AndrewM Samba Member
Joined: February 18, 2002 Posts: 496 Location: Charlotte, NC
Posted: Sat Jul 10, 2004 9:28 pm Post subject: no rr parking light? |
Or right taillight when the headlights are on.
The lights on my 64 were all working fine...brake lights, parking lights, turn signals . While going up a steep driveway the battery bounced and bumped the right rear bulbholder. It broke the connection and the result was a weak right rear brake, parking, and headlights on taillight...but they all still worked.....just very dim(bad ground). I order a new repro WW bulb housing and install it using my old seal and chrome ring. Now the brake light is nice and bright so is the turn signal but I have no light on with either the parking lights or headlights turned on.
Any ideas? |
KombiMonster Samba Member
Joined: April 17, 2001 Posts: 2751 Location: Central Cal.
Posted: Sat Jul 10, 2004 10:09 pm Post subject: |
This may be a stupid answer...but do you have a dual filliment bulb in there...? _________________ FOOK CANCER
*WANTED* |
58Type2 Samba Member
Joined: June 15, 2002 Posts: 636 Location: Hell's Soup Kitchen
Posted: Sat Jul 10, 2004 10:51 pm Post subject: |
I would check that dual filament as well. Also, try grounding the housing to the body or frame. Mine would not work til I did that and I bought them from WW as well.
Jax _________________ Jax
Few VW's, a few 2-wheeled mistresses, and a kayak for good measure. |
ToolBox Samba Member
Joined: January 27, 2004 Posts: 3439 Location: Detroit, where they don't jack parts off my ride in the parking lot of the 7-11
Posted: Sun Jul 11, 2004 3:41 pm Post subject: |
Check the fuse yet????????? |
Friedpotatoes Addicted4life
Joined: April 04, 2003 Posts: 1215 Location: Fresno California
Posted: Sun Jul 11, 2004 4:07 pm Post subject: |
If the light for the lisence plate. did work and still does. It would be something with the housing of the tail light. _________________ 56- Wolfsburg Single Cab
57- Oval Window Bug (Agave Green) |
bus-deciple Samba Member
Posted: Sun Jul 11, 2004 7:34 pm Post subject: |
this may also sound kind of stupid, but make shure your light bulb is in right.We were leaving for a show a few months ago in my 63 bug when we noticed the turn signal wasent working.we spent about an hour trying to figure out the problem, when I gave the light bulb a twist and it worked. |
