56 vert Jimmy Sprinkles
TomVaughan64
TomVaughan64 is offline
PostPosted: Sun Jan 07, 2024 12:06 am    Post subject: Re: 56 vert Jimmy Sprinkles Reply with quote
Great details. Thank you for posting this for all of us to follow along. My bucket list includes rebuilding one of these transmissions. Your posts will be a great reference. I have a 10-ton benchtop press with 16-inch max opening. Will that work for this type of transmission work or do I need one of the floor stand models?
Tom
"Begin with the end in mind"
Stephen Covey
"Keep focused and seeking knowledge, you will never find disappointed, only small hiccups!"
Jimbo
56 Old Speed Euro Deville Influenced Build Returning
Returning My 55 Ragtop To Stock
esde
esde is offline
PostPosted: Sun Jan 07, 2024 1:59 pm    Post subject: Re: 56 vert Jimmy Sprinkles Reply with quote
TomVaughan64, I think the 16" opening is enough, but you may need to have an opening under it for the shafts to drop into. For example, when pressing the bearing and gears off the input shaft, it needs space underneath to drop into, and the shaft is pretty long to begin with. If it's on a workbench you could probably just cut a hole right under the press.
modok wrote:
esde
esde is offline
PostPosted: Mon Jan 08, 2024 8:13 am    Post subject: Re: 56 vert Jimmy Sprinkles Reply with quote
*fixed to add all the missing pictures*
Getting closer to sealing this thing up. But, I did have a few more stumbling blocks, which I will detail here. I will say, that if I was simply rebuilding some parts back into their original case things would be much easier.
The differential, it seemed negligent to have everything this far apart and not check the axle spades and diff side gears..
After removing the ring gear bolts, the carrier splits and the side gears and axles are accessible.
The driver side axle spade, fulcrums, and side gear all looked nice.
Some minor wear that I polished out
The passenger side gear and spiders are retained by a pin that is peened into the diff housing. In this case the way it was peened in meant grinding and driving it out, and then re peening it was dodgy. I took it as a sign from some higher power and left it alone. Rinsed it with brake cleaner, and reassembled the diff. Upon retorquing the 6 diff bolts to 45ft/lbs I felt one give and carefully backed it out
Kamax 10.9 bolt
I managed to pull 6 bolts from my parts stash, and swapped all the bolts. Blue loctite and safety wired them
s1 driver side differential shim is 4mm and things are starting to look good
There is a freeplay spec for all 4 gears on the pinion shaft, .10mm is the minimum and .25mm is the max. Gears 1-3 were good, but I was just over .25mm on 4th gear. I ended up sanding .006" off of the 4th gear bushing and added the same amount of shim under the pinion bearing. This way the gear stack overall length was unchanged, but the extra clearance was removed..
Time to tighten the pinion nut, to 85ft/lbs.
I clamped a worn out 1/2 slider in the vice, and set the pinion stack into it. Tightened and locked the tab
Finally getting to the shift fork adjustment
You remove the main input shaft to access the reverse shift fork adjustment
Here is the bolt, The reverse spur gear is directly under it, you can see it's half contacting first gear.
Slide the fork so the gears makes full centered contact when reverse is engaged, and tighten the 11mm bolt, then check neutral to make sure it doesn't foul on anything
Next, 3/4 shift fork, the adjustment bolt is through this hole.
The correct adjustment is with the shift rail in it's neutral detent, and the slider centered on the hub. Now move the fork so it is as centered in the slider groove as you can get it, and lock the bolt.
1/2 shift fork, this took a while to feel confident about the adjustment.
For some reason there is a little more fore/aft play in the slider when it's in neutral, so finding the right position for the fork took some experimenting. The idea is that in neutral, none of the shifting forks should be pressing any of the hubs, so everything freewheels, this is often referred to as a "clean neutral".
That was enough for one night. Found some magnetic drain plugs in the stash, and started looking at the axle tubes to R&R the boots. Ordered some threebond 1184 for the case halves and went to bed!
