coat the trans, watch it attack the grime, give it a scrub with a brush and with a a small tool dig out the crud in corners, rinse off and coat again, repeat as needed. Use a soapy mixture after the final coat of oven cleaner is rinsed off. Oven cleaner will leave the case with a dullish grey appearance.
Put a a little plug in the vent hole so none of the cleaner makes its way inside. |
OTTO 1303 Samba Member
Joined: March 17, 2020 Posts: 636 Location: Louisiana
Posted: Wed Jun 07, 2023 1:04 pm Post subject: Re: Transaxle undercoating. Was it ever done by a dealer? |
Looks like mine did.
Diesel and a lot of scraping with wood and plastic.
Followed by a good pressure wash.
Good Luck _________________ 74 Super Sun Bug - OTTO
74 Super - DANZIG
74 Super - HERZOG |
RexMax Samba Member
Posted: Wed Jun 07, 2023 2:50 pm Post subject: Re: Transaxle undercoating. Was it ever done by a dealer? |
busdaddy wrote: |
The paint stripper might work though. |
the paint stripper did not work. All it did was turn that stuff into a slimy mess that spread it even more. The oven cleaner on the other hand is working. I got 6 cans at the dollar store, it was cheap, and it's not very strong. I wouldn't wash my face with it, but it takes quite awhile to make a dent in it. I spray it on a small area, wait 2 hours, and hit with a wire brush. How do you eat an Elephant? One bite at a time. |
Posted: Wed Jun 07, 2023 3:19 pm Post subject: Re: Transaxle undercoating. Was it ever done by a dealer? |
Original Easy-Off (sp), the stuff that burns your eyes and makes you gag, not the environmental friendly stuff. Also Castro Super Clean full strength will work. If the stuff you got is that weak just leave on a little longer. |
