What is the wheezing vacuum leak sound from brake pedal switch?
markcm2
markcm2 is offline
PostPosted: Sun Mar 25, 2018 7:54 pm    Post subject: What is the wheezing vacuum leak sound from brake pedal switch? Reply with quote
I’m on a road trip and when coasting down hill, foot off the accelerator, we occasionally hear a whistle wheezing sound from the switch on the brake pedal. It will last a few seconds and/or it stops if I depress the accelerator.
What is this switch and any idea why it whistles when coasting down hill?
JMB3
JMB3 is offline
PostPosted: Sun Mar 25, 2018 11:10 pm    Post subject: Re: What is the wheezing vacuum leak sound from brake pedal switch? Reply with quote
There are two switches on the brake pedal. One cancels the cruise control. It is a dual function switch. It breaks an electrical connection, so it has wires coming into it, and it opens a vacuum to the atmosphere, so it has a vacuum line attached. http://vweurovan.wikia.com/wiki/Cruise_Control_Brake_Switch
markcm2
markcm2 is offline
PostPosted: Mon Mar 26, 2018 6:51 am    Post subject: Re: What is the wheezing vacuum leak sound from brake pedal switch? Reply with quote
Thank you for the info!
Zeitgeist 13
Zeitgeist 13 is offline
PostPosted: Mon Mar 26, 2018 10:25 am    Post subject: Re: What is the wheezing vacuum leak sound from brake pedal switch? Reply with quote
The vacuum switch was my first thought, but then I remembered that this is a drive by wire engine, so there isn't any vacuum actuator used. Does it still use the vacuum switch?
Casey--
'01 Weekender --> full camper
y u rune klassik?
Marshall277
Marshall277 is offline
PostPosted: Wed Dec 13, 2023 10:07 pm    Post subject: Re: What is the wheezing vacuum leak sound from brake pedal switch? Reply with quote
Hi - has anyone resolved this?
I recently purchased a one-owner, 2002 Eurovan MV Westfalia that's in great condition. A few days ago it started making this high pitch noise, and I'm wondering if anyone here found a resolution.
Thanks!
TheOneTrueQuux
TheOneTrueQuux is offline
PostPosted: Thu Dec 14, 2023 8:17 am    Post subject: Re: What is the wheezing vacuum leak sound from brake pedal switch? Reply with quote
Thanks!
It is likely a leaky brake booster.
Marshall277
PostPosted: Thu Dec 14, 2023 10:48 am    Post subject: Re: What is the wheezing vacuum leak sound from brake pedal switch? Reply with quote
Thanks!
Nice - do I need to replace the booster or can I spray something on it or replace a seal or repair it in any way? Thank you!
TheOneTrueQuux
PostPosted: Thu Dec 14, 2023 4:02 pm    Post subject: Re: What is the wheezing vacuum leak sound from brake pedal switch? Reply with quote
Thanks!
First confirm the diagnosis by disconnecting and plugging the vacuum line to the booster. If the noise goes away, you've found it.
The usual failure is that the diaphraghm inside gets a tear in it, replacement is usually the only option.
Marshall277
PostPosted: Thu Dec 14, 2023 4:11 pm    Post subject: Re: What is the wheezing vacuum leak sound from brake pedal switch? Reply with quote
Thanks!
This is very helpful. Thank you so much!