SD
modok wrote:
esde
esde is offline
PostPosted: Tue Jan 09, 2024 8:35 pm    Post subject: Reply with quote
CLOSER
Got the Axle tubes pressed apart. NOTE: you drive the lock pin out from the shock mount side, and that pin is tight so get the biggest hammer. Once it's out get everything in the press like so
It comes apart easily enough, and cleaning the grease off is as bad as you imagine it will be. But it's worth it, cleaned, painted, and with new one piece boots ready to go
Here you can see the groove that the lock pin engages. I measured and made a scratch at the approximate depth the housing gets pressed to
I thought I had a better pic of pressing it back together, so use your imagination.
Used a little pen light to look into the lock pin bore, so I could see exactly when the groove was lined up, then drove the pins home
Triple checked everything inside the case. Wiped the flange down w acetone, and gave it a smear of my favorite sealer, Threebond 1184.
Together and axles tubes just hung for decoration.
Nosecone next, there are a few shims there, and one of the mount studs is bent..
SD
modok wrote:
kaieric Premium Member
kaieric is offline
PostPosted: Wed Jan 10, 2024 8:45 am    Post subject: Re: 56 vert Jimmy Sprinkles Reply with quote
wow! marvelous work!
7/58 Beetle Cabrio RHD
tehillah1
tehillah1 is offline
PostPosted: Wed Jan 10, 2024 9:10 am    Post subject: Re: 56 vert Jimmy Sprinkles Reply with quote
Seth, your mechanical skills are amazing. Great detail on the tranny restoration.
esde
esde is offline
PostPosted: Mon Jan 15, 2024 9:46 pm    Post subject: Re: 56 vert Jimmy Sprinkles Reply with quote
Since finishing the transmission I've been working on 10 things at once, and it doesn't feel like I'm making headway.. but things are moving along. I crawled under the car to scrape off the grease and grit, and give everything a better look. With the engine out I can see the passenger rear is buckled slightly. Maybe you can pick it out in these pics
This side is ok
This side is pushed in about 3/4"
I have a few ideas on how I might push it back, but I'll let it go for now. If I have time and confidence later, maybe..
I got new seals for the nosecone and the cables junction, and spring plate bushings. Plus I'll give this a thorough cleaning
Got the new mounts installed on the trans. Nothing unusual, except the new ones require you to drill the mount for a 10mm stud (original was 8mm) and you need to grid the top of the mount for clearance
I have a few 36hp cases that are all getting prepped at the same time. I pulled the plugs on all of them and started tapping for new threaded plugs. You need 1/16, 1/8, and 1/4npt taps
These two are access to the cam supply passage, drill and tap for 1/16npt
On the other side, the tapped hole is 1/8npt, and the other is where the full flow elbow will go. It gets tapped for 1/4npt but first I have to fix the fact that it's off center
Mounted the case under the mill and centered the hole
Have to go slow tapping that as the case material is thin
Here it is done, you can see the tap where I plug the old oil pump supply
There's another 1/16 next to the crank pulley and a 1/8 on top next to the oil sender, and then I got to scrub three cases with bore brushes and solvent.
And lastly, I started on the heads. First step was to set up the mill and machine off the first fin, then I can flycut the heads to the new depth. Removing the fin is slow going, as it takes a few passes. First one down
I'm hoping too have the case ready for when the crank comes back, so I can spend some time mocking that up. Then make the final cuts on the heads and send them out for new valves.. or at least in my head thats how it works.
SD
modok wrote:
TomVaughan64
PostPosted: Mon Jan 15, 2024 9:50 pm    Post subject: Re: 56 vert Jimmy Sprinkles Reply with quote
Great pictures! Thanks for the details photos and information.
Tom
Stephen Covey
Jimbo
esde
esde is offline
PostPosted: Tue Jan 23, 2024 9:17 pm    Post subject: Re: 56 vert Jimmy Sprinkles Reply with quote
Slogging right along..
I was stumped for a few days, because I ran into an issue where one axle seemed to be out too far. Wasn't sure what was going on, so I split the trans back open to look at the differential, and make sure the axles were in the differential carrier correctly. They were, and I wasn't sure what the hell was going on so I started measuring everything..
I had one of the axle ends pushed on 25" too far. So after some swearing, I fixed it all and everything is back to normal.
The frame horns are cleaned and rattle canned black. Replaced the Bowden tube, shift fork seal, trans mounts, and the rubber boot where all the cables exit the pan.
