Oil Light Flickering
BeetleGuy495
BeetleGuy495 is offline
PostPosted: Wed Jun 07, 2023 8:31 am    Post subject: Oil Light Flickering Reply with quote
Hey all,
For starters, I have a 1984 Mexican model Vw bug. As of recently, it runs perfectly for about 45 minutes worth of driving, then as it idles the oil light starts dimly flickering, but the moment I either rev the engine slightly or shift into gear and start driving, it turns completely off. It also flickers brighter and brighter as I idle the longer the car runs. Any help as to why it’s doing this would be greatly appreciated.
Eric&Barb
Eric&Barb is offline
PostPosted: Wed Jun 07, 2023 1:16 pm    Post subject: Re: Oil Light Flickering Reply with quote
BeetleGuy495 wrote:
Hey all,
Sounds like it needs the idle RPM turned up slightly. Otherwise it could be worn out engine, running too lean, missing engine tin and/or seals, etc. or a combo of problems.
Might help if you posted lots of images of the engine for all here to see. Then can chime in on any obvious faults.
In Stereo, Where Available!
sb001
sb001 is offline
PostPosted: Wed Jun 07, 2023 3:25 pm    Post subject: Re: Oil Light Flickering Reply with quote
Normal. Even says in the owner's manual you might get some oil light flickering. See bottom of this page (This is taken from the latest English version owner's manual I could find in the tech section here which was 1979, but should still apply to yours):
I notice you said "recently" as in, it just started recently happening? What oil do you use (weight/ viscosity)?
I'm the humblest guy on this board.
1600 SP engine
Solex 30 PICT 3 carburetor
Bosch 113905205AE autostick distributor
mukluk
mukluk is offline
PostPosted: Wed Jun 07, 2023 5:06 pm    Post subject: Re: Oil Light Flickering Reply with quote
A little flickering at idle after you just finished some high speed cruising is normal as noted, but for the warning lamp to get progressively brighter at idle the longer the car runs indicates the oil is thinning out too much or the engine is getting worn out.
Do you have any means of measuring the oil temperature?
Has it been a while since the last time the oil was changed?
Does the oil have a fuel smell to it?
How many miles are on the engine and what weight oil are you using?
Does the engine also lack power or exhibit signs of overheating when the oil warning lamp is getting brighter?
Cusser
Cusser is offline
PostPosted: Wed Jun 07, 2023 5:38 pm    Post subject: Re: Oil Light Flickering Reply with quote
Under such conditions, my oil light in both my VWs have flickered since the 1970s.....
