jbhurley92 Samba Member
Posted: Mon Jun 05, 2023 7:42 pm Post subject: 85 Vanagon pressure in pressure tank while cold |
New German blue cap installed.
Before driving coolant was constantly pushing to overflow and spilling out
Now with new cap everything seems fine drove it around for 2 hours on multiple occasions but radiator always has pressure in it and if I open the cap after sitting for +12 hours it comes shooting out.
Note after driving the overflow tank hasn't change and honestly the pressure tank looks fine until I open it after letting it sit till it's cold.
Is this a head gasket failure? This just happened so fast and I'm leaving on a trip in 1 week. I can overnight from busdepot and get changed this week if I must..
Edit recently I have been so defeated with this van. I have never gotten to take more than 1 trip without it self destructing.
I recently dual carbed it because I could never get it to run worth a crap. Now it runs good and this happens. |
Posted: Tue Jun 06, 2023 6:17 am Post subject: Re: 85 vanagon pressure in pressure tank while cold. |
Anyone? |
bobhill8 Samba Member
Posted: Tue Jun 06, 2023 7:41 am Post subject: Re: 85 vanagon pressure in pressure tank while cold. |
I don't have any suggestions as to why the pressure is still there after 12 hours, but I would definitely suggest testing the coolant with a chemical test for exhaust gases. It worked perfectly for me (unfortunately) when I was getting exhaust from waterjacket seal failure. You can get the test kit at any FLAPS.
_________________ 1986 Westy
1971 Squareback |
Posted: Tue Jun 06, 2023 8:22 am Post subject: Re: 85 vanagon pressure in pressure tank while cold. |
bobhill8 wrote: |
[Pic] |
What were your symptoms? |
dabaron Samba Member
Joined: June 21, 2018 Posts: 2559 Location: Philly, mang
Posted: Tue Jun 06, 2023 8:30 am Post subject: Re: 85 vanagon pressure in pressure tank while cold. |
jbhurley92 wrote: |
bobhill8 wrote: |
[Pic] |
a constant stream of bubbles entering the pressure tank from the large top hose and eventually coolant puking out of some where due to the pressure... _________________ 1991 Vanagon GL Camper
"burnin oil and cookin coils" -- Destructo
BiWerks Design, LLC |
Posted: Tue Jun 06, 2023 8:39 am Post subject: Re: 85 vanagon pressure in pressure tank while cold. |
I do see bubbles up top but it isn't constant just when I rev up I'll see a like 4-5 big bubbles and then almost looks foaming but I can see the liquid moving. |
Posted: Tue Jun 06, 2023 8:42 am Post subject: Re: 85 vanagon pressure in pressure tank while cold. |
jbhurley92 wrote: |
get the magic color changing tester, you need to rule it out. _________________ 1991 Vanagon GL Camper
AndyBees Samba Member
Joined: January 31, 2008 Posts: 2329 Location: Southeast Kentucky
Posted: Tue Jun 06, 2023 8:46 am Post subject: Re: 85 vanagon pressure in pressure tank while cold. |
Subscribed ..... _________________ '84 Vanagon Tin-top, ALH TDI. 1989 Tin-top
1983 Air-cool, 225k miles, 180k miles mine. Seven trips to Alaska from 1986 thru 2003. |
valvecovergasket Samba Member
Posted: Tue Jun 06, 2023 8:54 am Post subject: Re: 85 vanagon pressure in pressure tank while cold. |
jbhurley92 wrote: |
like you get coolant shooting out and it overflows, or theres just a little hiss of air still? _________________ MegaSquirt resource - SpitfireEFI.com
gone, but not forgotten: '83 tdi westy - swap thread |
Posted: Tue Jun 06, 2023 9:01 am Post subject: Re: 85 vanagon pressure in pressure tank while cold. |
valvecovergasket wrote: |
jbhurley92 wrote: |
like you get coolant shooting out and it overflows, or theres just a little hiss of air still? |
Big hiss and coolant comes shooting out.
[/img] |
Posted: Tue Jun 06, 2023 9:05 am Post subject: Re: 85 vanagon pressure in pressure tank while cold. |
jbhurley92 wrote: |
jbhurley92 wrote: |
[Pic] |
go get the tester and report back. _________________ 1991 Vanagon GL Camper
Posted: Tue Jun 06, 2023 9:16 am Post subject: Re: 85 vanagon pressure in pressure tank while cold. |
dabaron wrote: |
go get the tester and report back. |
Just picked up some more blue stuff and a harbor freight tester + a radiator pressure kit.. |
Posted: Tue Jun 06, 2023 9:17 am Post subject: Re: 85 vanagon pressure in pressure tank while cold. |
Do I need to drive it around and then remove some coolant and test or just let it warm up? |
Posted: Tue Jun 06, 2023 10:46 am Post subject: Re: 85 vanagon pressure in pressure tank while cold. |
There are most likely gases in the coolant already, but the test might be more of a slam dunk, quick color change if you let it run for a bit. When mine was bad, I could look in the pressure tank with the cap off and watch bubbles and smoke come out. If it erupted out of the overflow tank already, it is most likely your problem.
terrible photo, but I could see wisps of smoke, not steam and you could smell it as well. _________________ 1986 Westy
1971 Squareback |
Posted: Tue Jun 06, 2023 10:52 am Post subject: Re: 85 vanagon pressure in pressure tank while cold. |
bobhill8 wrote: |
[Pic]
terrible photo, but I could see wisps of smoke, not steam and you could smell it as well. |
So it did come out of the overflow with 2 different caps but I could blow and suck through them with just my mouth. With the new German cap the overflow hasn't move at all.
I'm wondering if I just have a shit ton of air in my system then. I drove it for +1 hour yesterday and the overflow never moved. But I waited for 4 hours and opened the top and coolant came rushing out.
I'm pretty sure it went down actually
With the old cap if I drove for a while/idled in driveway it would start filling up.
But I could sit there revving it in the driveway and it would start sucking it back over. |
Posted: Tue Jun 06, 2023 11:22 am Post subject: Re: 85 vanagon pressure in pressure tank while cold. |
jbhurley92 wrote: |
neither.
fill the tester with the fluid to the line, start the engine, open the blue cap and shove the tester in the hole. rev the engine a few times. let it idle for a few seconds and then rev again.
it will change color pretty quickly if you have combustion gases in the coolant. _________________ 1991 Vanagon GL Camper
Posted: Tue Jun 06, 2023 11:45 am Post subject: Re: 85 vanagon pressure in pressure tank while cold. |
dabaron wrote: |
jbhurley92 wrote: |
neither.
it will change color pretty quickly if you have combustion gases in the coolant. |
So I hooked up a radiator pressure kit on it and put it up to 15-16 pounds it held and when I let pressure off it the coolant came rushing out again |
Posted: Tue Jun 06, 2023 12:12 pm Post subject: Re: 85 vanagon pressure in pressure tank while cold. |
dabaron wrote: |
jbhurley92 wrote: |
neither.
13b Bro Samba Member
Posted: Tue Jun 06, 2023 1:46 pm Post subject: Re: 85 vanagon pressure in pressure tank while cold. |
Isn't there always head pressure on that tank? |
Posted: Tue Jun 06, 2023 1:50 pm Post subject: Re: 85 vanagon pressure in pressure tank while cold. |
13b Bro wrote: |
I don't think its normal to lose 1/4 of my coolant when I open my cap when it's cold |