Under the car and ready
And in
Realized I forgot a new ground strap Rolling Eyes always something..
Backing plates and seal housings got blasted, they really needed it.
It's all painted, sitting on the radiator, hopefully it will be dried so I can reassemble the brakes tomorrow.
modok wrote:
VW_Jimbo Premium Member
VW_Jimbo is offline
PostPosted: Tue Jan 23, 2024 11:44 pm    Post subject: Re: 56 vert Jimmy Sprinkles Reply with quote
Awesome progress Seth! You are moving quick on this car!
Jimbo
TDCTDI wrote:
67rustavenger wrote:
obus Premium Member
obus is offline
PostPosted: Wed Jan 24, 2024 8:32 pm    Post subject: Re: 56 vert Jimmy Sprinkles Reply with quote
you are doing this up right!! Looks like it fell to the right person for sure
esde
esde is offline
PostPosted: Sat Jan 27, 2024 9:01 am    Post subject: Re: 56 vert Jimmy Sprinkles Reply with quote
OK, several evenings spent puzzling over the rear brakes, and some hours sorting through part numbers and progressive refinements.. all trying to figure out what parts I had on Jimmy Sprinkles (and what was supposed to be there)
I had assumed that the parts were original to the car, and wasn't sure when the brakes changed at the end of oval production, now I know. Embarassed
Someone messaged me to point out that the rear brakes were later, and in fact they are 58-64. This was done by some previous owner, and was possibly because of several reasons: Wheel cylinders are larger and much cheaper, and the shoes and drums are easier to find.
I put everything back together with the new oval shoes and quickly realized that there was an issue. First clue was the shoes didn't sit correctly in the adjuster
later 58-64 shoes in front for comparison
Hard to see but I found some early adjusters and the slot is deeper and angled to match the shoe
But I swapped the oval adjusters on, but the drum wouldn't fit over the shoes. Confused
So I started digging through the parts stash, and found some early brakes left over from the zwitter project, started measuring and comparing
The early cylinders are smaller diameter, and slightly shorter side to side, so no using early shoes with later hardware
Early brakes, for comparison
so the choice is to keep the current later brakes, or swap to the correct earlier brakes.. for simplicities sake I decided to keep the current later brakes, and will box this extra set of early brakes. One more thing to check though, I read that early and later brake backing plate thickness was different, and the bearing retainer bore depth was different to accommodate this. I read that the the difference was in the axle tube end casting and the bearing retainer, but no definitive answer one way or the other.. I doubt very much that the bore depth is different on both.
I did measure how much the bearing stuck out of the axle tube end on Jimmy sprinkles, and that matched the bearing bore depth of the (58-64) retainer. So for now it appears that if the bearing retainer matches the backing plate, things bolt up correctly. Clear as mud right?
I'll dig some early parts out to measure and solve this once and for all with pictures and numbers..
modok wrote:
Käfer2
Käfer2 is offline
PostPosted: Sat Jan 27, 2024 12:03 pm    Post subject: Re: 56 vert Jimmy Sprinkles Reply with quote
Hi esde,
On my 11.56 bug I also mounted later brake baking plates 20 years ago, even later ones than you did. I mounted them with brake cylinders upwards (perhaps better to bleed the break system?), means changing left and right plate to keep the original (long) emergency brake cables going into the plates from behind.
Next step would be to change back to the original setup I still have, but until then, I leave it as it is.
My later brake backing plates are thicker than the original ones. No mechanical problems so far with the original bearing retainers.
But it took me 15 years and many attempts to realize
- to use only NOS thrust rings for the shaft seals (even good or "german" reproductions led to oil leakages in regular intervals)
- that (with the later and thicker brake backing plates in combination with the original axle tubes and original bearing retainers) thicker o-rings between "axle tube end casting" and plates must be installed to insure that NO oil sweats out between plates and "axle tube end casting" onto the plates (transmission side and brake side) over time.
