mtjade8384 Samba Member
Posted: Fri Jun 09, 2023 6:44 pm Post subject: 2.1 WBX pushrod covers don't fit |
I am in the final steps of my wbx 2.1 rebuild project and run into the problem in installing the exhaust system. I found I am unable to line up the holes to screw in the nuts at the bottom of the covers. I am wondering if I have messed up by installing them on the wrong sides. Does anyone know for sure that the covers are side specific and have to be installed on the correct side? Thanks in advance for any help. |
dabaron Samba Member
Joined: June 21, 2018 Posts: 2559 Location: Philly, mang
Posted: Fri Jun 09, 2023 6:57 pm Post subject: Re: 2.1 WBX pushrod covers don't fit |
if you are talking about the push rod tube shields, they are side specific. the one with the big cut out is for the oil filter. i ran without them for about 10,000 miles and then went with the Go Westy steel version that is detachable without removing the exhaust header nuts. _________________ 1991 Vanagon GL Camper
"burnin oil and cookin coils" -- Destructo
BiWerks Design, LLC |
Posted: Fri Jun 09, 2023 7:12 pm Post subject: Re: 2.1 WBX pushrod covers don't fit |
dabaron wrote: |
if you are talking about the push rod tube shields, they are side specific. |
Thank you so much for the quick reply. I noticed that the driver side shield seems to get in the way of the oil cooler and the holes at the bottom don't line up. Oh well, I guess a couple of hours of R/R of the shields has to be done now. |
Posted: Mon Jun 12, 2023 4:09 pm Post subject: Re: 2.1 WBX pushrod covers don't fit |
Swapped the pushrod shields and found all holes lined up perfectly. These shields were from a 1.9 engine in fact. They still fit perfectly. Completed reassembling the exhaust and ready to start the engine. Keep my fingers crossed and hope it goes well. |