Thicker o-ring:
I ended up using appoximately this o-ring-dimension:
Käfer2
Käfer2 is offline
PostPosted: Sat Jan 27, 2024 12:24 pm    Post subject: Re: 56 vert Jimmy Sprinkles Reply with quote
I forgot to mention that you should mount the bearing retainers with the "dripping edge" pointing downwards, so that oil drips down from them in the oil deflectors mouted in your break drums in case of shaft seal oil leakages
esde
esde is offline
PostPosted: Sun Jan 28, 2024 9:32 am    Post subject: Re: 56 vert Jimmy Sprinkles Reply with quote
Käfer2 wrote:
Hi esde,
Kafer2, thank you for adding the pictures and info.
I ended up out in the barn loft again, measuring old parts in an attempt to find what would fit together and not leak..
Here is what I did find, in case it will help someone else make sense of mixed up parts from different years..
This is the end of an Oval straight shock mount bearing housing, which is what I have on Jimmy Sprinkles now. It has a short lip (1.4mm) and shallow bearing bore (6.8mm)
The square sided bearing retainer has a short lip (1.4mm) and deep bearing bore (10.55mm)
The oval rear backing plate is 4.65mm, though there is some variation due to it being laminated stampings that are spot welded together.
Add all of this together, accounting for the step and backing plate and you have a 19.2mm space for the 19mm wide bearing. Measuring greasy parts in the dark might account for the .2mm, or the laminated backing plate may squish down when the bolts are tightened.
The later axle tubes... This had me stumped, as I was not aware there were straight shock mount axle tubes, that were later than oval production, but they have a different bearing bore depth Besides the shock mount hey are otherwise similar to curved shock mount axle tubes, with the pinched side bearing retainers that are used till (I'm not exactly sure when, I think through 65)
Heres the 58-60
Here's the 61 to 65? curved shock
Both read 10.05-10.08mm bearing bore depth, and both have a 4.7mm tall lip. Not doubt the tall lip helps to hold the backing plate and gaskets during assembly.
The matching pinched bearing retainer has no lip, and a 9.25mm bearing bore depth.
The backing plate is thicker than the early one, 5.16mm- 5.25mm
Add all of this up and you have a 19.3mm space for the 19mm wide bearing.
Again, the extra tolerance may be a manufacturing allowance, measuring error, or maybe the backing plate will compress some..
All that fussing to figure, that an early oval tube casting with the short lip
and a later backing plate, and later bearing retainer cap leaves 19.8mm which is too much.
If I use the early bearing retainer, I get 19.65mm
oh my head..
I wonder if people swapping to later brakes have just had side to side clearance where the axle bearing sits and not known? Sometimes ignorance is bliss as they say..
As I see it, I can bite the bullet and buy new oval drums and wheel cylinders, and put this back together with correct early parts. OR, mill a little of the bottom of a bearing retainer to achieve a 19mm depth, and use the parts that were on the car? While I do want to preserve the originality of this car, I am not against slightly later larger brakes, so I'm leaning towards option 2. I'll see what is needed to accurately mount a retainer in the milling vice today..
modok wrote:
esde
esde is offline
PostPosted: Thu Feb 01, 2024 10:09 pm    Post subject: Re: 56 vert Jimmy Sprinkles Reply with quote
DONE, Solved the conundrum of how to keep the later rear brakes on the car, without the bearings being loose in the retainers, and also not have them leak..
SO, for starters, I bolted the later brakes up, with the later bearing retainers, torqued the drums, and set a dial indicator like so.. to measure how much the bearing moved in and out
in this case it was .5mm
So, next step is to remove the retainer, and set it up to mill .5mm from the gasket surface.
Then I machined the pinched sides, so I can flip the retainers (so the oil drip lip hangs down)
Cleaned and de-burred
Reinstalled it, and it bolts up tight
When using the later thicker backing plates, I found a recommended procedure for no leaks:
-install the backing plate over the axle. Carefully push a large o-ring around the bearing, and back into the gap between the backing plate and bearing. Install a bearing retainer gasket, I used some tacky gasket adhesive to hold it. Follow with a second o-ring, which is used because the later bearing retainer has a bevel for it to squeeze into. Then the bearing cover.
Done at last. Perhaps this was more of a pain in the ass than actually rebuilding the transmission..
The bench was cleaned up from all the transmission parts, so time to take something else apart..
next victim
It's actually in decent condition, except for this brush
And the manual diagram shows a 2 brush starter but this one has 4??
checked the model #, it's a Porsche 356 starter
Super cool as it's rated at .5ps, where the stock starter is only .4ps. This will probably be better suited to spinning the new higher compression motor. Just need to find the correct brush set, which will undoubtedly have a Por$che price Rolling Eyes
And, some cleaning
The engine bay was filthy
Scrubbed, degreased, and buffed some of it
There is a super thick coating that seems to be sprayed up underneath, and I'm wondering what it is? It's really on there, not the kind of kind of goop that you get off with elbow grease. For now I'm leaving it, maybe if I run across a chance to try a steamer I'll see if it loosens it up.
Any thoughts?
Getting there..
Next step is tidying up the wiring, to get rid of some ugly splices and repairs..
SD
VW_Jimbo is offline
PostPosted: Fri Feb 02, 2024 1:06 pm    Post subject: Re: 56 vert Jimmy Sprinkles Reply with quote
Have you tried oven cleaner on that gunk. Works on a lot of hard to remove stuff!
Car is coming together very nice! Keep going, you continue to inspire me!
Jimbo
TomVaughan64
PostPosted: Fri Feb 02, 2024 1:13 pm    Post subject: Re: 56 vert Jimmy Sprinkles Reply with quote
I agree. It is inspiring to see that one person can accumulate knowledge and skills in so many areas. It gives me hope. Also, your stash of old parts is pretty impressive. (My wife may not agree with that last statement)
Keep up the quality work and thanks for sharing.
Tom
Stephen Covey
Jimbo
esde
esde is offline
PostPosted: Sat Feb 03, 2024 9:10 am    Post subject: Re: 56 vert Jimmy Sprinkles Reply with quote
VW_Jimbo wrote:
Have you tried oven cleaner on that gunk. Works on a lot of hard to remove stuff! Car is coming together very nice! Keep going, you continue to inspire me!
I considered it, but it is generally pretty aggressive. I don't want to damage whatever paint is there. Many thanks
Thanks Tom.
I've come to the realization, that for me it is better to learn how to rebuild or fix something, as I'm always disappointed with replacement parts or subcontracted work. And I LOVE buying tools, especially machinists measuring tools. Knowing how to accurately measure parts is what lets me get something right (on occasion Rolling Eyes )
As to the parts stash... it's a real exercise in self control. It's mostly in the loft of the barn, and when it starts to get crowded I either finish a project to use up some of the parts or I list stuff for sale..
Back to the starter.
The brushes for the Porsche 356 starter seem to only be available in a kit, with all the other rebuild parts. So I looked more closely at the damaged brush and realized that the way the corner is broken will never impede the way it slides in the brush holder. So, I decided to clean everything and put it all back together
The little container is Dow Corning Molykote 33, which is silicone grease that should stay put in this application. It was recommended on another board for exactly this purpose. Expensive though, so I bought the mini container
I removed the sliding drive gear assembly so I could clean and re-grease the splines. Getting the little collar and snap ring off and then back is the hardest part.
Here it is going back on. The collar slides over the shaft towards the gear, open cup end facing the shaft end.
Then the ring goes over the shaft, and you squeeze it tight into the groove. Sounds easy but the ring is some hardened alloy and does not want to bend
Pull the collar to the ring, and tap it over
Done
There is a forked lever, which is how the solenoid moves the drive gear out to the flywheel. You can see it is flattened from pressing the gear. I flipped it over, so it's now wearing on an unused side
There is no picture of me fitting the brushes and end cap, as you need 5 hands.
Essentially, the armature is just floating in the middle, while you carefully pry the springs back and install the brushes. Then the end cap covers it, the end cap screws go (hopefully) the brush holder, through the main body, and into the mounting end. Thats 5 pieces that are loose till the screws are tight, and then you still need to get the last shims, clip, and cover on. Oy vey Shocked
Not as good as new, but better that it was.
I will clean up the mounting surface, so it makes a solid ground with the transmission case
SD
VW_Jimbo is offline
PostPosted: Sat Feb 03, 2024 2:03 pm    Post subject: Re: 56 vert Jimmy Sprinkles Reply with quote
Nice job! Yep, those starter brush assemblies are not installer friendly! Nice job making it happen! Are you painting it black or leaving it blasted metal?
Jimbo
Page 3 of 5
